Tomislav Posted April 20, 2019 Posted April 20, 2019 46 minutes ago, dlanorh said: (setq a (10 20 30)) => ;error: bad function: 10. This is looking for a function called 10 (defun 10 ( a b / )......) with two parameters to pass in (setq a '(10 20 30)) => (10 20 30) (type a) => LIST but (setq b 20) (setq a '(10 b 30)) => (10 B 30) (type a) => LIST ; ' means literal b is not evaluated (setq a (list 10 b 30)) => (10 20 30) (type a) => LIST ;Now b is evaluated i've wrote this down as a reminder, now it's pretty clearer, thanx again for the effort to explain it Quote
BIGAL Posted April 21, 2019 Posted April 21, 2019 Just a extra (kbn) this would be looked at as if you have a defun called kbn because you have enclosed it in brackets. This is the way you call a defun without passing any variables. Quote
Lee Mac Posted April 27, 2019 Posted April 27, 2019 On 4/20/2019 at 6:23 PM, Tomislav said: i still don't quite get it why list,list,list instead of '(("Blocks" (kbn)) but must work on it My article describing The Apostrophe and the Quote Function should shed some light on this and help with your understanding. On 4/20/2019 at 6:03 PM, dlanorh said: Try (Steal "D:\\Geodezija\\Kartografska zbirka\\1000_BLOKOVI.dwg" (list (list "Blocks" (list kbn))) ) ;_ Steal Many thanks for assisting in my absence @dlanorh Quote
Tomislav Posted April 27, 2019 Posted April 27, 2019 Thanks to you too Lee, ruler of the Lisp land Quote
AJT Posted May 6, 2024 Posted May 6, 2024 Resurrecting an old thread, but I did a bunch of searching and this lisp routine does just about exactly what I'm looking to do, except I'm a total noob and can't figure out how to change it to: 1) force the z elevation to 0 - a 2d point would be preferred (I know I can change it to 0 in the CSV file, but it's got to be easy enough to force it through the routine and save the manual processing) 2) keep the original layer of the block being imported instead of it being put on the current layer Does anyone happen to know what would need to be done? Thanks in advance, AJT Quote
