DEAR SIR,
REQUIRE LISP TO WRITE TEXT VALUE ON LINE/PLINE.
THE TEXT VALUE I HAVE IN EXCEL THAT IS NOT SAME,  I WANT TO WRITE THAT TEXT ON LINE/PLINE AT MID WITH SAME ROTATION OF LINE/PLINE.
THANKS
SEE IMAGE
  • Dislike 1
What does your spreadsheet look like?
How do you know which text is linked to which line?  Just by the number (1 to 6) that's next to it?
Are those numbers TEXT? MTEXT?  blocks with attributes? ...
Edited by Emmanuel Delay
1~6 IS LINE NUMBER
EXCEL LOOK LIKE
LINE NO            TEXT
1                           -2.00%
2                           -2.20%
3                           -2.50%
4                           -3.00%
5                            4.00%
6                            4.00%
BUT I WANT TO WRITE TEXT ONLY ON PLINE, LINE NUMBER IS ALREADY WRITTEN IN DWG.
EX: ON LINE NUMBER 1 I WANT TEXT -2.00% AT MID LOCATION
There is a mistake in the image the two 4% are slightly different, if you just want to draw a series of lines at a % then ask for that you can do say a point and start offset so lines are radial. Even with X and Y scales can still be done.
Sir ,
thanks for your good and valuable time.
now no need to make lisp program,  i get another good trick by cadtools, to write the text value on pline .
