isolate diagonal polylines
HOCHANZ
i'm having difficulty creating a LISP routine to do the following.
1. get a selection set from the user
2. isolate diagonal (non horizontal and vertical) polylines
3. then do whatever is needed ie. change layer or delete
i can get the polyline selection set, but i'm not sure how to write the condition.
help.
Here is one way to do it checking that the start/endpoint x's or y's are not equal.
(defun c:foo (/ a b s)
  (cond	((setq s (ssget '((0 . "lwpolyline") (90 . 2))))
	 (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
	   (setq a (vlax-curve-getstartpoint x))
	   (setq b (vlax-curve-getendpoint x))
	   (if (or (equal (car a) (car b) 1e-8) (equal (cadr a) (cadr b) 1e-8))
	     (ssdel x s)
	 (sssetfirst nil s)
Edited by ronjonp
*changed code to work on polylines
  • Thanks 1
Ronjonp thats ok if closed else will error for every open pline. Like a U, also a closed pline can be a trapezoid with sloping sides, which OP has asked for.
Would not just check vertices pt1-pt2 ang is 0 pi/2 pi 1.5pi may need to check at least 3 pts.
Removed code
Edited by BIGAL
Try this, tested on "U" pline, zigzag, rectang, one corner moved of rectang.
; check if pline has ortho sides
; By Alan H April 2019
;(setq ent (entsel))
;(if ent (setq co-ords (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car ent))))))
(defun sqpline ( / ent ss  x pt1 pt2 ang ans len)
(setq ss (ssget "_+.:E:S" '((0 . "LWPOLYLINE"))))
(if ss  (setq co-ords (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (ssname ss 0))))))
(setq x 0)
(setq  ans " ")
(setq len (- (length co-ords) 1))
(setq pt1 (nth x co-ords))
(while (<  x len)
(setq pt2 (nth (setq x (+ x 1)) co-ords))
(setq ang (angle pt1 pt2))
(if (or (= ang 0.0) (= ang  (/ pi 2.0)) (= ang  pi) (= ang (* 1.5 pi)))
(setq ans (strcat ans "Yes"))
(setq ans (strcat ans "No" ))
(setq pt1 pt2)
(if (> (vl-string-search "No" ans )-1)
(alert "pline is not square")
(alert "square sided pline")
(sqpline)
Edited by BIGAL
15 hours ago, HOCHANZ said:
yes. i have the code for a LINE.
I'm trying to do this with LWPOLYLINES.
The code I posted works on 2 vertex polylines
Removed code
Where did they ask for a trapezoid? The code I posted just compares the x's and y's of the start and end points .. no angle check.
This is a good example where a sample drawing would be helpful.
RONJON - The revised does exactly what i was looking for.
The criteria
1. 2 point polylines
2. non rectangular
3. not closed
simple stuff.
thank you.
