Hello everyone.
I have tried to select all entities in the current workspace based on the properties in the ent_list list (see an example below).  I notice that the ent_list could contain several names of entities and/or other properties thereof.
;| ent_list example
(((0 . "CIRCLE") (8 . "R_30m") (62 . 7) (410 . "Model"))
((0 . "MTEXT") (8 . "Pen_No__12") (62 . 3) (410 . "Model"))
((0 . "LWPOLYLINE") (8 . "Limits") (62 . 256) (410 . "Model"))
((0 . "LWPOLYLINE") (8 . "Pen_No__1") (62 . 5) (410 . "Model"))
((0 . "LINE") (8 . "Pen_No__7") (62 . 256) (410 . "Model"))
((0 . "ARC") (8 . "Pen_No__31") (62 . 256) (410 . "Model")))
;;This returns nil:
(setq S_LIGH (ssget "_X" (append (cons '(-4 . "<and") ent_list) (list '(-4 . "and>")))))
So I found a "bypass route" but I do not like the solution (see below).
(setq SS_LST (mapcar (function (lambda (x) (ssget "_X" x))) ent_list))
Returns:
<Selection Set: ff8b7860>
<Selection Set: ff8b7820>
<Selection Set: ff8b7940>
<Selection Set: ff8b79a0>
<Selection Set: ff8b77e0>
<Selection Set: ff8b79c0>)
(setq S_LIGH
	(if (= (length SS_LST) 1)
		(car SS_LST)
;;https://www.cadtutor.net/forum/topic/39716-how-to-join-selection-sets/
;; Selection Set Union  -  Lee Mac
;; Returns the union of a list of Selection Sets
		(LM:ss-union SS_LST) ;;Returns <Selection Set: ff8b7940>
Another approach or idea?
Thank you in advance.
You'll need to use OR logic between each group of properties, and AND logic between the properties within the group, e.g.:
(setq s_ligh
    (ssget "_X"
        (append
           '((-4 . "<OR"))
            (apply 'append (mapcar '(lambda ( x ) (append '((-4 . "<AND")) x '((-4 . "AND>")))) ent_list))
           '((-4 . "OR>"))
Edited by Lee Mac
  • Thanks 1
What don't you like about it if it works?
@ronjonp
1. Need for speed.
2. I want to avoid using a large number of selection sets.
@Lee Mac
Thank you for your solution. It works fine.
9 hours ago, lido said:
@Lee Mac
Excellent to hear - you're welcome :)
