robertbon Posted May 15, 2019 Posted May 15, 2019 I've got a dwg that contains lots (hundreds) of 3D polylines. What I need is to get each individual 3D polyline in its own dwg file? These can be called 1.dwg, 2.dwg, 3.dwg, etc. Can anyone help me with a LISP routine to acheive this? It is way beyond my capabilities! Quote
dlanorh Posted May 15, 2019 Posted May 15, 2019 Try this, it should work without overloading the number of selection sets. (vl-load-com) (defun c:WBP ( / c_doc o_arr ss o_lst cnt fname) (setq c_doc (vla-get-activedocument (vlax-get-acad-object)) o_arr (vlax-make-safearray vlax-vbobject '(0 . 0)) ss (ssget "_X" '((0 . "POLYLINE") (-4 . "&=") (70 . 8))) );end_setq (repeat (setq cnt (sslength ss)) (setq o_lst (cons (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt)))) o_lst)) );end_repeat (setq cnt 0) (foreach obj o_lst (setq sso (vla-add (vla-get-selectionsets c_doc) "PLO") fname (strcat (getvar 'dwgprefix) (itoa cnt) ".dwg") );end_setq (vlax-safearray-put-element o_arr 0 obj) (vla-additems sso o_arr) (vla-wblock c_doc fname sso) (vla-delete sso) (setq cnt (1+ cnt)) );end_foreach );end_defun It will write each individual 3DPolyline into the same directory as the drawing. The drawing names will start with "0" (zero) then "1" etc until (hopefully) all have been wblocked. It doesn't delete the original polylines from the drawing, but that is a possiblity. Quote
BIGAL Posted May 16, 2019 Posted May 16, 2019 dlanorh you write good answers it looks to me that your over complicating it by making extra lists, why not just take the ss which is a 3d polyline selection and jump straight to wblock with correct filename. not tested no cad (repeat (setq cnt (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt))))) (setq fname (strcat (getvar 'dwgprefix) (itoa cnt) ".dwg") (vla-wblock c_doc fname obj) );end_repeat Quote
dlanorh Posted May 16, 2019 Posted May 16, 2019 6 hours ago, BIGAL said: dlanorh you write good answers it looks to me that your over complicating it by making extra lists, why not just take the ss which is a 3d polyline selection and jump straight to wblock with correct filename. not tested no cad (repeat (setq cnt (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt))))) (setq fname (strcat (getvar 'dwgprefix) (itoa cnt) ".dwg") (vla-wblock c_doc fname obj) );end_repeat vla-wblock requires a selectionset (safearray of objects) to be passed. I didn't want to attempt handling a selectionset whilst iterating a different selectionset. I've not tested vlax-invoke using an object or list etc so this may be possible. Quote
BIGAL Posted May 17, 2019 Posted May 17, 2019 Thanks for reply wblock is one of those things that is a pain command to do easily. I tried this (setq ss (ssget "_X" '((0 . "POLYLINE") (-4 . "&=") (70 . 8)))) (setq x 0) (repeat (sslength ss) (command "_.-wblock" (strcat (getvar 'dwgprefix) (itoa x) ".dwg") "" (list 0 0) (ssname ss x) "" ) (setq x (+ x 1)) ) 1 Quote
