i want a lisp to set property color to bylayer through command line example digit :bl (bylayer)and bk (byblock)
and for linetype i want digit for bylayer lb and for byblock lk is possible? thanks
Your request is kind of vague, but give this quickie a try. Does not do nested items.
(defun _foo (c / s)
  (if (setq s (ssget ":L"))
    (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
      (entmod (append (entget e) (list (cons 62 c))))
(defun c:bl nil (_foo 256))
(defun c:bk nil (_foo 0))
(setq a 0)
;; Create c:b1 thru c:b255 for $h!+s :)
(repeat 255 (eval (read (strcat "(defun c:b" (itoa (setq a (1+ a))) " nil (_foo " (itoa a) "))"))))
Edited by ronjonp
(defun C:CBL () (COMMAND "CHANGE" PAUSE "" "P" "C" "BYLAYER" "")
(PROMPT "nCOLOR CHANGED TO BYLAYER."))
(defun C:LTBL () (COMMAND "CHANGE" PAUSE "" "P" "LT" "BYLAYER" "")
(PROMPT "nLINETYPE CHANGED TO BYLAYER."))
(defun C:PS ()       ;Pick entity to set layer
    (setvar "CMDECHO" 0)
    (setq EN (car (entsel "\nPick any entity to set the layer..: ")))
    (setq ED (entget EN))
    (setq LN (cdr (assoc 8 ED )))
    (command "LAYER" "S" LN "")
Edited by Jman
Explain more guesses are being made. Have not transferred the crystal ball to my new laptop yet.
(defun _foo (c / s)
(setq a 0)
i want only  when i write bk or bl the state of color or layer change in byblock or bylayer and not select an object ...
What I use:
(defun c:bys nil
  (mapcar 'setvar '(CECOLOR CELTYPE CELWEIGHT) '("BYLAYER" "BYLAYER" -1))
  (vl-cmdf "_.regen")
  ) (vl-load-com)
As Tharwat eluded to:
(defun c:bl nil (setvar 'cecolor "ByLayer"))
(defun c:bk nil (setvar 'cecolor "ByBlock"))
That works
Edited by Jman
you are the best very thanks!! i make another lisp for linetype:
(defun c:ll nil (setvar 'celtype "ByLayer"))
(defun c:lk nil (setvar 'celtype "ByBlock"))
thanks! to everyone
HELLO your code is ok but i need a modify please, when i select multiple object that are set on bylayer and type the command example bk the object not change to byblock...
I'm confused. 🤔
The code above does not do anything to existing objects. It changes the 'cecolor' variable so that new items added to the drawing will take on either bylayer or byblock properties depending on which you run.
SORRY can you even  make that do that?!
Already wrote that HERE. As stated before does not do nested items.
Quote
sorry but I want that when I have an element selected from the keyboard I type for example bk or bl and the type of color or line changes
Sorry, I cannot help you.
jim78b
   i wrote my 2 lisp routines to change existing lines that people changed the color or line type but not the layer . it put them on the correct color or line type for the
  layer you want to use.
  I threw in pick set just for fun.  I use those lisp routines daily. It doesn't change everything globally
