Copy text from layer1 to layer2
BKRao
Hello everybody,
Can anyone help me my requirement,
I want text copy from "layer1" to "layer2"
requesting for code
With regards.
BKRao
1   You can manually type lisp code on the command line so you can use ssget to make a selection, and then use Copy etc. (ssget '((0 . "Text")))
2   The Filter command is the same just select text then it detects the selection made.
3   Qselect ?
4  You can make a shorthand using the ssget mentioned aboved so Copy 'ssgt the 'ssgt is a shorthand command that is tranparently called, its a preloaded  lisp you could have a few of these for pre defined selections. The use of transparent commands is one of those hidden options in Autocad.
Some examples at command line type
copy 'ssgt <Enter> pick pick text is copied.
Chprop 'ssgt "" la newlayer
Note the apostrophe ' before the command this makes it transparent.
(defun c:ssgp ()
(ssget '((0 . "LWPOLYLINE")))
(defun c:ssgt ()
(defun c:ssgm()
(ssget '((0 . "MText")))
(defun c:ssgl ()
(ssget '((0 . "LINE")))
(defun c:ssmt ()
(ssget '((0 . "*text")))
(defun c:ssct ( / ss)
(setq ss (ssget '((0 . "*Text"))))
(command "chprop" ss "" "la" (getstring "new layer") "")
Edited by BIGAL
  • Thanks 1
22 hours ago, Aftertouch said:
Copy or move?
copy not move Sir
Edited by BKRao
Thank U "BIGAL" Sir
I am traying with below code kindly correct it Sir.
(defun c:ssct (/ ss sel)
(command "copy" ss  "" "" "")
    (setq sel (vlax-ename->vla-object (entlast)))
    (vlax-put-property sel 'layer "layer2")
Edited by BKRao
On 05/04/2019 at 13:19, BKRao said:
Thank U "BIGAL" Sir
You need to loop through the selection set
You can either
(defun c:ssct (/ ss cnt obj n_obj)
  (setq ss (ssget '((0 . "*Text") (8 . "layer1"))))
  (repeat (setq cnt (sslength ss))
    (setq obj (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt))))
          n_obj (vla-copy obj)
    (vlax-put-property n_obj 'layer "layer2")
or
(defun c:ssct (/ ss cnt sel)
  (setq c_doc (vla-get-activedocument (vlax-get-acad-object))
  (vlax-for obj (vla-get-activeselectionset c_doc)
    (setq n_obj (vla-copy obj))
The text will exactly overwrite the existing text so you will have two text items at each location. Did you by change mean to copy and move?
Edited by dlanorh
corrected code
  • Thanks 1
Copy and move
(defun c:ssct (/ ss  pt1 pt2 layer2)
(setq layer2 (getstring "\nEnter layer name"))
 (setq pt1 (getpoint "\npick start point "))
(setq pt2 (getpoint  pt1 "\npick end point"))
(command  "copy" (ssname ss (setq x (- x 1))) ""  pt1 pt2)
(command "chprop" (entlast) "" "la" Layer2 "" )
  • Thanks 1
Is this not the same as "copytolayer" command?
Quote
Thanking U everyone above program sufficient for my requirement. BKRao
