Cut tool not working in ortographic side views.
Hello everyone,
I've already checked the web, as well as the reddit page. The only similar problem with solution I found ended up not working for me, which was to change view with the side bar rather than the cube.
My issue is simple. I'm trying to cut a plane while looking at it from the left in ortographic realistic view. If I look at it at an angle I can cut it any way I want, as well as in perspective mode. But directly from the left and the cut tool seems to either start from a vertice at the bottom of the plane, from the centerpoint of the grid, or from the middle of one of the edges. However it still won't cut, it just seems to imply that I'm able to.
