I found a lisp that does this, but i need a couple more tweaks to make this perfect. I need precision to be set to 2 decimal points and i also dont want Elevation output. Can someone help me change the nesecary lines, since i dont know the first thing about programming
Quote
;POLYVERT - list coordinates of polyline vertices
;CAD Studio - www.cadstudio.cz  www.cadforum.cz
(setq __PV_Delimiter "      ") ; or ";" or (chr 9)
(setq __PV_DP (getvar "LUPREC")) ; decimal places
(defun C:POLYVERT ( / ent listCOORDINATES PT1)
 (setq ent (entsel "\nPick POLYLINE to list vertices:"))
 (if
  (and ent
      (wcmatch (cdr (assoc 0 (entget (setq ent (car ent))))) "*POLYLINE") ;all types
  ) ;and
   (setq listCOORDINATES (PolyVert ent)) ;make list
   (princ "\nVertex list:")
   (foreach PT1 listCOORDINATES ;all vertices
    (princ (strcat "\n" (rtos (car PT1) 2 __PV_DP) __PV_Delimiter
                        (rtos (cadr PT1) 2 __PV_DP)
__PV_Delimiter
                        (rtos (caddr PT1) 2 __PV_DP) )) ;
display XYZ
   ) ;for
  ) ;progn
  (princ " no polyline selected")
 ) ;if
; PolyVert
; returns vertices list for any type of polyline (in WCS coordinates)
; arg POLY: polyline to list (ename or vla-object)
(defun PolyVert (POLY / par pt1 lst)
  (vl-load-com)
  (setq    par (if (vlax-curve-isClosed POLY)
                (vlax-curve-getEndParam POLY) ; else
                (1+ (vlax-curve-getEndParam POLY))
  (while (setq pt1 (vlax-curve-getPointAtParam POLY (setq par (- par 1))))
   (setq lst (cons pt1 lst))
) ; return lst
(princ "\nPOLYVERT command loaded.")
Source:
https://www.cadstudio.cz/en/download.asp?file=PolyVert
To change the number of decimal places, change line 6. It says
Remove the part that says (getvar "LUPREC") and replace it with (or however many). You can also keep this line and change the precision with the UNITS command, which is where the routine gets this number.
To remove the Z coordinate, remove the text (lines 19 and 20) that says
__PV_Delimiter
Make sure you keep the two parentheses at the end of the second line. You will get an error if they are missing.
For me the code is a bit messy it  looks like old code. There are some simple ways to get the co-ordinates or just a vl 'getcoordinates. You could do multiple plines in one go checking for 3d polylines hence Z. Using ssget with pline filter would be way better than using entsel.
The reason no code is I would suggest a bit of a Google there is lots of examples out there and do decimals using rtos a better method than luprec.
For me I don't have anything pre done maybe Lee-mac.com has a good routine and I expect lots more.
If you paste these two lines 1 at a time you will see the co-ords.
(setq ent (entsel))
(if ent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car ent))))))
Edited by BIGAL
__PV_Delimiter
Thanx man worked like a charm
(setq ent (entsel))
Not sure how the code could get any better, but with the cyberangels edits, it acts exactly as i wanted.
Is there any way to list lengths of each polyline side in a 3rd column (where z columkn used to be) ? This would get me to maximum effect since i'm required to have a table with vertex coordinates and its side for boundary polygons. And for the moment after i use this routine i do an autoannotate and then type each side manually. It would save me some time. Especially when the polygon changes shape and i have to redraw the table of information
Found code for the lengths as well. I only need the decimal precision to be set to "2", and the result to be added as the 3rd column on the prvious code without printint "Segment#:"
Quote
(defun c:Test (/ T_Entity T_Object T_Start T_End T_SegmentLengths T_Count)
   (if
      (and
         (setq T_Entity (car (entsel "\nSelect polyline: ")))
         (= (vla-get-ObjectName (setq T_Object (vlax-ename->vla-object T_Entity))) "AcDbPolyline")
         (setq T_Start (vlax-curve-getStartParam T_Object))
         (setq T_End   (vlax-curve-getEndParam T_Object))
         (while (< T_Start T_End)
            (setq T_SegmentLengths (append T_SegmentLengths (list (- (vlax-curve-getDistAtParam T_Object (setq T_Start (1+ T_Start))) (vlax-curve-getDistAtParam T_Object (1- T_Start))))))
         (setq T_Count 0)
         (foreach T_Item T_SegmentLengths
            (princ (strcat "\nSegment " (itoa (setq T_Count (1+ T_Count))) ": " ))
         (princ (strcat "\n\n ** Total polyline length is " ))
      (princ "\n ** Nothing selected or not a polyline.")
Source:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/list-the-length-of-all-segments-of-a-polyline/td-p/7506972
Vla-get-length is the answer.
It seemed a lot of code to do something simple there are lots of ways of getting co-ordinates of either 3d or 2d polylines.
If you look at lee-mac.com he has a great dump all info including arcs in a poly line.
(defun c:test ( , ent str pt str)
(setq ent (entsel))
(setq str "")
(repeat (setq x (length co-ord))
(setq pt (nth (setq x (- x 1)) co-ord))
(setq str  (strcat str "\n" "x= " (rtos (car pt) 2 3) " Y= " (rtos (cadr pt) 2 3)))
(alert str)
Please count lines of code. yes can add trans to world ucs.
My $0.05
(defun c:test ( / ent str pt str)
(setq ent (entsel))
(setq obj (vlax-ename->vla-object (car ent)))
(if (= (vla-get-objectname obj) "AcDbPolyline")
(setq str "")
(setq len (rtos (vla-get-length obj) 2 2))
(setq str (strcat str "\n \nLength = " len))
(alert str)
(alert "You did not pick pline")
(c:test)
Edited by BIGAL
31 minutes ago, BIGAL said:
My $0.05
(setq ent (entsel))
(setq str "")
(alert str)
(c:test)
Does not load for me
Command: APPLOAD
test.lsp successfully loaded.
Command: syntax error :error#2
I added a "did not pick pline" but was working sometimes cutting and pasting hidden characters get added.
Thank you so much for your trouble BIGAL, sadly its pretty far from what i want. I'll just keep using the couple previous routines, and do a 2-step process.
The following outputs only the x and y followed by the distance from the previous point all with 2 decimal points.  I think that is what you wanted.
(command "-units" "" 2 "" "" "" "")
(defun C:POLYVERT (/ ent listCOORDINATES PT1)
  (if
    (and ent
		  "*POLYLINE"
	 )				;all types
    )					;and
       (princ "\nVertex list (x y distance-from-previuos):")
       (setq pt0 (nth 0 listCOORDINATES))
	 (setq d (distance pt0 pt1))
	 (princ	(strcat	"\n"
			__PV_Delimiter
			__PV_Delimiter
			(rtos d 2 __PV_DP)
			__PV_Delimiter
	 display
	 XYZ
	 (setq pt0 pt1)
       )				;for
     )					;progn
  )					;if
; PolyVert
  (vl-load-com)
)					; return lst
  • 2 weeks later...
  (if
    (and ent
		  "*POLYLINE"
	 )				;all types
    )					;and
	 (princ	(strcat	"\n"
			__PV_Delimiter
			__PV_Delimiter
			(rtos d 2 __PV_DP)
			__PV_Delimiter
	 display
	 XYZ
	 (setq pt0 pt1)
       )				;for
     )					;progn
  )					;if
; PolyVert
  (vl-load-com)
)					; return lst
Sorry Man i just saw this, i came back here randomly to check someething and just saw your port. This is exacly what i wanted. Just one last tweak. Is it possible that on the length column it starts length from point 1? Cause right now it calculates length 1 as 0.000 and Since it sees no secondary vertex on first point, and i get a 0 as my first length.
For instance i get
3195.18      2015.72      0.00
3212.68      1845.18      171.44
3361.47      1845.18      148.79
3361.47      1945.75      100.58
3195.18      2015.72      180.41
but i want to get
3195.18      2015.72      171.44
3212.68      1845.18      148.79
3361.47      1845.18      100.58
3361.47      1945.75      180.41
3195.18      2015.72
This way i can copy directly from autocad history and paste directly into the drawing, without having to copy on notepad and start editing.
Also if its a closed poly where start and end match, could we omit the last vertex. I can edit the mtext and just delete last line, if its too much hassle, so this last one is no big deal.
Thanx a lot for your help.
Please note that there are two types of "closed" polylines.   Consider a polyline that forms a closed shape square.  It could have 4 defined vertices and the "c" option was used to close it or it could have 5 vertices where the first and last vertices have the same location.
The following code will handle open polylines and polylines where the first and last vertex are the same with output per your latest posted request. It will not list the  distance for a "closed" polyline where the first and last vertex are not the same but the closed parameter was used.
; modified by lrm 6/27/2019   v4
  (if
    (and ent
		  "*POLYLINE"
	 )				;all types
    )					;and
	     ptStart pt0
	 (if (/= pt0 PT1)
	     (princ (strcat "\n"
			    (rtos (car pt0) 2 __PV_DP)
			    __PV_Delimiter
			    (rtos (cadr pt0) 2 __PV_DP)
			    __PV_Delimiter
			    (rtos d 2 __PV_DP)
			    __PV_Delimiter
	     display
	     XYZ
	     (setq pt0 pt1)
	   )				; progn
	 )				; end if
       )				;for
					; check if first and last vertex are the same
       (if (> (distance ptStart pt0) 0.001)
	   (princ (strcat "\n"
			  __PV_Delimiter
			  (rtos	(cadr pt0
				2
				__PV_DP
			  __PV_Delimiter
	 )				; progn
     )					;progn
  )					;if
; PolyVert
(defun PolyVert	(POLY / par pt1 pt0 lst)
  (vl-load-com)
)					; return lst
Thanx man excellent work exactly what i needed. Now i got one less thing to worry about when doing CAD Work. Take Care.
