convert Spline to Polyline
Guest Beadin Sabovic
Hi everyone,
How can I convert Spline to Polyline.
Thank you :lol:
1 way is to DXFOUT in R12 format the selcted object, and then DXFIN the file. -David
Thank you David for replay,
I did dxfout and dxfin but I still can not convert my spline to polyline.
QUOTE FROM THE DOTSOFT FAQ
The new SPLINE objects introduced in R13 are nice, but there are limits on what you can do with them. So conversion to a polyline is necessary. Carefully erase all the geometry except for the splines, then save the drawing in R12 DWG (A2K users use R12 DXF) format. Then open the original drawing, erase the splines and insert the R12 file. The spline will now have become polylines. If the splines had differing elevations on the vertices, the resulting polyline will be a 3D polyline.
Or you could try this link and scroll down til you see the program with this text description
http://www.dotsoft.com/freestuff.htm
Converts a selection set of splines to polylines inside the drawing. No more hoops with DXF files in R12 format.
HTH....
Ot you could use:
(defun massoc (key alist / x nlist)
 (foreach x alist
   (if (eq key (car x))
       (setq nlist (cons (cdr x) nlist))))
 (reverse nlist))
(defun c:spl2pol (/ en ed pl)
 (setq en (ssname (ssget '((0 . "SPLINE"))) 0)
       ed (entget en)
       pl (massoc 10 ed))
 (command "_.PLINE")
 (foreach p pl
    (command p))
 (command "")
 (command "_.CHPROP" (entlast) "" "_LA" (cdr (assoc 8 ed)) ""
          "_.PEDIT" (entlast) "_Spline" "_X")
 (entdel en)
 (redraw (entlast))
(prin1))
-David
  • 7 months later...
Hi,
I apology that I am late.
I downloaded SPL2PL.VLX
My question is: What should I do with file SPL2PL.VLX.
Where to place this file.
Thank you very much.
  • 5 years later...
Hi,
You just type the upload command in autocad command prompt.
browse the sp2pl.vlx, hit load and close.
Then type "spl2pl" command to run this command.
Thanks,
Kumar.
  • 2 years later...
You can try out the new SPLINECAM app in Autodesk AppStore or download it from autocam2d.com/download link.
It converts splines to polylines/polyarcs with optimal number of vertices and smoothness.
regards
cncpatriot
You can try out the new SPLINECAM app ....
In general, I think it is OK to post commercial solutions when a current question is asked, but I do not think it is proper to search and drag up old posts for the purpose of making advertisment of new products. (especially when you do it in multiple (very old) threads)
