Hi.  I have a lisp routine that I use all the time but I'm wondering if someone could please tell me how the routine sets the following variables:
1. The number of decimal places (precision) that the distance displays at.  It currently displays it to 2 decimal places, I'd like to have 3 eg. 0.000
2. The text offset distance from the line.
Thank you all in advance!  ðŸ˜Š
(defun get_endpts (/ a b)
     (COMMAND "OSNAP" "ENDP")
     (setq a (getpoint "\nEnter first point: "))
     (setq b (getpoint "\nEnter second point: "))
     (COMMAND "OSNAP" "NONE")
     (list a b)
(defun c:setdim ()
   ;(initget (+ 1 2 4))
   ;(setq scalefactor (getreal "\nEnter scale factor: "))
   (if (not setmap)
       (load "setmap")
   (setmap)
   (setq scalefactor #mapsc)
   ;(initget 1 "Y y N n")
   ;(setq angflg (question "Do you want azimuths printed?"))
   (setq angflg "Y" angmessage "WILL")
   ;(cond (angflg
   ;      (if (not (setq dimrotation (getangle "\nEnter angular rotation: ")))
   ;          ;(setq dimrotation #mapang )
   ;    (setq DIMROTATION 0)
   ;      (initget 1 "1 5")
   ;      (setq secprec (atoi (getkword "\nRound off seconds to nearest <1 or 5> ")))
   (setq dimrotation 0 secprec 5 secsmessage "5")
   (alert (strcat "DIMLINE SETTINGS: \n\nScale Factor set to: " (rtos scalefactor 2 6) "\nAzimuths " angmessage " print." "\nSeconds rounded off to " secsmessage "\""
           "\n\n\nTo change the Scale Factor use MAP SETTINGS CSF \+ ROTATION \non the LISP pulldown.\n\nTo change other settings type SETDIM2."))
   (setq dimset T)
   ;(chgsize (* (/ scalex 1000) 1.95))
);defun setdim
(defun c:setdim2 ()
   (initget (+ 1 2 4))
   (if (not setmap)
          (load "setmap")
   (if angflg
         (setq DIMROTATION 0 angMessage "WILL")
             (initget 1 "1 5")
             (setq secsMessage (getkword "\nRound off seconds to nearest <1 or 5> "))
             (setq secprec (atoi secsmessage))
         (setq angMessage "WON'T" )
           "\n\n\nTo change the Scale Factor use MAP SETTINGS CSF \+ ROTATION \non the LISP pulldown."))
   (setq dimset T)
(defun c:dimline (/ L A B ucsflg)
     (load "F1")
     (cond ((not dimset) (c:setdim)))
     (if (/=(getvar "WORLDUCS") 1)
                 (command "UCS" "W")
                 (setq UCSflg T)
             );progn
     );if
     (setq L (getline))
     (dimfunc (getassoc 10 L) (getassoc 11 L)
              (placetxt (getassoc 10 L) (getassoc 11 L))
     (if UCSflg
           (COMMAND "UCS" "P")
(defun c:dimpts (/ ENDPTS ucsflg)
     (load "F1")
                  (command "UCS" "W")
                  (setq UCSflg T)
              );progn
     );if
     (dimfunc (car(setq ENDPTS(get_endpts))) (cadr ENDPTS)
              (placetxt (car ENDPTS)(cadr ENDPTS))
     (if UCSflg
                (COMMAND "UCS" "P")
(defun dimfunc (a b below / angab distab ctrpt d)
     (setq angab (angle a b))
     (setq distab (distance a b))
     (setq ctrpt (polar a angab (/ distab 2)))
     (setq d  (/ distab scalefactor))
     (cond
       (below
          (cond
             ((and (> angab (+ NORTH 0.1744)) (<= angab (+ SOUTH 0.1744)))
                (writedim d angab ctrpt (+ angab A90) (- angab PI) 1.20 2.85)
             (T (writedim d angab ctrpt (+ angab A270) angab 1.20 2.85))
       (T (cond
                (writedim d angab ctrpt (+ angab A270) (- angab PI) 1.20 2.85)
             (T (writedim d angab ctrpt (+ angab A90) angab 1.20 2.85))
(defun writedim (d azimuth ctrpt perpang orientation sp1 sp2 / textpt scalept)
     ;(switchl "DIMENSION")
     (setq textpt (polar ctrpt perpang (* (getxtht) sp1)))
     (setq scalePt ctrpt)
     (COMMAND "TEXT" "M" textpt  (angtos orientation)  (rtos d 2 2))
     (cond (angflg
        (setq textpt (polar ctrpt perpang (* (getxtht) sp2)))
                      (writeang (+ angab (dtr dimrotation)))
     (if (= (substr (getvar "CLAYER") 1 2) "34")
             (findDetailScale)
             (if (and (/= nil detTxtScl)(/= 0.0 detTxtScl))
                 (command "SCALE" (lastn 2) "" scalept detTxtscl)
                 (command "SCALE" (lastn 2) "" scalept theRatio)
    ; (switchl nil)
(defun findDetailScale ( / detLayer detLen det7thLast undScr)
    (if (not c:lastn)
        (load "LASTN")
    (if (null theRatio)
            (load "labelling")
            (c:detail)
    (setq detLayer (getvar "CLAYER"))
    (setq detlen (strlen detLayer))
    (setq det7thLast (substr detLayer (- detLen 6)))
    (setq undScr (st_scan "_" det7thlast))
    (setq detTxtScl  (/ (* 0.001 (atoi (substr det7thLast (+ 1 undScr)))) plscale))
(defun writeang (azimuth)
  (setq azimuth (angtos azimuth 1 4))
  (if (= "d" (substr azimuth 3 1))
      (strcat (deg_format azimuth 3))
      (if (= "d" (substr azimuth 4 1))
          (strcat (deg_format azimuth 4))
          (strcat (deg_format azimuth 2))
  (cond ((= 5 secprec)
           (cond
              ((< 7 (last_digit seconds))
                 (setq seconds (additostr seconds (- 10 (last_digit seconds))))
              ((< 2 (last_digit seconds))
                 (setq seconds (additostr seconds (- 5 (last_digit seconds))))
              (T (setq seconds (additostr seconds (- 0 (last_digit seconds)))))
           (if (= (strlen seconds) 1) (setq seconds (strcat "0" seconds)))
           (if (= "60" seconds) (progn
               (setq seconds "00")
               (setq minutes (additostr minutes 1))
               (if (= (strlen minutes) 1) (setq minutes (strcat "0" minutes)))
               (if (= "60" minutes) (progn
                   (setq minutes "00")
                   (setq degrees (additostr degrees 1))
  (if (/= (strcase (getvar "LOGINNAME")) "Pam.hvizdos")
      (strcat degrees "%%d" minutes "'" seconds "\"")
(defun deg_format ( str pos)
    (setq degrees (substr str 1 (- pos 1)))
    (min_format (substr str (+ pos 1)))
 (defun min_format (str)
    (setq minutes (cond ((= "'" (substr str 2 1))
                         (sec_format (substr str 3))
                         (strcat"0" (substr str 1 1))
                        (T (sec_format (substr str 4))
                           (substr str 1 2)
(defun sec_format (str)
    (setq seconds (substr (if ( = 2 (strlen str))
                              (strcat "0" str)
                              str
                          1 2
(defun last_digit(str)
   (atoi (substr str (strlen str)))
(defun additostr(str no)
       (itoa (+ (atoi str) no))
1 look at help for lisp commands and the rtos function regrading decimal palces, also atof and atoi, I have some www links need to add to my new pc.
Its a lot of code to wade through but a guess try changing (/ distab 2) to (/ distab 1.5) if it moves text away then you are on the right path.
Edited by BIGAL
Thanks BIGAL!  I'll get started on your suggestions and let you know how I make out.
Changed (rtos d 2 2) to (rtos d 2 3) solved my precision issue.  Thanks!
Glad you found it better to understand the rtos options than just give 2 3 .
