lido Posted March 24, 2019 Posted March 24, 2019 Hello everybody. Considering PSTYLEMODE=0 (use of named plot style tables), how to select with AutoLISP all entities in current working space based on PlotStyleName criteria? Thank you in advance. Quote
marko_ribar Posted March 24, 2019 Posted March 24, 2019 Look into DXF 380 and 390 group codes... Quote
lido Posted March 24, 2019 Author Posted March 24, 2019 @marko_ribar Thank you for your answer. Here below are the results. ;;1 (vla-get-plotstylename(vlax-ename->vla-object(entlast))) ;;Return "Style_1" ;;2 (cdr (assoc 380 (entget (entlast)))) ;;Return nil ;;3 (cdr (assoc 390 (entget (entlast)))) ;;Return <ENTITY NAME: 2a253790> ;;??? Quote
marko_ribar Posted March 24, 2019 Posted March 24, 2019 (defun c:selnamedpstyle-Style_1 ( / dict stename ss ) (setq dict (dictsearch (namedobjdict) "ACAD_PLOTSTYLENAME")) (setq stename (cdr (assoc 350 (member '(3 . "Style_1") dict)))) (setq ss (ssget "_X" (list (cons 390 stename) (cons 410 (getvar 'ctab))))) (sssetfirst nil ss) (princ) ) HTH., M.R. 1 Quote
lido Posted March 24, 2019 Author Posted March 24, 2019 @marko_ribar Yess. Thank you very much for your solution. Quote
