dilan Posted April 19, 2019 Posted April 19, 2019 Hello. Trying to make a function that will return a list of coordinates of all selected cogo points. But I can not understand how to add to the list the coordinates of all points. The coordinate of only one point is added. Please help me understand. Thank. (defun cogo_list_coor ( / descr eastng idx northng pnt pntobj ss elev numb ) (vl-load-com) (if (setq ss (ssget '((0 . "AECC_COGO_POINT")))) (progn (setq idx -1) (while (setq pnt (ssname ss (setq idx (1+ idx)))) (setq pntobj (vlax-ename->vla-object pnt)) (setq descr (vlax-get pntobj 'fulldescription) numb (vlax-get pntobj 'Number) eastng (vlax-get pntobj 'easting) northng (vlax-get pntobj 'northing) elev (vlax-get pntobj 'Elevation) ) (list numb eastng northng elev) ); end of while ); end of progn ); end of if ); end of cogo_list_coor Quote
BIGAL Posted April 19, 2019 Posted April 19, 2019 Try this Command: (setq ss (ssget "X" '((0 . "AECC_COGO_POINT")))) <Selection set: 14> Command: (sslength ss) 686 Quote
dlanorh Posted April 19, 2019 Posted April 19, 2019 (edited) Is this what you are after? It returns a list of lists. You are also extracting the description but not using it. (defun cogo_list_coor ( / descr eastng idx northng pnt pntobj ss elev numb p_lst) (vl-load-com) (cond ( (setq ss (ssget '((0 . "AECC_COGO_POINT")))) (setq p_lst nil) (repeat (setq idx (sslength ss)) (setq pntobj (vlax-ename-vla-obj (ssname ss (setq idx (1- idx)))) descr (vlax-get pntobj 'fulldescription);;;;!!Why? Never Used numb (vlax-get pntobj 'Number) eastng (vlax-get pntobj 'easting) northng (vlax-get pntobj 'northing) elev (vlax-get pntobj 'Elevation) p_lst (cons (list numb eastng northng elev) p_lst) );end_setq );end_repeat ) );end_cond p_lst ); end of cogo_list_coor Edited April 19, 2019 by dlanorh 1 Quote
dilan Posted April 19, 2019 Author Posted April 19, 2019 (setq p_lst (cons (list numb eastng northng elev) p_lst)) Yes, I needed this line. thank dlanorh Quote
Lee Mac Posted April 27, 2019 Posted April 27, 2019 FWIW, rather than defining separate variables for each retrieved property, you can use a single mapcar expression to return the desired sublist: (defun cogo_list_coor ( / i l o s ) (if (setq s (ssget '((0 . "AECC_COGO_POINT")))) (repeat (setq i (sslength s)) (setq i (1- i) o (vlax-ename->vla-object (ssname s i)) l (cons (mapcar '(lambda ( p ) (vlax-get o p)) '(number easting northing elevation)) l) ) ) ) l ) 1 Quote
dilan Posted April 27, 2019 Author Posted April 27, 2019 4 hours ago, Lee Mac said: FWIW, rather than defining separate variables for each retrieved property, you can use a single mapcar expression to return the desired sublist: (defun cogo_list_coor ( / i l o s ) (if (setq s (ssget '((0 . "AECC_COGO_POINT")))) (repeat (setq i (sslength s)) (setq i (1- i) o (vlax-ename->vla-object (ssname s i)) l (cons (mapcar '(lambda ( p ) (vlax-get o p)) '(number easting northing elevation)) l) ) ) ) l ) thank Lee Quote
BIGAL Posted April 29, 2019 Posted April 29, 2019 Great idea as usual Lee often getting multiple details from an object using VL-get, can see it as a library defun passing list of item names, so not hard coded. Quote
