Text height can't change in properties panel.
RAMPRASANTH
Text height can't change in Dimensions style manager.i saw that text height default in style manager.....I already reset text style and text height 0. But I can't change the value in Dimensionstyle manager.........if any command to lock the text height....please give solutions
If the text style in your dimension is associative, you can't change it in the dimension style. Use a style that isn't associative, or make a copy of the associative style and change it to non-associative.
If that doesn't resolve your issue, please provide more information or a relevant excerpt from your drawing.
If there's a Height set in the Text Style it will override the Text height in the Dimension Style.  Use a different Text style whose height is set to 0.
