DEAR SIR,
I NEED A LISP PROGRAM (3 IN 1) FOR XYZ COORDINATES LABEL IN AUTOCAD WITH LEADER,
THAT LISP MUST ASK THE CHOICE: EASTING+NORTHING, EASTING+NORTHING+Z, AND Z.
SEE ATTACH IMAGE
Edited by Ish
MODIFY
The suggestion is good a couple of changes put the two getpoint into a while so you can repeat.
; pick a point and make a leader
; by Alan H July 2019
(defun C:cxy ( / pt1 pt2 ans txtx txty txtz oldlay)
(command "-layer" "m" "Co-ordinates" "c" 1 "Co-ordinates" "")
(setq oldlay (getvar 'clayer))
(setvar 'clayer "Co-ordinates")
(if (not AH:Butts)(load "Multi Radio buttons.lsp"))
(if (= but nil)(setq but 1))
(setq ans (ah:butts but "V"  '("Please choose" "E-N" "E-N-Z" "Z")))
(setvar "cmdecho" 0)
(while (setq pt1 (getpoint "\nPick point for co-ordinate: "))
(setq pt2 (getpoint pt1 "\nPick point for text: "))
(if pt2
(setq txtx (strcat "E= " (rtos (car pt1) 2 3) ))
(setq txty (strcat "N= " (rtos (cadr pt1) 2 3) ))
(setq txtz (strcat "Z= " (rtos (caddr pt1) 2 3) ))
(princ "\n")
(cond
((= ans "E-N")(command "leader" pt1 pt2 "Annotation" txtx txty ""))
((= ans "E-N-Z")(command "leader" pt1 pt2 "Annotation" txtx txty txtz ""))
((= ans "Z")(command "leader" pt1 pt2 "Annotation" txtz ""))
(setvar 'clayer oldlay)
(c:cxy)
Multi radio buttons.lsp
Edited by BIGAL
Hi,
Give this a shot.
(defun c:enz (/ key pnt dim a b c)
  ;;	Tharwat - 5.Jul.2019	;;
  (and
    (or (initget "EN ENZ Z")
        (setq key
               (cond
                 ((getkword
                    "\nPick your go [EASTING+NORTHING , EASTING+NORTHING+Z , Z] [EN ENZ Z] < EN > :"
                 ("EN")
    (setq pnt (getpoint "\nSpecify base point : "))
    (setq dim (getvar 'DIMZIN))
    (setvar 'DIMZIN 0)
    (mapcar 'set
            '(a b c)
            (mapcar '(lambda (k p) (strcat k (rtos p 2 4)))
                    '("E=" "N=" "Z=")
                    pnt
    (setvar 'DIMZIN dim)
    (command "_.LEADER"
             "_none"
             pnt
             (nth (vl-position key '("EN" "ENZ" "Z"))
                  (list (strcat a "\\P" b) (strcat a "\\P" b "\\P" c) c)
(defun C:cxy ()
(if pt2
(princ "\n")
(cond
(setvar "cmdecho" 1)
(c:cxy)
Thanks, it working smoothly
That is good one, Plz Add a code for layer:
in that lisp program, automatic create layer for leader and text.
leader and text must be come in layer,             Layer name  "Coordinate"
17 hours ago, Tharwat said:
Hi,
Give this a shot.
  (and
        (setq key
               (cond
                 ((getkword
                 ("EN")
    (setvar 'DIMZIN 0)
    (mapcar 'set
            '(a b c)
                    '("E=" "N=" "Z=")
                    pnt
    (command "_.LEADER"
             "_none"
             pnt
after upload i received msg.
AP APPLOAD ENZ.lsp successfully loaded.
Command: ; error: bad argument type: numberp: nil
You may need to read the codes that you copied and search if there is any question mark(s) or any other weired chars added automatically with the codes due to the software of this forum and this is happening a lot.
NOW WORKING GOOD.
BY DEFAULT  <EN>  IS GOOD.
BUT FOR ENZ AND Z I NEED TO TYPE ,
IT IS POSSIBLE FOR ENZ AND Z JUST CLICK BY MOUSE ON ENZ AND Z AS WELL AS TYPE.
*** NOTE - CONTINUOUSLY NOT GETTING VALUE, EVERY TIME NEED TO HIT ENTER, MAKE LOOP UNTILL ESCAPE BUTTON PRESS.
AND BY LAYER CODE ALSO ADD IN PROGRAM.
LAYER NAME  "Coordinate"
SEE 2nd image offset: asking option by click (through, erase, layer)
THANKS
Edited by Ish
MODIFY COMMENTS
Tharwat your welcome to use the multi radio button lisp and replace initget so your code becomes a mouse pick could add a exit button. Happy for any comments back to me for improvements. Examples of how to use are in code.
Lsh Re NOT GETTING VALUE as your using a getpoint its hard to not return just that co-ords of pick point, only way is to check that an object was found at that point, would need to be added.
Just hit the F12 to enable the Dynamic input (DYNMODE) then you can pick the option you want right from mouse click.
On 7/6/2019 at 8:54 AM, Ish said:
NOW WORKING GOOD.
*** NOTE - CONTINUOUSLY NOT GETTING VALUE, EVERY TIME NEED TO HIT ENTER, MAKE LOOP UNTIL ESCAPE BUTTON PRESS.
THANKS
The lisp function GETKWORD finds the first distinct matching Upper-case characters for the command line making [z] the only option since both of the other options start with E.
Something like [NoZ All Z] should give you clickable options.
Ish I have updated the original code to include new layer.
Tharwat did not know about Dynmode and initget handy to know. You never stop learning with Autocad.
Edited by BIGAL
THANK YOU SIR,
SIR PLZ UPLOAD AGAIN YOUR LISP AFTER MODIFY
CLICK BASE [E] [ENZ] [Z]
LAYER "COORDINATE"
CONTIGUOUSLY GET VALUE
THANKS
LAYER "COORDINATE"
THANKS
LAYER "COORDINATE"
THANKS
Tharwat's code with slight modifications in my later post.
Edited by tombu
Updated code below.
Poor old "Z", always getting nozall'd.
I'll get my coat.
17 hours ago, tombu said:
Tharwat's code with slight modification:
  ;;	(load "enz.lsp") enz
  ;;	https://www.cadtutor.net/forum/topic/68126-require-lisp-3-in-1-for-xyz-coordinates-with-leader/?tab=comments#comment-552639
  (and
    (or (initget "NoZ All Z")
        (setq key
               (cond
                 ((getkword
                    "\nPick your go [No Elevation , All Coordinates , Z coordinates only] [NoZ/All/Z] < NoZ > :"
                 ("NoZ")
    (setvar 'DIMZIN 0)
    (mapcar 'set
            '(a b c)
                    '("E=" "N=" "Z=")
                    pnt
    (command "_.LEADER"
             "_none"
             pnt
             (nth (vl-position key '("NoZ" "All" "Z"))
 now working good, by click.
please do small modify , every time i get coordinate , i must hit enter or click.,
if i need EN value only, until i press escape button that must give value .
i get EN  value than again hit enter for another EN value.
if any option select, i need continuously value by pick until i  press escape button.
See image, after get EN value it stop, for second En value i need hit enter.
thanks
Edited by Ish
MODIFY COMMENTS
thanks
Once you select an option this will continuously allow you to keep picking points until you hit Enter or Spacebar.
(defun c:enz (/ clr key pnt a b c)
  ;; Add Commas
  ;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/1-000-comma-separator/m-p/1857166#M230806
  ;; Code Source: John Uhden
  ;; This function pads a numeric string with commas.
  ;; Arguments:
  ;; num = any number, real or integer (>= 0)
  ;; # = precision, integer (>= 0)
  (defun rtoc (num # / p#)
	(setq num (rtos num 2 #) # 1)
	(while (and (/= (substr num # 1) ".")(<= # (strlen num)))
	  (setq # (1+ #))
	(setq # (1- #) p# #)
	(if (= (setq # (rem # 3)) 0)(setq # 3))
	(while (< # p#)
	  (setq num (strcat (substr num 1 #) "," (substr num (1+ #)))
		# (+ 4 #)
		p# (1+ p#)
	num
  (setq clr (getvar 'clayer)) ; from dlanorh's code
  (cond ( (null (tblsearch "LAYER"  "Coor Text")) (command "-layer" "_M" "Coor Text" "_C" 7 "" "")) (t (setvar 'clayer "Coor Text")))
  (and
        (setq key
               (cond
                 ((getkword
                 ("NoZ")
    (setvar 'DIMZIN 0)
    (while pnt
	  (mapcar 'set
			  '(a b c)
			  (mapcar '(lambda (k p) (strcat k (rtoc p 4)))
					  '("E=" "N=" "Z=")
					  pnt
	  (command "_.LEADER"
			   "_none"
			   pnt
    ) ; while
  (setvar 'clayer clr)
Edited by tombu
Added comma separators for coordinate values and set "Coor Text" as current layer.et .
  ;;	https://www.cadtutor.net/forum/topic/68126-require-lisp-3-in-1-for-xyz-coordinates-with-leader/?tab=comments#comment-552696
  (and
        (setq key
               (cond
                 ((getkword
                 ("NoZ")
    (while pnt
	  (setvar 'DIMZIN 0)
	  (mapcar 'set
			  '(a b c)
					  '("E=" "N=" "Z=")
					  pnt
	  (command "_.LEADER"
			   "_none"
			   pnt
    ) ; while
 wonderful Sir,
now working perfectly.
Request To You just add code for layer,  create Layer Automatic And All value must come in Layer
layer Name "Coor Text"
Thanks a Lot.
