b2b2 Posted May 11, 2019 Posted May 11, 2019 Hi all, i have small problem i am new in VBA and i am trying to write easy script in excel vba... i want to make a polyline from points i use this syntax, i cant find mistake but when i run macro it show me error 91 Can someone help me, thanks a lot Sub pline() Dim plineObj As AcadLWPolyline Dim Points(0 To 15) As Double Dim AcadDwg As AcadDocument 'Define the polyline Coordinates XY, XY, XY ..... Points(0) = 0: Points(1) = 0 Points(2) = 1: Points(3) = 1 Points(4) = 5: Points(5) = 3 Points(6) = 4: Points(7) = 6 Points(8) = 8: Points(9) = 8 Points(10) = 20: Points(11) = 0 Points(12) = 25: Points(13) = 5 Points(14) = 100: Points(15) = 100 ' Create a lightweight Polyline object in model space Set plineObj = AcadDwg.ModelSpace.AddLightWeightPolyline(Points) End Sub Quote
BIGAL Posted May 12, 2019 Posted May 12, 2019 A google revealed a subtle difference, Works now. Just a comment if your going to make a sub pline then it would be better to make the number of points non fixed and pass to the function X & Y & Z as required. Note requires a minimum of 2 points. I do most in lisp so sorry. Set plineObj = AcadDwg.ModelSpace.AddLightWeightPolyline(Points) try Set plineObj = Thisdrawing.ModelSpace.AddLightWeightPolyline(Points) Quote
