dilan Posted July 10, 2019 Share Posted July 10, 2019 Hello. I have a list: (("n1" 74678.6 53741.6 0.0) ("n2" 74683.8 53741.6 0.0) ("n3" 74683.8 53747.6 0.0) ("n4" 74677.6 53747.6 0.0)) I can not convert it to this kind: (n1 74678.6 53741.6 0.0) (n2 74683.8 53741.6 0.0) (n3 74683.8 53747.6 0.0) (n4 74677.6 53747.6 0.0) Please tell me how it can be done. Thank. Quote Link to comment Share on other sites More sharing options...
kpblc Posted July 10, 2019 Share Posted July 10, 2019 Start list is one variable. Final list is 4 variables. I think it's impossible to convert quite right you want. (setq lst '(("n1" 74678.6 53741.6 0.0) ("n2" 74683.8 53741.6 0.0) ("n3" 74683.8 53747.6 0.0) ("n4" 74677.6 53747.6 0.0))) (mapcar (function (lambda(x)(cons (read (car x)) (cdr x)))) lst)) ;; returns : '((N1 74678.6 53741.6 0.0) (N2 74683.8 53741.6 0.0) (N3 74683.8 53747.6 0.0) (N4 74677.6 53747.6 0.0)) ;; using nth, foreach, mapcar etc you can get access to any element of list 1 Quote Link to comment Share on other sites More sharing options...
dilan Posted July 10, 2019 Author Share Posted July 10, 2019 48 minutes ago, kpblc said: Start list is one variable. Final list is 4 variables. I think it's impossible to convert quite right you want. (setq lst '(("n1" 74678.6 53741.6 0.0) ("n2" 74683.8 53741.6 0.0) ("n3" 74683.8 53747.6 0.0) ("n4" 74677.6 53747.6 0.0))) (mapcar (function (lambda(x)(cons (read (car x)) (cdr x)))) lst)) ;; returns : '((N1 74678.6 53741.6 0.0) (N2 74683.8 53741.6 0.0) (N3 74683.8 53747.6 0.0) (N4 74677.6 53747.6 0.0)) ;; using nth, foreach, mapcar etc you can get access to any element of list Thank you very match....That's what I need Quote Link to comment Share on other sites More sharing options...
Grrr Posted July 10, 2019 Share Posted July 10, 2019 (edited) Assuming that the list is consistent - (setq L '(("n1" 74678.6 53741.6 0.0) ("n2" 74683.8 53741.6 0.0) ("n3" 74683.8 53747.6 0.0) ("n4" 74677.6 53747.6 0.0))) ( '((L) (apply 'mapcar (cons 'list (cons (mapcar 'read (car L)) (cdr L) ) ) ) ) (apply 'mapcar (cons 'list L)) ) Edited July 10, 2019 by Grrr Quote Link to comment Share on other sites More sharing options...
dilan Posted July 10, 2019 Author Share Posted July 10, 2019 I wanted to put this list in list_box DCL, I did it like this ... ;+++++++++++++ (defun List_for_Box ( list_ / qwer ) (foreach item list_ (setq qwer (strcat "\n" " " (car item) " " (rtos (nth 1 item)) " " (rtos (nth 2 item)) " " (rtos (nth 3 item)) ) ptlist_DCL (cons qwer ptlist_DCL) ) ); end of foreach ptlist_DCL ); end of defun ;+++++++++++++ (setq ptlist_DCL (List_for_Box (("n1" 74678.6 53741.6 0.0) ("n2" 74683.8 53741.6 0.0) ("n3" 74683.8 53747.6 0.0) ("n4" 74677.6 53747.6 0.0))) show_coord (reverse ptlist_DCL) ) ;----------------------------------- (start_list "Coord") (mapcar 'add_list show_coord) (end_list) ;----------------------------------- Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 10, 2019 Share Posted July 10, 2019 For what it's worth, you needn't iterate over the list repeatedly - you can construct the string whilst adding items to the list box, e.g.: (setq lst '(("n1" 74678.6 53741.6 0.0) ("n2" 74683.8 53741.6 0.0) ("n3" 74683.8 53747.6 0.0) ("n4" 74677.6 53747.6 0.0))) (start_list "Coord") (foreach itm lst (add_list (apply 'strcat (cons (car lst) (mapcar '(lambda ( x ) (strcat " " (rtos x))) (cdr lst))))) ) (end_list) 1 Quote Link to comment Share on other sites More sharing options...
