Oscar Posted June 7, 2019 Posted June 7, 2019 I am cleaning up a survey file and here are tons of unwanted layers Quote
ammobake Posted June 7, 2019 Posted June 7, 2019 use PURGE command, click Purge all. usually that's enough. But you might have nested layers it just depends whats referenced (if anything). Sometimes it's necessary to purge layers from other drawings too. For example, if you have 20 unused layers in a block you might not be able to purge the layer even though nothing in your drawing is on that layer. With hundreds of layers it can get pretty complicated if you're using blocks and XREF's, dynamic blocks, etc.. But usually not a huge deal. ChriS Quote
steven-g Posted June 8, 2019 Posted June 8, 2019 If the layers are used, and you just have too many! then maybe the layer merge command could help. Quote
BIGAL Posted June 9, 2019 Posted June 9, 2019 if you are using Civ3D you can not just purge layers they will remain do purgestyles 1st then purge. 200 down to 20. 2 Quote
