The CAD Geek Posted June 26, 2018 Posted June 26, 2018 AutoCAD provides many ways to select objects in a drawing. Among these is the infinitely useful Select Similar command. What is the Select Similar command you ask? The Select Similar command lets you select objects with shared properties. With it, AutoCAD will search for and select all other objects that are like the object(s) you have selected. For example, you could quickly select all the lines, but not the arcs or polylines, on a layer, or all the dimensions, but not text in a drawing. Whatever the combination, the result of the command is always based on what you have selected. How to use the Select Similar Command The basic use of the Select Similar command is pretty straightforward. Select objects with properties like the other objects you want to select in your drawing. To use the Select Similar command: Select an object that whose properties match the other objects you would like to select in your drawing. In this example, I’ve selected a desk as I’d like to select the other desks in my drawing. With the initial object(s) selected, right-click and then choose the Select Similar option from the contextual menu that opens. In this example, interprets my selection of just one desk to find all the desks in my drawing. Although the above example uses a block, you can use the Select Similar command on any object in your drawing. For example, you could use the same procedure to select all of the dimensions or text in your drawing. Configuring the Select Similar Command Although the basics of Select Similar are simple, what many users don’t know is that you can customize how the command behaves. Put another way, you can specify what properties AutoCAD considers as it selects similar objects. To configure how Select Similar evaluates objects: Enter SELECTSIMILAR at the command-line. Choose SEttings at the Select objects or [SEttings]: prompt. Choose the properties you would like the Select Similar command to evaluate, then choose OK. That’s it! AutoCAD will now evaluate the objects in your drawing based on the similar properties you chose. Leveraging Select Similar for Quick Quantity Takeoffs There are many uses for the Select Similar command, but one of my favorite uses is for quick quantity takeoffs. By selecting a block in my drawing, I can use Select Similar in tandem with the Properties palette to get a quick count of blocks. Circling back to the desk block selected at the start of this post. Opening the Properties palette, I can quickly see I have 43 desk blocks in my drawing. Although a data extraction table is probably the better tool for calculating many quantities across your drawing, the select similar tool is an awesome tool for quick counts. What are your tips for using Select Similar in AutoCAD? Share the creative ways you use the command in the comments below. The post Leveraging the AutoCAD Select Similar Command appeared first on The CAD Geek. View the full article Quote
