ktbjx Posted March 29, 2019 Share Posted March 29, 2019 (defun c:test ( / ss n i e el start_point End_point new_start_point new_End_point romabels ) (setq ss (ssget "_:L" '((0 . "LINE")))) (setq romabels (Getreal "\nEnter X Value: ")) (setq i 0) (setq n (sslength ss)) (while (< i n) (setq e (ssname ss i)) (setq el (entget e)) (setq start_point (assoc 10 el)) (setq new_start_point (list 10 (romabels) (cadr start_point) (caddr start_point))) (setq el (subst new_start_point start_point el)) (setq End_point (assoc 11 el)) (setq new_End_point (list 11 (romabels) (cadr End_point) (caddr End_point))) (setq el (subst new_End_point End_point el)) (entmod el) (setq i (+ 1 i)) ) (princ) ) basically my routine just change the coordinate... StartX = input value StartY = old StartX StartZ = old StartY EndX = input value EndY = old EndX EndZ = old EndY But it says Error Bad Function "whatever the input value is" Quote Link to comment Share on other sites More sharing options...
dlanorh Posted March 29, 2019 Share Posted March 29, 2019 (edited) (setq start_point (cdr (assoc 10 el))) (setq new_start_point (list 10 (romabels) (cadr start_point) (caddr start_point))) (setq el (subst new_start_point (assoc 10 el) el)) (setq End_point (cdr (assoc 11 el))) (setq new_End_point (list 11 (romabels) (cadr End_point) (caddr End_point))) (setq el (subst new_End_point (assoc 11 el) el)) (entmod el) This (cadr start_point) (caddr start_point) won't work with this (setq start_point (assoc 10 el)) Learn how to use the vlide Edited March 29, 2019 by dlanorh clarity Quote Link to comment Share on other sites More sharing options...
ScoRm Posted March 29, 2019 Share Posted March 29, 2019 1 hour ago, dlanorh said: (setq start_point (cdr (assoc 10 el))) (setq new_start_point (list 10 (romabels) (cadr start_point) (caddr start_point))) (setq el (subst new_start_point (assoc 10 el) el)) (setq End_point (cdr (assoc 11 el))) (setq new_End_point (list 11 (romabels) (cadr End_point) (caddr End_point))) (setq el (subst new_End_point (assoc 11 el) el)) (entmod el) This (cadr start_point) (caddr start_point) won't work with this (setq start_point (assoc 10 el)) Learn how to use the vlide what do you mean??? If i do this, it works just fine (setq new_start_point (list 10 (cadr start_point) (cadr start_point) (caddr start_point))) but if i do this, it gives me error (setq new_start_point (list 10 (romabels) (cadr start_point) (caddr start_point))) romabels is taken here at the begining (setq romabels (Getreal "\nEnter X Value: ")) Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted March 29, 2019 Share Posted March 29, 2019 Romabels is a variable not a function. There should not be parentheses around it. (setq new_start_point (list 10 romabels (cadr start_point) (caddr start_point))) 1 Quote Link to comment Share on other sites More sharing options...
dlanorh Posted March 29, 2019 Share Posted March 29, 2019 start_point is a dotted pair which is a different type of list. Quote Link to comment Share on other sites More sharing options...
dlanorh Posted March 29, 2019 Share Posted March 29, 2019 1 hour ago, Roy_043 said: Romabels is a variable not a function. There should not be parentheses around it. (setq new_start_point (list 10 romabels (cadr start_point) (caddr start_point))) missed that Quote Link to comment Share on other sites More sharing options...
dlanorh Posted March 29, 2019 Share Posted March 29, 2019 42 minutes ago, dlanorh said: start_point is a dotted pair which is a different type of list. My mistake, this isn't true. However (cadr start_point) (caddr start_point) returns the x and y coordinates, not the y and z coordinates Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 30, 2019 Share Posted March 30, 2019 An alternative (defun c:test ( / ss ent start_point End_point romabels ) (setq ss (ssget "_:L" '((0 . "LINE")))) (setq romabels (Getreal "\nEnter X Value: ")) (setq ent (ssname ss 0)) (setq start_point(getpropertyvalue ent "startpoint" )) (setq end_point (getpropertyvalue ent "endpoint" )) (setq start_pointx (car start_point)) (setq start_pointy (cadr start_point)) (setq start_pointz (caddr start_point)) (setq end_pointx (car end_point)) (setq end_pointy (cadr end_point)) (setq end_pointz (caddr end_point)) (setpropertyvalue ent "startpoint" (list romabels start_pointx start_pointy)) (setpropertyvalue ent "endpoint" (list romabels end_pointx end_pointy)) ) (C:test) Quote Link to comment Share on other sites More sharing options...
