modify startup screen
samifox
hi
im using several costumized version of the same autocad. i would like to chang the startup screen, is that possible?
Thanks
Shay
No, you can turn if off though with STARTMODE.  You can always access it using Ctrl+Home or by clicking the Start tab if you use File Tabs. I keep FILETABSTATE set to 0 to save screen space.
This is possible. I did it for myself, it was a long time ago. But this is a violation of the license agreement. :)
This is a change in the original AutoCAD files.
