Need a small change in Lisp Code Please
minejash
Hai all, i have a lisp that gives me Length and Width of Rectangles that i select into a Table in cad. the table gives me the length and width as per incremental in size (eg:{ 1x2, 1.2x2, 2.1x3 } like wise)  i have attached a screenshot of this, and also joins same size rectangle in one cell and shows number as 2.
What i need help is to get the table not as incremental values but as i select (1st selection in first cell, 2nd in second cell like that). Please check the Screen shot.
i don't know how to change the codes, the lisp is from a friend i got. so please help if possible , thanks in advance..  Please check the image ive uploaded too.
the lisp code:
(defun rectangle_dims (e / l a b)
  (setq l (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) e)))
  (if
    (and
      (or
        (= 1 (logand (cdr (assoc 70 e)) 1))
        (equal (car l) (last l) 1e-8)
      (equal (distance  (car   l) (caddr l)) (distance  (cadr   l) (cadddr l)) 1e-8)
      (equal (mapcar '- (cadr  l) (car   l)) (mapcar '- (caddr  l) (cadddr l)) 1e-8)
      (equal (mapcar '- (caddr l) (cadr  l)) (mapcar '- (cadddr l) (car    l)) 1e-8)
    (vl-sort (list (distance (car l) (cadr l)) (distance (cadr l) (caddr l))) '<)
(defun C:RECDIMS (/ acObj acDoc space *error* ss e old r p1)
  (vl-load-com)
  (setq acObj (vlax-get-acad-object)
        acDoc (vla-get-activedocument acObj)
        space (vlax-get acDoc (if (= 1 (getvar 'cvport)) 'PaperSpace 'ModelSpace))
  (vla-startundomark acDoc)
  ;;;;;; Error function ;;;;;;;;;
  (defun *error* (msg)
    (and
      msg
      (not (wcmatch (strcase msg) "*CANCEL*,*QUIT*,*BREAK*"))
    (vla-endundomark acDoc)
  (if
    (setq ss (ssget '((0 . "LWPOLYLINE") (-4 . "<OR") (90 . 4) (90 . 5) (-4 . "OR>"))))
        (setq e (ssname ss (setq i (1- i))))
        (if
          (setq dims (rectangle_dims (entget e)))
          (if
            (setq old (vl-some '(lambda (d) (if (equal (list (cadr d) (caddr d)) dims 1e-8) d)) r))
            (setq r (subst (cons (1+ (car old)) dims) old r))
            (setq r (cons (cons 1 dims) r))
      (if
        (and r (setq p1 (getpoint "\nSpecify table insert point: ")))
        (insert_table
          (mapcar
            '(lambda (a)
               (list (cadr a) (caddr a) (car a))
            (vl-sort (vl-sort r '(lambda (a b) (< (caddr a) (caddr b)))) '(lambda (a b) (< (cadr a) (cadr b))))
          p1
;;The textheight in table depends on cannonscale
(defun insert_table (lst pct / tab row col ht i n)
  (setq ht  (/ 2.5 (getvar 'cannoscalevalue))
        pct (trans pct 1 0)
        n   (trans '(1 0 0) 1 0 T)
        tab (setq tab (vla-addtable space (vlax-3d-point pct) (+ 2 (length lst)) (length (car lst)) (* 2.5 ht) ht))
  (vlax-put tab 'direction n)
  (mapcar
    (function
      (lambda (rowType)
        (vla-SetTextStyle  tab rowType (getvar 'textstyle))
        (vla-SetTextHeight tab rowType ht)
   '(2 4 1)
  (vla-put-HorzCellMargin tab (* 0.14 ht))
  (vla-put-VertCellMargin tab (* 0.14 ht))
  (setq lst (cons '("Width" "Length" "Pcs.") lst))
  (setq i 0)
  (foreach col (apply 'mapcar (cons 'list lst))
    (vla-SetColumnWidth tab i
      (apply
        'max
        (mapcar
          '(lambda (x)
             ((lambda (txb) (+ (abs (- (caadr txb) (caar txb))) (* 2.0 ht)))
              (textbox (list (cons 1 (vl-princ-to-string x)) (cons 7 (getvar 'textstyle)) (cons 40 ht)))
          col
    (setq i (1+ i))
  (setq lst (cons '("RECTANGLES") lst))
  (setq row 0)
  (foreach r lst
    (setq col 0)
    (vla-SetRowHeight tab row (* 1.5 ht))
    (foreach c r
      (vla-SetText tab row col (vl-princ-to-string c))
      (setq col (1+ col))
    (setq row (1+ row))
(princ "\nType RECDIMS to start the command")
Try this.  I rewrote most of it
I don't know how to handle tables (in lisp) well, I hardcoded the size of things.  So I hope you have a text height of 2.5, else this needs some more work
  (if
    (and
      (or
(defun inserttable (lst pt / ht tab i j row tb)
  (setq ht 2.5)
  (setq tab (setq tab (vla-addtable space (vlax-3d-point pt) (length lst) (length (cadr lst)) (* 1.1 ht) (* 10.0 ht))))
  (vla-SetTextHeight tab 1 ht)
  (vla-SetTextHeight tab 2 ht)
  (vla-SetTextHeight tab 4 ht)
  (vla-setcolumnwidth tab 0 20.0)
  (vla-setcolumnwidth tab 1 40.0)
  (setq i 0)
  (repeat (length lst)  ;; iterates the rows
    (vla-setrowHeight tab i 4.0)
    (setq row (nth i lst))
    (setq j 0)
    (repeat (length row)  ;; iterates the cols in the row
      (vla-SetText tab i j (nth j row) )
      (setq j (+ j 1))
    (setq i (+ i 1))
(defun c:recdims ( / ss i e lst)
  (vl-load-com)
  (setq i 0)
  (setq lst (list (list "Area Table") (list "Numbers" "Length & Width")))    ;; head / titles of the table
  (if
      (repeat (sslength ss)
        (setq e (ssname ss i))
        (princ "\n")
        (princ  (setq dims (rectangle_dims (entget e))) )
        (setq lst (append lst (list
          (list
            (itoa (+ i 1))
            (strcat "L = " (rtos (cadr dims) 2 2 ) ", W = "  (rtos (car dims) 2 2 ))
        (setq i (+ i 1))
      (inserttable lst p1)
  (if
    (and
      (or
  (setq ht 2.5)
  (setq i 0)
    (setq j 0)
      (setq j (+ j 1))
    (setq i (+ i 1))
  (vl-load-com)
  (setq i 0)
  (if
        (princ "\n")
          (list
            (itoa (+ i 1))
        (setq i (+ i 1))
Thank you so much, it works great...
Just one more help if possible. is it possible to combine TWO lisp codes so it works as one?
