has anyone got this before? It happens when i click on the big red A in the corner. I can get around using that with the command bar, but when i forget i cant use it and hit it auto cad closes. any suggestions?
sp1 and sp2, is there a 3?
No.
It could be a .NET Framework related error. If you Google "e0434f4dh" and / or "7c812aebh" you'll find you're not the only one who has encountered this same error message over a few releases of AutoCAD.
Nothing at the AutoDesk website re: 7c812aebh.
I got sometimes happen like this !..May be error occur this file !
When i get this,copy and paste to new file!
This way is always good handling autocad error !ha..ha
thanks mark... I guess my afternoon will be uninstall reinstall, i hope that applies to vanilla autocad too since thats what I have.
I did not see a recommendation to uninstall / reinstall. Where are you seeing that?
Before that step I'd try a Repair but isn't the NET Framework idea worth investigating?
Are you running any other AutoDesk programs on this computer? If so, what are they (include the year)?
