ScoRm Posted March 19, 2019 Posted March 19, 2019 i found a VBA that get the coordinates Here: but its not quite what i have in mind, first, it can select multiple lines - I need to select single line... (to control my selections) second, i need to press enter everytime i select - i need to automatically press enter if its possible my guess on the pressing the enter thingy is this code: oSS.SelectOnScreen iFilterCode, vFilterValue is there any other ways to select a line? so that i will not press ENTER everytime? Here is the code BTW if you dont wanna go to the link: Public Sub LineDetail() Dim oSS As AcadSelectionSet Dim oEntity As AcadEntity Dim iFilterCode(0) As Integer Dim vFilterValue(0) As Variant On Error Resume Next Application.ActiveDocument.SelectionSets("Lines").Delete On Error GoTo 0 Set oSS = Application.ActiveDocument.SelectionSets.Add("Lines") iFilterCode(0) = 0: vFilterValue(0) = "Line" oSS.SelectOnScreen iFilterCode, vFilterValue If oSS.Count Then For Each oEntity In oSS Dim oLine As AcadLine Set oLine = oEntity With oLine MsgBox "StartPoint: " & .StartPoint(0) & ", " & .StartPoint(1) & ", " & .StartPoint(2) & vbCrLf & _ "EndPoint : " & .EndPoint(0) & ", " & .EndPoint(1) & ", " & .EndPoint(2) End With Next oEntity End If End Sub Quote
BIGAL Posted March 20, 2019 Posted March 20, 2019 (edited) Public Sub alantest() Dim objent As AcadObject pick = True 'WHILE PICKING ENTITY Do While pick ThisDrawing.Utility.GetEntity objent, basepnt, "Pick line : " 'WHILE PICKING ENTITY If objent.ObjectName = "AcDbLine" Then ' If condition is True. Dim oLine As AcadLine Set oLine = objent With oLine MsgBox "StartPoint: " & .StartPoint(0) & ", " & .StartPoint(1) & ", " & .StartPoint(2) & vbCrLf & _ "EndPoint : " & .EndPoint(0) & ", " & .EndPoint(1) & ", " & .EndPoint(2) End With Else pick = False ' Set value of flag to False. MsgBox "object is not a line " & objent.ObjectName End If Loop End Sub Edited March 20, 2019 by BIGAL Quote
