RubberDinero Posted March 13, 2019 Posted March 13, 2019 I'm looking for a lisp that will scan the entire drawing for objects that are on layers and change it to another layer i.e. drawings that have objects within and outside of blocks with "their-sewer-layer", select all those objects without exploding the blocks and change them to "my-sewer-layer" I've seen a few lisps but they don't work for objects inside a block. Thanks in advanced! Quote
Tharwat Posted March 13, 2019 Posted March 13, 2019 Something like this? (defun c:Test (/ doc) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vlax-for obj (vla-get-blocks doc) (or (= :vlax-true (vla-get-IsXRef obj)) (vlax-for itm obj (if (= (vla-get-layer itm) "their-sewer-layer") (vla-put-layer itm "my-sewer-layer") ) ) ) ) (vla-regen doc AcAllViewports) (princ) ) (vl-load-com) Quote
RubberDinero Posted March 13, 2019 Author Posted March 13, 2019 it did not work, but I'm guess it was because I am trying to use an asterisk "*sewer*" to get all related sewer entities. Quote
Tharwat Posted March 13, 2019 Posted March 13, 2019 3 minutes ago, RubberDinero said: it did not work, but I'm guess it was because I am trying to use an asterisk "*sewer*" to get all related sewer entities. Actually it DOES work but you have changed your intention and wanted something different than what you have explained in the first post. Anyway, if you want it with wildcard then just replace the following and be sure to have the target layer available in the drawing. Replace this: (if (= (vla-get-layer itm) "their-sewer-layer") (vla-put-layer itm "my-sewer-layer") ) With this: (if (wcmatch (vla-get-layer itm) "*sewer*") (vla-put-layer itm "my-sewer-layer")) Quote
RubberDinero Posted March 13, 2019 Author Posted March 13, 2019 (edited) I apologize for my ineptitude at explaining my intended use. I would like a lisp that can examine items like polylines, texts, circles, blocks, etc (every type of objects) that may be in model space or at the same time within a block reference(the objects in a block reference being more polylines, texts, circles, etc), and globally change the layer of individual objects who's original layer is containing the wildcard "*sewer*" to a layer of my choice. In this "Test" a layer named "My-Sewer-Layer". In this scenario, as tested above, the code not was useful for my intended use, but that was my fault for not describing with more detail exactly what I was needing. Thanks! Edited March 13, 2019 by RubberDinero Quote
Tharwat Posted March 13, 2019 Posted March 13, 2019 No worries, just replace what I have described in my last reply then try again. Quote
RubberDinero Posted March 13, 2019 Author Posted March 13, 2019 That worked great! only issue was that it was case sensitive, but i fixed it by adding an additional line (if (wcmatch (vla-get-layer itm) "*sewer*") (vla-put-layer itm "my-sewer-layer") (if (wcmatch (vla-get-layer itm) "*Sewer*") (vla-put-layer itm "my-sewer-layer")) Is this how you would have handled this case? Quote
Tharwat Posted March 13, 2019 Posted March 13, 2019 Not quite but the following is to cover all cases: (if (wcmatch (strcase (vla-get-layer itm)) "*SEWER*") (vla-put-layer itm "my-sewer-layer")) Quote
RubberDinero Posted March 16, 2019 Author Posted March 16, 2019 This has been working perfectly! is there a way to create or statements? look for "*SEWER*" or "*SWR*" or "*Sewr*" I don't mind creating additional lines. I have already added additional lines for water and gas with different abbreviation, but I was just curious . Quote
dlanorh Posted March 16, 2019 Posted March 16, 2019 40 minutes ago, RubberDinero said: This has been working perfectly! is there a way to create or statements? look for "*SEWER*" or "*SWR*" or "*Sewr*" I don't mind creating additional lines. I have already added additional lines for water and gas with different abbreviation, but I was just curious . (if (or (wcmatch (strcase (vla-get-layer itm)) "*SEWER*") (wcmatch (strcase (vla-get-layer itm)) "*SWR*") (wcmatch (strcase (vla-get-layer itm)) "*SEWR*") );end_or (vla-put-layer itm "my-sewer-layer") ) Quote
Tharwat Posted March 17, 2019 Posted March 17, 2019 @dlanorh you can use comma for the string pattern instead of the repetition of the same expression many times like this: *SEWER*,*SWR*" and you can add as many as you want. 1 Quote
