handasa Posted April 22, 2019 Share Posted April 22, 2019 Hello Everyone i use to this lisp to change color of block's subentities . (defun colorb (x0 / doc blk) (setq col (cdr (assoc 62 (acad_truecolordlg 2)))) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (setq blk (vla-item (vla-get-blocks doc) (vla-get-Effectivename x0))) (vlax-for x blk (if (eq (vla-get-objectname x) "AcDbBlockReference") (progn (colorb x)) ; recursion (vla-put-color x col) ) ) ) it works well for regular blocks but in case of dynamic blocks the new color won't take effect until i use "bedit" command like this (defun update (block) (setq blockname (LM:al-effectivename block)) (COMMAND "-BEDIT" "" blockname) (command "zoom" "e") (COMMAND "_BCLOSE" "SAVE") ) any ideas to change dynamic block subentities without using the bedit command thanks in advance Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 22, 2019 Share Posted April 22, 2019 Hi, Replace the function vla-get-effectivename with vla-get-name and try again. Quote Link to comment Share on other sites More sharing options...
handasa Posted April 22, 2019 Author Share Posted April 22, 2019 (edited) 12 minutes ago, Tharwat said: Hi, Replace the function vla-get-effectivename with vla-get-name and try again. this didn't change the color of the block subentities Edited April 22, 2019 by handasa Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 22, 2019 Share Posted April 22, 2019 You may need to regen the active space / drawing to see the changes. Quote Link to comment Share on other sites More sharing options...
handasa Posted April 22, 2019 Author Share Posted April 22, 2019 Just now, Tharwat said: You may need to regen the active space / drawing to see the changes. regen didn't work also.the only way to have the changes take effect is to bedit the block and zoom inot it and exit the bedit Quote Link to comment Share on other sites More sharing options...
dlanorh Posted April 22, 2019 Share Posted April 22, 2019 (edited) 2 hours ago, handasa said: (defun update (block / blockname) (setq blockname (LM:al-effectivename block)) (vl-cmdf "_.attsync" "_N" blockname) ) Try the above Edited April 22, 2019 by dlanorh Quote Link to comment Share on other sites More sharing options...
handasa Posted April 22, 2019 Author Share Posted April 22, 2019 7 minutes ago, dlanorh said: Try the above block doesn't have attribute definitions.so this command gives error _N Unknown command "N" Quote Link to comment Share on other sites More sharing options...
dlanorh Posted April 22, 2019 Share Posted April 22, 2019 The only other way i can think of without opening the block editor is to ssget "_X" the blocks in the drawing, and iterate the pickset filtering blocks with the same effective name into a list. Then for each block in the list get ALL the dynamic block properties and values, use the resetblock command and then reinstate the saved dynamic block property values. Example functions to do this can be found HERE This is also worth a READ Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted April 23, 2019 Share Posted April 23, 2019 (edited) Strange that a block definition does not have an EffectiveName property. But with some 'classic' Lisp you can create a workaround. I also tried to fix some issues with the recursion. ; Blk can be a block name or the ename of a "BLOCK" entity. (defun KGA_BlockClassic_EffectiveName (blk / elst blkRecHnd) (setq elst (entget (if (= 'ename (type blk)) blk (tblobjname "block" blk))) ) (if (and (= "*" (substr (cdr (assoc 2 elst)) 1 1)) (setq blkRecHnd (cdr (assoc 1005 (cdadr (assoc -3 (entget (cdr (assoc 330 elst)) '("AcDbBlockRepBTag"))))))) ) (cdr (assoc 2 (entget (handent blkRecHnd)))) (cdr (assoc 2 elst)) ) ) ; (colorb (vla-get-name (vlax-ename->vla-object (car (entsel)))) (acad_colordlg 2)) (defun colorb (nme col / N_Mod blks i nmeLst) (defun N_Mod (blk) (vlax-for obj blk (if (and (= "AcDbBlockReference" (vla-get-objectname obj)) (not (vl-position (strcase (vla-get-effectivename obj)) nmeLst)) ) (setq nmeLst (append nmeLst (list (strcase (vla-get-effectivename obj))))) ; Append required. (vla-put-color obj col) ) ) ) (setq blks (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))) (setq nmeLst (list (strcase (KGA_BlockClassic_EffectiveName nme)))) (setq i 0) (while (< i (length nmeLst)) (setq nme (nth i nmeLst)) (vlax-for blk blks (if (= nme (strcase (KGA_BlockClassic_EffectiveName (vla-get-name blk)))) (N_Mod blk) ) ) (setq i (1+ i)) ) ) Edited April 23, 2019 by Roy_043 1 Quote Link to comment Share on other sites More sharing options...
handasa Posted April 23, 2019 Author Share Posted April 23, 2019 54 minutes ago, Roy_043 said: Strange that a block definition does not have an EffectiveName property. But with some 'classic' Lisp you can create a workaround. I also tried to fix some issues with the recursion. ; Blk can be a block name or the ename of a "BLOCK" entity. (defun KGA_BlockClassic_EffectiveName (blk / elst blkRecHnd) (setq elst (entget (if (= 'ename (type blk)) blk (tblobjname "block" blk))) ) (if (and (= "*" (substr (cdr (assoc 2 elst)) 1 1)) (setq blkRecHnd (cdr (assoc 1005 (cdadr (assoc -3 (entget (cdr (assoc 330 elst)) '("AcDbBlockRepBTag"))))))) ) (cdr (assoc 2 (entget (handent blkRecHnd)))) (cdr (assoc 2 elst)) ) ) ; (colorb (vla-get-name (vlax-ename->vla-object (car (entsel))))) (defun colorb (nme / N_Mod blks col i nmeLst) (defun N_Mod (blk) (vlax-for obj blk (if (and (= "AcDbBlockReference" (vla-get-objectname obj)) (not (vl-position (strcase (vla-get-effectivename obj)) nmeLst)) ) (setq nmeLst (append nmeLst (list (strcase (vla-get-effectivename obj))))) ; Append required. (vla-put-color obj col) ) ) ) (setq blks (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))) (setq col (acad_colordlg 2)) (setq nmeLst (list (strcase (KGA_BlockClassic_EffectiveName nme)))) (setq i 0) (while (< i (length nmeLst)) (setq nme (nth i nmeLst)) (vlax-for blk blks (if (= nme (strcase (KGA_BlockClassic_EffectiveName (vla-get-name blk)))) (N_Mod blk) ) ) (setq i (1+ i)) ) ) this is what happen when using the code above cadtt.mp4 Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted April 23, 2019 Share Posted April 23, 2019 Seems like a simple regen issue. Notice that the main function is not a command ('C:') function. I have renamed the main function and added an example of a command function: ; Blk can be a block name or the ename of a "BLOCK" entity. (defun KGA_BlockClassic_EffectiveName (blk / elst blkRecHnd) (setq elst (entget (if (= 'ename (type blk)) blk (tblobjname "block" blk))) ) (if (and (= "*" (substr (cdr (assoc 2 elst)) 1 1)) (setq blkRecHnd (cdr (assoc 1005 (cdadr (assoc -3 (entget (cdr (assoc 330 elst)) '("AcDbBlockRepBTag"))))))) ) (cdr (assoc 2 (entget (handent blkRecHnd)))) (cdr (assoc 2 elst)) ) ) ; (ChangeDynBlockColor (vla-get-name (vlax-ename->vla-object (car (entsel)))) (acad_colordlg 2)) (defun ChangeDynBlockColor (nme col / N_Mod blks i nmeLst) (defun N_Mod (blk) (vlax-for obj blk (if (and (= "AcDbBlockReference" (vla-get-objectname obj)) (not (vl-position (strcase (vla-get-effectivename obj)) nmeLst)) ) (setq nmeLst (append nmeLst (list (strcase (vla-get-effectivename obj))))) ; Append required. (vla-put-color obj col) ) ) ) (setq blks (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))) (setq nmeLst (list (strcase (KGA_BlockClassic_EffectiveName nme)))) (setq i 0) (while (< i (length nmeLst)) (setq nme (nth i nmeLst)) (vlax-for blk blks (if (= nme (strcase (KGA_BlockClassic_EffectiveName (vla-get-name blk)))) (N_Mod blk) ) ) (setq i (1+ i)) ) ) (defun c:Test ( / col doc enm obj) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-endundomark doc) (vla-startundomark doc) (if (and (setq enm (car (entsel))) (setq obj (vlax-ename->vla-object enm)) (= "AcDbBlockReference" (vla-get-objectname obj)) (setq col (acad_colordlg 2)) ) (progn (ChangeDynBlockColor (vla-get-name obj) col) (vla-regen doc acactiveviewport) ) ) (vla-endundomark doc) (princ) ) 2 Quote Link to comment Share on other sites More sharing options...
handasa Posted April 23, 2019 Author Share Posted April 23, 2019 29 minutes ago, Roy_043 said: Seems like a simple regen issue. Notice that the main function is not a command ('C:') function. I have renamed the main function and added an example of a command function: ; Blk can be a block name or the ename of a "BLOCK" entity. (defun KGA_BlockClassic_EffectiveName (blk / elst blkRecHnd) (setq elst (entget (if (= 'ename (type blk)) blk (tblobjname "block" blk))) ) (if (and (= "*" (substr (cdr (assoc 2 elst)) 1 1)) (setq blkRecHnd (cdr (assoc 1005 (cdadr (assoc -3 (entget (cdr (assoc 330 elst)) '("AcDbBlockRepBTag"))))))) ) (cdr (assoc 2 (entget (handent blkRecHnd)))) (cdr (assoc 2 elst)) ) ) ; (ChangeDynBlockColor (vla-get-name (vlax-ename->vla-object (car (entsel)))) (acad_colordlg 2)) (defun ChangeDynBlockColor (nme col / N_Mod blks i nmeLst) (defun N_Mod (blk) (vlax-for obj blk (if (and (= "AcDbBlockReference" (vla-get-objectname obj)) (not (vl-position (strcase (vla-get-effectivename obj)) nmeLst)) ) (setq nmeLst (append nmeLst (list (strcase (vla-get-effectivename obj))))) ; Append required. (vla-put-color obj col) ) ) ) (setq blks (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))) (setq nmeLst (list (strcase (KGA_BlockClassic_EffectiveName nme)))) (setq i 0) (while (< i (length nmeLst)) (setq nme (nth i nmeLst)) (vlax-for blk blks (if (= nme (strcase (KGA_BlockClassic_EffectiveName (vla-get-name blk)))) (N_Mod blk) ) ) (setq i (1+ i)) ) ) (defun c:Test ( / col doc enm obj) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-endundomark doc) (vla-startundomark doc) (if (and (setq enm (car (entsel))) (setq obj (vlax-ename->vla-object enm)) (= "AcDbBlockReference" (vla-get-objectname obj)) (setq col (acad_colordlg 2)) ) (progn (ChangeDynBlockColor (vla-get-name obj) col) (vla-regen doc acactiveviewport) ) ) (vla-endundomark doc) (princ) ) this worked fine..thank you very much ,Roy Quote Link to comment Share on other sites More sharing options...
rlx Posted April 23, 2019 Share Posted April 23, 2019 nice one Roy! Quote Link to comment Share on other sites More sharing options...
