rehan0129 Posted March 21, 2019 Posted March 21, 2019 I am creating a template drawing but while making this drawing I was working on two different versions of AUTOCAD (2012 & 2013). I have prepared my title sheet block but there are two scales in the drawing and I want only one i.e that is 1:1 but somehow there is one more scale which I am sure is coming 2012 version. I am trying to remove this scale as both the scale has same factor but I am unable to delete it as it says its being used by some object. I searched everything but could not find which object is using this 1:1000 scale. Need help to remove this scale and load only standard scale. AR template.dwtFetching info... Quote
vdigai78 Posted March 21, 2019 Posted March 21, 2019 Try Erase; All; R (a select objects that you wish to retain in your drawing); Enter. This will remove anything outside of the defined area. Then do: -purge;all; Enter; no; Enter This will purge everything including unused dimension styles, leading styles, and text styles etc. After that is complete you will be able to delete unused scales. Quote
SLW210 Posted March 22, 2019 Posted March 22, 2019 See if this article helps. http://cadtips.cadalyst.com/notestext/eliminate-excess-drawing-scales 1 1 Quote
