masterfal Posted April 18, 2019 Share Posted April 18, 2019 Hi All, I've used the lisp below to quickly add background masks to text but after an autocad update its stopped working. I'm getting this message when i try run it: no function definition: MASK:SELECTION Any ideas how i can fix? (defun c:mtm nil (mask:maskselection (mask:selection "\nSelect objects: ") t 1.1 t nil) (princ) ) Quote Link to comment Share on other sites More sharing options...
dlanorh Posted April 18, 2019 Share Posted April 18, 2019 Are the defined functions "mask:selection" and "mask:maskselection" loaded? 1 Quote Link to comment Share on other sites More sharing options...
tombu Posted April 18, 2019 Share Posted April 18, 2019 Looks like it's Lee Mac's code that isn't being loaded: http://www.lee-mac.com/mask.html 1 Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 27, 2019 Share Posted April 27, 2019 The two functions mask:selection & mask:maskselection are defined within the main program which may be downloaded using the link found here. The MaskV#-#.lsp program file will need to be loaded in the active drawing in order to define these two functions before your custom command can be evaluated. Quote Link to comment Share on other sites More sharing options...
