Siberian Posted June 17, 2019 Posted June 17, 2019 In the IFC-options dialog I can chose what to export and not. In this case it is one particular family that I don't want to export (yet). It resides within Mechanical Equipment, but it doesn't seem possible to turn off elements within the category - only the entire category as a whole. Is there any way around this? Quote
tzframpton Posted June 17, 2019 Posted June 17, 2019 (edited) I have not tested it, but I believe all export processes will export only visible objects in the 3D View that's currently active. So you can use the Right Click > Select Similar to quickly isolate and hide certain Family Types, rather than entire Categories. I'm shootin' from the hip here so I would test it first. -TZ Edited June 17, 2019 by tzframpton Quote
Siberian Posted June 18, 2019 Author Posted June 18, 2019 I'll need to check that as well, but I believe you're right. Appreciate the help Quote
