Please Help error: extra right paren on input
Hello Dear All,
I really need that lisp but no idea how to fix that script! Can anyone tell me where is the problem in that script please? I cant even find command name! :(
Thank you & Best Regards
Original Script Spot: https://adndevblog.typepad.com/autocad/2014/03/extracting-isolines-from-surface.html
// 1) Enable support for the BRep API in StdAfx.h
#define _BREP_SUPPORT_            //- Support for the BRep API
// 2) Code to retrieve the IsoLines from a surface
Acad::ErrorStatus es;
ads_point pt;
ads_name ename;
if (RTNORM != acedEntSel(L"Select a Surface", ename, pt))
    return;
AcDbEntity *pEnt = NULL;
AcDbObjectId id;
es = acdbGetObjectId(id, ename);
es = acdbOpenAcDbEntity(pEnt, id, AcDb::kForWrite);
AcDbSurface *pSurface = AcDbSurface::cast(pEnt);
if(NULL == pSurface)
    acutPrintf(ACRX_T("\nPlease select a surface."));
    return;
AcDbNurbSurfaceArray nsArray;
es = pSurface->convertToNurbSurface(nsArray);
if(es == Acad::eOk)
    if(nsArray.length() == 1)
        AcDbDatabase *pDb
            = acdbHostApplicationServices()->workingDatabase();
        AcDbBlockTable *pBlockTable = NULL;
        es = pDb->getBlockTable(pBlockTable, AcDb::kForRead);
        AcDbBlockTableRecord *pMS = NULL;
        es = pBlockTable->getAt(
                       ACDB_MODEL_SPACE, pMS, AcDb::kForWrite);
        AcDbNurbSurface *pNS = NULL;
        pNS = AcDbNurbSurface::cast(nsArray.at(0));
        Adesk::UInt16 uIsoDensity = pSurface->uIsolineDensity();
        Adesk::UInt16 vIsoDensity = pSurface->vIsolineDensity();
        AcDbBody* pBody = new AcDbBody();
        es = pBody->setASMBody(pSurface->getLockedASMBody());
        AcBr::ErrorStatus ebs;
        AcBrBrep* pBrep = new AcBrBrep();
        ebs = pBrep->set(*pBody);
        if(AcBr::eOk == ebs)
            AcBrBrepFaceTraverser* pFaceTrav
                                = new AcBrBrepFaceTraverser;
            ebs = pFaceTrav->setBrep(*pBrep);
                for(pFaceTrav->restart();
                        !pFaceTrav->done();pFaceTrav->next())
                    AcBrFace face;
                    ebs = pFaceTrav->getFace(face);
                        AcGeSurface *pGeSurface;
                        ebs = face.getSurface(pGeSurface);
                        Adesk::Boolean isClosedInU
                                  = pGeSurface->isClosedInU();
                        Adesk::Boolean isClosedInV
                                  = pGeSurface->isClosedInV();
                        int ucMax = uIsoDensity+2;
                        if(isClosedInU)
                            ucMax = uIsoDensity;
                        int vcMax = vIsoDensity+2;
                        if(isClosedInV)
                            vcMax = vIsoDensity;
                        AcGeInterval intervalU, intervalV;
                        pGeSurface->getEnvelope
                                       (intervalU, intervalV);
                        double boundMinU = 0.0,
                               boundMaxU = 0.0,
                               boundMinV = 0.0,
                               boundMaxV = 0.0;
                        intervalU.getBounds
                                       (boundMinU, boundMaxU);
                        intervalV.getBounds
                                       (boundMinV, boundMaxV);
                        double paramIncrU =
                        (boundMaxU - boundMinU) /
                        (isClosedInU ? uIsoDensity :
                                       (uIsoDensity+1));
                        double paramIncrV =
                        (boundMaxV - boundMinV) /
                        (isClosedInV ? vIsoDensity :
                                       (vIsoDensity+1));
                        double paramU = boundMinU;
                        for(int uc = 0; uc < ucMax; uc++)
                            double paramV = boundMinV;
                            for(int vc = 0; vc < vcMax; vc++)
                                AcArray<AcDbCurve*> uIsoLines;
                                es = pNS->getIsolineAtU(
                                           paramU, uIsoLines);
                                if(es == Acad::eOk)
                                    for(int cnt = 0;
                                        cnt < uIsoLines.length();
                                        cnt++)
                                        AcDbCurve *pCurve
                                            = uIsoLines[cnt];
                                        pCurve->setColorIndex(1);
                                        pMS->appendAcDbEntity
                                                     (pCurve);
                                        pCurve->close();
                                AcArray<AcDbCurve*> vIsoLines;
                                es = pNS->getIsolineAtV(
                                           paramV, vIsoLines);
                                if(es == Acad::eOk)
                                    for(int cnt = 0;
                                        cnt < vIsoLines.length();
                                        cnt++)
                                        AcDbCurve *pCurve
                                             = vIsoLines[cnt];
                                                     (pCurve);
                                        pCurve->close();
                                paramV += paramIncrV;
                            paramU += paramIncrU;
                    else
                        acutPrintf(
                              ACRX_T("\nSorry, BRep error."));
                        break;
            else
                acutPrintf(ACRX_T("\nSorry, BRep error."));
            delete pFaceTrav;
        else
        delete pBrep;
        es = pMS->close();
        es = pBlockTable->close();
    else
        acutPrintf(ACRX_T("\nSorry, this code cannot handle
                               multiple Nurb surfaces yet."));
    // Cleanup
    for(int cnt = 0; cnt < nsArray.length(); cnt++)
        pNS = AcDbNurbSurface::cast(nsArray.at(cnt));
        if(pNS != NULL)
            delete pNS;
else
    acutPrintf(
        ACRX_T("\nSorry, could not convert to Nurb surface."));
pSurface->close();
