nlandry83 Posted June 26, 2019 Posted June 26, 2019 I'm needing to find the coordinates of a specific point of an arc within a polyline using VBA. I'm not sure exactly what you would call this point, but basically it would be the vertex of two lines that if you used the fillet command would create the arc shown in the polyline. I have attached a picture to show what I am looking for. Quote
BIGAL Posted June 27, 2019 Posted June 27, 2019 IP Intersection point, no code rather method lisp vba .net the all have a method of working out what segment of the pline you have picked so in simple terms you would make two new lines and work out the intersection point, then erase two lines, you may be able also to use ray lines hence dont actually exist. The old lisp INTERS command supports 4 point intersection (inters p1 p2 p3 p4) solution v's vl instersectwith which needs two objects. So search for VBA pline segments etc. If some one does not answer sooner. Quote
BIGAL Posted June 27, 2019 Posted June 27, 2019 (edited) Found some time this is in lisp but pretty easy to convert to VBA In the code no check if you have picked a radius or a straight. The line command is so you can see something for the result. Its not perfect need a bit more time has problem where the radius is the last section but close. ; Intersection point of plines where radius exists ; By Alan H June 2019 (defun PSN (plsel / ) (1+ (fix (vlax-curve-getParamAtPoint (car plsel) (osnap (cadr plsel) "_nea") ) ) ) ) (defun ah:IPP ( / pt1 pt2 pt3 pt4 pt5 seg1 seg2 plent) (setq plent (entsel "Select Polyline Radius")) (setq seg1 (- (psn plent) 1)) (setq seg2 (+ seg1 2)) (if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent)))))) (if (> seg2 (length co-ord))(setq seg2 1)) (setq pt1 (nth (1- seg1) co-ord)) (setq pt2 (nth seg1 co-ord)) (setq pt3 (nth (1- seg2) co-ord)) (setq pt4 (nth seg2 co-ord)) (if (= pt4 nil)(setq pt4 (nth 0 co-ord))) (setq pt5 (inters pt1 pt2 pt3 pt4 nil)) (command "line" pt5 (list 0 0) "") (princ) ) (ah:IPP) Edited June 27, 2019 by BIGAL Quote
nlandry83 Posted June 27, 2019 Author Posted June 27, 2019 Thank you BIGAL. It seemed to work for point B but not for the other two points. I was thinking of maybe going in a different direction but not sure how it could be done. Is there a way to pull the intersection points of all the lines within the polyline? So, basically ignoring the arcs all together. I would still need to keep the polyline intact though. Quote
lrm Posted June 27, 2019 Posted June 27, 2019 Here's a simple process that has you manually pick the arc segment start, end, and center to find the intersection point. Use it with osnap set to end and cen. YOu could adapt the process to work on all arc segments of a polyline. (defun c:AV (/ p1 p2 p3 p4 p ang osm) (setq p1 (getpoint "\nSelect arc beginning.") p2 (getpoint p1 "\nSelect arc end.") pctr (getpoint p2 "\nSelect arc center.") ang (angle pctr p1) p3 (polar p1 (+ ang (/ pi 2.)) 10) ang (angle pctr p2) p4 (polar p2 (+ ang (/ pi 2.)) 10) p (inters p1 p3 p2 p4 nil) ) (setq osm (getvar "osmode")) (command "_line" pctr p "") (setvar "osmode" osm) (princ) ) Quote
nlandry83 Posted June 27, 2019 Author Posted June 27, 2019 Thanks Irm. It works great! I'm having some trouble adapting this to VBA though. Mainly with the 'angle' and 'polar' portions of the equation. Do you know of a way to adapt that to VBA? Quote
lrm Posted June 28, 2019 Posted June 28, 2019 I don't have access to AutoCAD/VBA but wrote the following using Excel/VBA which you could adapt to AutoCAD/VBA. I used some vector algebra (i.e., cross product) rather than tri to determine a perpendicular line to the radial line for the arc as it avoids potential problems with vertical lines (slope = 0). Note that an arc that subtends 180° will cause an error as the tangent lines to the arc's end point are parallel and thus do not intersect. Sub ArcVertex() Range("B2:b2").Select p1x = ActiveCell.Value ActiveCell.Offset(0, 1).Select p1y = ActiveCell.Value ActiveCell.Offset(1, -1).Select p2x = ActiveCell.Value ActiveCell.Offset(0, 1).Select p2y = ActiveCell.Value ActiveCell.Offset(1, -1).Select pcenx = ActiveCell.Value ActiveCell.Offset(0, 1).Select pceny = ActiveCell.Value Call cross(pcenx - p1x, pceny - p1y, 0, 0, 0, 1, p3x, p3y, p3z) p3x = p3x + p1x p3y = p3y + p1y Call cross(pcenx - p2x, pceny - p2y, 0, 0, 0, 1, p4x, p4y, p4z) p4x = p4x + p2x p4y = p4y + p2y Range("B6:B6").Select ActiveCell.Value = p3x ActiveCell.Offset(0, 1).Select ActiveCell.Value = p3y ActiveCell.Offset(1, -1).Select ActiveCell.Value = p4x ActiveCell.Offset(0, 1).Select ActiveCell.Value = p4y pintx = ((p3x * p1y - p1x * p3y) * (p4x - p2x) - (p4x * p2y - p2x * p4y) * (p3x - p1x)) / _ ((p3x - p1x) * (p4y - p2y) - (p4x - p2x) * (p3y - p1y)) pinty = ((p3x * p1y - p1x * p3y) * (p4y - p2y) - (p4x * p2y - p2x * p4y) * (p3y - p1y)) / _ ((p3x - p1x) * (p4y - p2y) - (p4x - p2x) * (p3y - p1y)) ActiveCell.Offset(1, -1).Select ActiveCell.Value = pintx ActiveCell.Offset(0, 1).Select ActiveCell.Value = pinty End Sub Sub cross(ax, ay, az, bx, by, bz, cx, cy, cz) cx = ay * bz - az * by cy = az * bx - ax * bz cz = ax * by - ay * bx End Sub arc_vertex.zip Quote
