K Baden Posted June 7, 2019 Posted June 7, 2019 (edited) Good morning! I am hoping someone has something laying around that can help. I need a specific incremental text that is pretty simple. I basically would like for something at does the following on each click: A1 A2 A3 etc.. but i want to be able to key in something while using to reset the number increment and change the letter to the next letter like so: A1 A2 A3 (*some sort of way to indicate i am ready to reset the number and increment the letter here*) B1 B2 B3 (*some sort of way to indicate i am ready to reset the number and increment the letter here*) C1 C2 C3 etc.. I know Lee MAc has the awesome numbering suite and I have attempted to try and grab pieces of it... but my LISP skills are way too rusty for that to have any success. I really just want something much smaller to accomplish this as this is the only incremental thing i will ever need to do. Does anyone have any idea how i would accomplish this? (PS, the text style will be ROMANS and a text height of 3/32" on layer TEXT, if that makes any difference) Thanks in advance for any help!!! Edited June 7, 2019 by K Baden Quote
Lee Mac Posted June 7, 2019 Posted June 7, 2019 Here is a very basic example: (defun c:inc ( / *error* alp ang hgt ins lay num ocs sty ) (defun *error* ( msg ) (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) (princ (strcat "\nError: " msg)) ) (princ) ) (setq sty (getvar 'textstyle) ;; Text Style hgt (getvar 'textsize) ;; Text Height lay (getvar 'clayer) ;; Text Layer ocs (trans '(0 0 1) 1 0 t) ang (angle '(0 0) (trans (getvar 'ucsxdir) 0 ocs t)) ) (if (not inc:alp) (setq inc:alp "A")) (if (not inc:num) (setq inc:num 1)) (if (not (tblsearch "style" sty)) (setq sty (getvar 'textstyle))) (while (not (or (= "" (setq alp (strcase (getstring (strcat "\nSpecify alpha prefix <" inc:alp ">: "))))) (wcmatch alp "~*[~A-Z]*") ) ) (princ "\nPrefix may only contain the characters A-Z.") ) (if (= "" alp) (setq alp inc:alp) (setq inc:alp alp) ) (initget 4) (if (setq num (getint (strcat "\nSpecify numerical suffix <" (itoa inc:num) ">: "))) (setq inc:num num) (setq num inc:num) ) (while (progn (initget "Prefix Suffix") (setq ins (getpoint (strcat "\rSpecify point for " alp (itoa num) " [Prefix/Suffix] <exit>: "))) ) (cond ( (= "Prefix" ins) (setq alp (LM:alpha++ alp) num 1)) ( (= "Suffix" ins) (setq num (1+ num))) ( (entmake (list '(000 . "TEXT") (cons 008 lay) (cons 007 sty) (cons 040 hgt) (cons 050 ang) (cons 010 (trans ins 1 ocs)) (cons 001 (strcat alp (itoa num))) (cons 210 ocs) ) ) (setq num (1+ num)) ) ) ) (princ) ) ;; Alpha++ - Lee Mac ;; Increments an uppercase alphabetical string by one, e.g. AZ => BA ;; a - [str] uppercase alphabetical string (defun LM:alpha++ ( a / n ) (if (= "" a) "A" (if (= "Z" (substr a (setq n (strlen a)))) (strcat (LM:alpha++ (substr a 1 (1- n))) "A") (strcat (substr a 1 (1- n)) (chr (1+ (ascii (substr a n))))) ) ) ) (princ) Quote
K Baden Posted June 10, 2019 Author Posted June 10, 2019 This is perfect! Thank you so much for the help. One additional question, can i change it to MTEXT jsut by updating it in the code to MTEXT here? '(000 . "TEXT") And are any of these properties able to update th justification to middle Center? if not, how would i add that into the specifications of properties? Thank you again!!! Quote
Lee Mac Posted June 10, 2019 Posted June 10, 2019 2 hours ago, K Baden said: This is perfect! Thank you so much for the help. You're welcome. 2 hours ago, K Baden said: One additional question, can i change it to MTEXT jsut by updating it in the code to MTEXT here? '(000 . "TEXT") No, MTEXT DXF data requires you to specify the sub class markers AcDbEntity & AcDbMText (DXF group 100). 2 hours ago, K Baden said: And are any of these properties able to update th justification to middle Center? if not, how would i add that into the specifications of properties? Yes - for TEXT the justification is represented using DXF groups 72 & 73; for MTEXT, it is represented using DXF group 71. Therefore, for middle-center justified MText, replace the first entry in the DXF data: '(000 . "TEXT") With: '(000 . "MTEXT") '(100 . "AcDbEntity") '(100 . "AcDbMText") '(071 . 5) Quote
K Baden Posted June 11, 2019 Author Posted June 11, 2019 This is perfect. thank you so much, Lee! Quote
Lee Mac Posted June 11, 2019 Posted June 11, 2019 1 hour ago, K Baden said: This is perfect. thank you so much, Lee! You're welcome! Quote
