jim78b Posted June 8, 2019 Posted June 8, 2019 (edited) I set a 100x100 cm format without margins, but every time I print in pdf does it cut me off the edges, with other formats does it not happen . i attach the pc3 and pmp files . my model of sheet is MANUALI 100x100 thanks 000.pdf Adobe PDF_.pc3 Adobe PDF_.pmp Edited June 8, 2019 by jim78b Quote
SLW210 Posted June 10, 2019 Posted June 10, 2019 You will probably need to select a FULL BLEED paper size. Quote
Steven P Posted June 17, 2019 Posted June 17, 2019 I modified some of the paper sizes to suit (I uses An Expand paper because I don't otherwise use the)... Go to page setup, select Dwg to PDF plotter and then properties Under 'Use-Defined Paper Sizes and Calibration' choose modify Standard Paper Sizes (though you can also go and create a Custom paper Size), and then choose the paper size in the box below, click modify and there you can set the margins, mine are set at 0. Click finish and then repeat for all the paper sies. I used the standard paper sizes since I use a plotting list - and it is easier to use if I use a standard paper size. Then when it comes to plotting, just choose your modified paper size 1 Quote
tombu Posted July 1, 2019 Posted July 1, 2019 Steven P's method is probably the best. I plot to paper with a page setup set to Layout and to PDF with a page setup set to Extents with "Center the plot" checked. Not exactly the same, but close enough. 1 Quote
Steven P Posted July 1, 2019 Posted July 1, 2019 1 hour ago, tombu said: Steven P's method is probably the best. I plot to paper with a page setup set to Layout and to PDF with a page setup set to Extents with "Center the plot" checked. Not exactly the same, but close enough. I never thought of that, I'll have a look for myself and see if that works for me 1 Quote
