Hi
i have a drawing with 36 layouts,
it takes a long time to generate them
i have "cache all layouts" on
it takes an average of 25 seconds to generate each layout for the first time
is there a way to automate the first regeneration of all laouts at once?
, Thanks
S
Not.
You can turn off all viewports, then there will be a quick switch between tabs.
If you need to edit the desired viewport - just turn it on only.
How can you work in all 36 layouts ? I had 88 layouts 1 dwg, ok so if I was making some new ones thay were empty then I added details. If I needed to do edits went directly to correct one.
I guess what I am saying is why would you step through all 36 ? Just go to the one you want thats why I wrote GOTO.lsp just type 99 go to last layout tab
goto-layout.lspFetching info...
Simple, just never set Layout Regen Options to "Cache model all layouts".
My PC hardware is rather weak though, had to do a layout with 40 viewports for a special project that took over 20 minutes to generate.
  • 2 years later...
Dont ever put dashed line as the deafult line of viewport, it made me mad. Took so long to generate.
Best wishes!
Suvad
