bw_cad Posted April 15, 2019 Posted April 15, 2019 I'm importing point shapefiles into Map3D, that have attributes defining the BLOCKNAME, BLOCK ROTATION and BLOCK SIZE. I can use the mapimport dialog box to create the blocks using the BLOCKNAME, but is there a way to get it to use the rotation and size information too? Really appreciate any help/advice. Quote
SLW210 Posted April 15, 2019 Posted April 15, 2019 I have moved your thread to the Map 3D Forum. Quote
tombu Posted April 17, 2019 Posted April 17, 2019 For the shapefiles we use tbl1 (car (ade_odgettables EN)) ;First_Table_Assigned_to_Object where EN is entity name (car (ade_odgettables EN)) ;First_Table_Assigned_to_Object (ade_odgetfield EN TBL1 "ELEV" 0) ;the object data for the elevation is ELEV There's no standards that I know of and our GIS folk change both the attributes and their names from time to time forcing me to modify my code. You're going to have to figure out the table and attribute structure to code it yourself. Lot of cool stuff you can do with it once you figure it out. Quote
bw_cad Posted April 22, 2019 Author Posted April 22, 2019 Thanks for your response; I figured there would be a way in lisp...I'm just not up to the challenge of writing the script! I understand the GIS tables and how all my attributes are defined and what I need to use to get my outcome, but not how to program it. I will have to get help with that... thanks again. Quote
BIGAL Posted April 22, 2019 Posted April 22, 2019 A slightly different way use this at times with attributes, you shouldbe able to get the "count" of the objdata fields you can then just loop through and create a variable for each field getting its name and value. Need a dwg to check. For normal block its get-attributes then a foreach to open each attribute then you can get all the stuff inside, insertpoint, text rotation etc. not tested (setq EN (car (entsel "Pick object data")) (setq tbl1 (car (ade_odgettables EN)) ;First_Table_Assigned_to_Object where EN is entity name (foreach fld (car (ade_odgettables EN)) (vlax-dump-object fld) ) Quote
