acad1985 Posted March 22, 2019 Posted March 22, 2019 (edited) Hello guys, I found a lisp on below path, file to rotate the blocks to 0 degree by the name of the block.but as per this code i need to select the block. Instead of select the block manually i want to select the block through Lisp. i tried to modify but i can;t able to do that. Can anyone help me on this. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/rotate-objects-to-0/td-p/5841894 (defun C:B0 (/ bdata sel); = Block to 0 rotation ;(setq sel (ssget "_x" '((0 . "INSERT")(2 . "123")))) (setq bdata (entget (car (entsel "\nSelect Block for 0 rotation: ")))) (entmod (subst '(50 . 0) (assoc 50 bdata) bdata)) ) Thanks in Advance. Edited March 22, 2019 by acad1985 Quote
dlanorh Posted March 22, 2019 Posted March 22, 2019 Try this : (vl-load-com) (defun C:B0 ( / ss cnt) (setq ss (ssget "_x" '((0 . "INSERT")(2 . "123"))));123 = Block to rotate to 0 (repeat (setq cnt (sslength ss)) (vlax-put-property (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt)))) 'rotation 0) );end_repeat (princ) ) Quote
Tharwat Posted March 22, 2019 Posted March 22, 2019 Vanilla. The following would ignore blocks on locked layers. (defun c:Foo (/ sel int ent get) (and (setq int -1 sel (ssget "_X" '((0 . "INSERT")))) (while (setq int (1+ int) ent (ssname sel int) ) (setq get (entget ent)) (if (/= 4 (logand 4 (cdr (assoc 70 (entget (tblobjname "LAYER" (cdr (assoc 8 get)))) ) ) ) ) (entmod (subst '(50 . 0) (assoc 50 get) get)) ) ) ) (princ) ) Quote
BIGAL Posted March 22, 2019 Posted March 22, 2019 Try this (defun test ( / obj ss bname x) (setq obj (vlax-ename->vla-object (car (entsel "Pick block for 0")))) (setq bname (vla-get-EffectiveName obj)) (setq ss (ssget "_x" (list(cons 0 "INSERT")(cons 2 bname)))) (repeat (setq x (sslength ss)) (vla-put-rotation (vlax-ename->vla-object (ssname ss (setq x (- x 1)))) 0.0) ) ) (test) Quote
Lee Mac Posted March 22, 2019 Posted March 22, 2019 @Tharwat FWIW, there is no need to test for & exclude block references on locked layers, as entmod will simply return nil if the entity is not write-enabled. Since INSERTs don't require subclass markers, here's another way to perform the entmod: (defun c:test ( / i s ) (if (setq s (ssget "_X" '((0 . "INSERT")))) (repeat (setq i (sslength s)) (entmod (list (cons -1 (ssname s (setq i (1- i)))) '(50 . 0.0))) ) ) (princ) ) Quote
Tharwat Posted March 23, 2019 Posted March 23, 2019 @Lee Mac Thank you for that precious observation. Quote
acad1985 Posted March 23, 2019 Author Posted March 23, 2019 Hello Everyone, Thank you so much for your code. All of your code works perfectly. Thanks everyone Quote
