I have a receptacle block which includes a note and circuit attribute. i recently went into Block Editor and decreased the size of the attribute text, using the properties. I saved the block and exited. For some reason my blocks in my drawing have not changed text size? What gives? Is there a certain way that i have to change text size for existing attributes? The text changed size within the Block Editor so i assume not.
The ATTSYNC command may help you...
  • 2 years later...
man i spent an hour tryn to redefine. good lookn out G
I see a happy man! Welcome in the forum, Suka4luv!
And also congrats for Nscherneck: a well named thread can help others having similar problems.
If ATTSYNC doesn't work you could also try BATTMAN (not the superhero! :) ) this saved me alot of time with stuborn attributes.
