rombi Posted April 20, 2019 Posted April 20, 2019 I found this lisp on this forum, and it is almost perfect for my use case. The one thing i would like it changed about it is that instead of asking for my input for a color, it changes it for a certain one that we set in the code. The thing i would like this code to do: after entering the command and selecting the objects, the color of the object changes right away, without asking for a any input. Appreciate your help in advance! (defun C:CHC (/ ColorObjects CurrColorOrg NewColor CmdEchoOrg) (prompt "\nSelect objects to color...") (cond ( (setq ColorObjects (ssget)) (setq CurrColorOrg (getvar 'CECOLOR) CmdEchoOrg (getvar 'CMDECHO) ) (setvar 'CMDECHO 0) (while (not (cond ( (initget 6) ) ( (setq NewColor (getint "\nEnter object color (1-255) <dialog>: " ) ) (if (< NewColor 256) (setvar 'CECOLOR (itoa NewColor))) ) (T(initdia) (command "_.COLOR") (numberp (read (getvar 'CECOLOR))) ) ) ) (prompt "\nCannot set color to that value.\n*Invalid.*") ) (command "_.CHANGE" ColorObjects "" "_P" "_C" (getvar 'CECOLOR) "") ) ) (setvar 'CECOLOR CurrColorOrg) (setvar 'CMDECHO CmdEchoOrg) (princ) ) Quote
dlanorh Posted April 20, 2019 Posted April 20, 2019 Try this : ;; Change Objects Color (vl-load-com) (defun C:COC (/ *error* cme c_doc ss clr obj cnt) (defun *error* ( msg ) (if cme (setvar 'cmdecho cme)) (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error occurred : " msg))) (princ) );end_defun *error* (cond ( (/= (getvar 'cmdecho) 0) (setq cme (getvar 'cmdecho)) (setvar 'cmdecho 0))) (prompt "\nSelect Objects to Color : ") (setq c_doc (vla-get-activedocument (vlax-get-acad-object)) clr 1 ;0 = Byblock , 256 = Bylayer ss (ssget) );end_setq (cond (ss (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (vla-startundomark c_doc) (repeat (setq cnt (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt))))) (if (vlax-property-available-p obj 'color T) (vlax-put-property obj 'color clr)) );end_repeat (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) ) );end_cond (if cme (setvar 'cmdecho cme)) (princ) );end_defun The hard coded integer color value is variable "clr" currently set to 1, and found in the first multi (setq) statement 1 Quote
rombi Posted April 20, 2019 Author Posted April 20, 2019 On 4/20/2019 at 2:31 PM, dlanorh said: Try this : ;; Change Objects Color (vl-load-com) (defun C:COC (/ *error* cme c_doc ss clr obj cnt) (defun *error* ( msg ) (if cme (setvar 'cmdecho cme)) (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error occurred : " msg))) (princ) );end_defun *error* (cond ( (/= (getvar 'cmdecho) 0) (setq cme (getvar 'cmdecho)) (setvar 'cmdecho 0))) (prompt "\nSelect Objects to Color : ") (setq c_doc (vla-get-activedocument (vlax-get-acad-object)) clr 1 ;0 = Byblock , 256 = Bylayer ss (ssget) );end_setq (cond (ss (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (vla-startundomark c_doc) (repeat (setq cnt (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt))))) (if (vlax-property-available-p obj 'color T) (vlax-put-property obj 'color clr)) );end_repeat (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) ) );end_cond (if cme (setvar 'cmdecho cme)) (princ) );end_defun Expand You are a legend! Works great! Wish i knew more about autolisp programming! Quote
dlanorh Posted April 20, 2019 Posted April 20, 2019 On 4/20/2019 at 2:52 PM, rombi said: Wish i knew more about autolisp programming! Expand Every journey starts with a single step. https://www.afralisp.net/index.php Quote
