GregGleason Posted April 24, 2019 Posted April 24, 2019 (edited) I want to add text to an existing MTEXT, but the utility I have used doesn't support what I am trying to do. I can select it fine, but it doesn't come out right. This is the old format: This is the new format (this is what is desired): This is the old text in properties: This is the new text in properties (this is what is desired): I tried to use this code to call a MRWA.lsp (but the format doesn't work right): (setq mylisp "MRWA.lsp") ; Set the lisp routine name (setq mypatlsp (strcat mypath mylisp)) ; Set the path/file of the lisp routine name (load mypatlsp) ; Load the lisp routine (replace "INSPECTION AND WELDING." "INSPECTION AND WELDING. NORTH IS BASED ON PLANT NOTRTH PER DWG 123-KD-401.") ; Replace MTEXT string: old/new Using this lisp (MRWA.lsp): (defun replace (old new / string_subst dxf idx o ss) (defun string_subst (str old new / idx) (setq idx 0) (while (setq idx (vl-string-search old str idx)) (setq str (vl-string-subst new old str idx)) (setq idx (+ idx (strlen new))) ) str ) (if (setq ss (ssget "_X" (list '(0 . "MTEXT") (cons 410 (getvar 'ctab))))) (repeat (setq idx (sslength ss)) (setq o (vlax-ename->vla-object (ssname ss (setq idx (1- idx))))) (if (vl-string-search old (vla-get-textstring o)) (vla-put-textstring o (string_subst (vla-get-textstring o) old new)) ) ) ) (princ) ) Am I just a few characters off to get this to work right? Or do I need to take another path to make this work? Greg Edited April 24, 2019 by GregGleason Quote
ronjonp Posted April 24, 2019 Posted April 24, 2019 On 4/24/2019 at 8:01 PM, GregGleason said: (vla-put-textstring o (string_subst (vla-get-textstring o) old new)) You never define what 'new' is? Quote
GregGleason Posted April 24, 2019 Author Posted April 24, 2019 This is the "new" text in yellow (with a couple of carriage returns). Greg Quote
