Sorry English is not good
Hello all
I have 1 LWPOLYLINE
Is there a LISP to find the highest or lowest value of the Y axis  POINT on the ARC S  IN polyline ?
condition should not be the beginning or end of the bow
AND picture
mntda.dwg
Edited by hosneyalaa
In case nobody writes you a lisp, you can easily find the highest and lowest points of the polyline by drawing a vertical line from the centres of each arc.
  • Thanks 1
It does not have to be the middle of the arc is the highest point
Except in a special case
Sometimes
Near the middle or beginning of the arch or end
Note that @eldon constructed the line vertically from the centre point of the arc, not the middle of the arc segment:
Edited by Lee Mac
Also the Quadrant osnap would give the highest and lowest points on the arcs.
I think OP wanted to learn something new... And BTW. LWPOLYLINE can have more than 2 arced segments... Perhaps OP wanted to find all quadrant points and sort them by Y of OCS of LWPOLYLINE...
(defun c:minmaxYarcedsegsLW ( / LM:Bulge->Arc lw lwx k dxf10l dxf42l l v1 v2 bul b->a pl )
  ;; Bulge to Arc  -  Lee Mac - mod by M.R.
  ;; p1 - start vertex
  ;; p2 - end vertex
  ;; b  - bulge
  ;; Returns: (<center> <start angle> <end angle> <radius>)
  (defun LM:Bulge->Arc ( p1 p2 b / a c r )
      (setq a (* 2 (atan (abs b)))
            r (abs (/ (distance p1 p2) 2 (sin a)))
            c (if (minusp b) (polar p2 (+ (- (/ pi 2) a) (angle p2 p1)) r) (polar p1 (+ (- (/ pi 2) a) (angle p1 p2)) r))
      (list c (angle c p1) (angle c p2) r)
  (while
    (or
      (not (setq lw (car (entsel "\nPick LWPOLYLINE with arced segemnts that lie in WCS..."))))
      (if lw
        (or
          (/= (cdr (assoc 0 (setq lwx (entget lw)))) "LWPOLYLINE")
          (vl-every '(lambda ( x ) (equal (cdr x) 0.0 1e-6)) (vl-remove-if '(lambda ( x ) (/= (car x) 42)) lwx))
    (prompt "\nMissed or picked wrong entity type or picked LWPOLYLINE with all straight segemnts...")
  (setq k -1)
  (setq dxf10l (vl-remove-if '(lambda ( x ) (/= (car x) 10)) lwx))
  (setq dxf42l (vl-remove-if '(lambda ( x ) (/= (car x) 42)) lwx))
  (while (< (setq k (1+ k)) (if (= 1 (logand 1 (cdr (assoc 70 lwx)))) (cdr (assoc 90 lwx)) (1- (cdr (assoc 90 lwx)))))
    (setq l (cons (list (nth k dxf10l) (nth k dxf42l)) l))
  (setq l (reverse l))
  (mapcar '(lambda ( a b )
    (setq v1 (cdr (assoc 10 a)) v2 (cdr (assoc 10 b)) bul (cdr (assoc 42 a)))
    (if (not (equal bul 0.0 1e-6))
        (setq b->a (LM:Bulge->Arc v1 v2 bul))
        (setq pl (cons (list (caar b->a) (+ (cadar b->a) (last b->a)) (cdr (assoc 38 lwx))) pl) pl (cons (list (caar b->a) (- (cadar b->a) (last b->a)) (cdr (assoc 38 lwx))) pl))
    ) l (cdr l)
  (setq pl (mapcar '(lambda ( p ) (trans p lw 1)) pl))
  (foreach p pl
    (if (not (equal p (osnap p "_nea") 1e-6))
      (setq pl (vl-remove p pl))
  (setq pl (vl-sort pl '(lambda ( a b ) (< (cadr (trans a 1 lw)) (cadr (trans b 1 lw))))))
  (prompt "\nMinimum Y coordinate arced point in current UCS : ") (princ (car pl))
  (prompt "\nMaximum Y coordinate arced point in current UCS : ") (princ (last pl))
This is all Vanilla AutoLisp, just in case VLISP functions not available...
  • Thanks 1
Thank you everyone
marko_ribar
eldon
Lee Mac
Responses to the topic and interaction with me
Try to create lisp and have reached the required
However, the exact needs of the experienced people may include errors due to lack of experience in lisp
I thank you again for the subject
this lisp
 I changed it
I am not his writer
The lisp  is to create points only on the arc's
(defun c:test ( / ss l e d z p n D1 D2 I N OUTT P1 PL PY SL X)
  (if
    (and
      (setq ss (ssget ":E:S" '((0 . "lwpolyline"))))
      (setq n 5)
      (> n 1)
      (setq e (ssname ss 0)
            z (cdr (assoc 38 (entget e)))
            l (vl-remove-if-not '(lambda (x) (member (car x) '(10 42))) (entget e))
            d (mapcar '(lambda (x) (/ x 1.0 n)) (repeat (1- n) (setq d (cons (1- (cond ((car d)) (n))) d))))
      (setq i 0)
      (setq sl 0.1)
      (while l
        (setq p (trans (list (cadar l) (caddar l) z) e 0))
    (setq p1 (trans (list (cadr(nth 2 l)) (caddr(nth 2 l)) z) e 0))
    (setq py (cadr p))
        (if
      (and
        (/= 0.0 (cdadr l))
        (= T (minusp(cdadr l)))
        (fix (vlax-curve-getendparam e))
            (setq d1 (vlax-curve-getdistatparam e i)
                  d2 (vlax-curve-getdistatparam e (1+ i))
                (while (< d1 d2)
                    (setq pl (cons (vlax-curve-getpointatdist e d1) pl)
                          d1 (+ d1 sl)
        (setq pl (cons (vlax-curve-getpointatdist e d2) pl))
                    (setq pl (vl-sort
                           (mapcar '(lambda(x)(list (cadr x) x))
        pl)
        '(lambda(a b)(> (car a)(car b)))))
      (setq outt(cadr(car pl)))
      ( if (and
         (> (car outt) (car p))
         (< (car outt) (car p1))
         (setq ptlst (cons outt ptlst))
      (entmake (list '(0 . "POINT") (cons 10 outt)))
        );if
        (setq pl (cdr(car pl)))
         (setq pl (vl-remove (last pl) pl))
            );pru
          );if
    (if
      (and
        (/= 0.0 (cdadr l))
        (/= T (minusp(cdadr l)))
                (while (< d1 d2)
                          d1 (+ d1 sl)
                    (setq pl (vl-sort
        pl)
        '(lambda(a b)(< (car a)(car b)))))
      ( if (and
        );if
            );pru
    (setq i (1+ i))
        (setq l (cddr l))
           );PRO
    );IF
If we break it down into individual arcs then would bounding box give correct answers ?
Or not even break it up :) .. although this doesn't just check arcs.
(defun c:foo (/ _x e1 ll o p2 s ur)
  ;; RJP » 2019-06-13
  (defun _x (p c / a vs)
    (setq a (/ pi 4.))
    (setq vs (* 0.025 (getvar 'viewsize)))
    (and p (repeat 4 (grdraw (trans p 0 1) (polar (trans p 0 1) (setq a (+ a (/ pi 2.))) vs) c)))
  (cond	((setq s (ssget))
	 (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
	   (cond ((= 'list (type (vl-catch-all-apply 'vlax-curve-getendpoint (list e))))
		  (vla-getboundingbox (setq o (vlax-ename->vla-object e)) 'll 'ur)
		  (foreach p (mapcar 'vlax-safearray->list (list ll ur))
		    (setq p2 (cons 11 (mapcar '+ p '(1 0 0))))
		    (setq e1 (entmakex (list '(0 . "line") '(8 . "junk") (cons 10 p) p2)))
		    (if	(= 3
			   (length (setq p2 (vlax-invoke
					      o
					      'intersectwith
					      (vlax-ename->vla-object e1)
					      acextendotherentity
		      (_x p2 3)
		    (entdel e1)
Edited by ronjonp
When applied to the entire object, the bounding box approach will only yield the global minimum/maximum, not the local minima/maxima such as the high/low points of the arc segments which lie inside of the bounding box - of course, this is only my interpretation of the OPs requirements - your code may be entirely suitable.
What is the correct result for a polyline such as this?
(defun c:test ( )
    (entmake
            (000 . "LWPOLYLINE")
            (100 . "AcDbEntity")
            (100 . "AcDbPolyline")
            (090 . 5)
            (070 . 0)
            (010 0.0 0.0)
            (010 -1.6208 2.3534)
            (042 . -0.404273)
            (010 -0.866311 6.87711)
            (042 . 0.48306)
            (010 -0.698647 11.8616)
            (010 -3.12366 13.9225)
            (210 0.0 0.0 1.0)
This is like some face book posts how smart are you, what does this add up to ?
My guess for arcs
max y   Y=11.8616 max x X=0.4214
miny Y=2.3534 min x X=-2.2029
