ktbjx Posted March 7, 2019 Posted March 7, 2019 I have this layers, I know how to make a new layer from Autolisp, but I don't know how to make a group filter from the layers made. Also as you can see in the image, the layers have strings("CONTOUR_EL") attached to elevations, so i cannot just use If statements to it. Can someone help me group filter all the layers please? here is the ranges: 1170 - 1238 = "1150 LEVEL" 1110 - 1168 = "1100 LEVEL" 1070 - 1108 = "1070 LEVEL" 1020 - 1068 = "1000 LEVEL" 962 - 1018 = "950 LEVEL" 910 - 960 = "900 LEVEL" 870 - 908 = "850 LEVEL" 810 - 868 = "800 LEVEL" 770 - 808 = "750 LEVEL" 710 - 778 = "700 LEVEL" 670 - 708 = "670 LEVEL" help? or at least show me how to make it, and ill try to make one myself 1 Quote
tombu Posted March 7, 2019 Posted March 7, 2019 (edited) Here's how I load mine: ; ^C^C^P(or LayFilterAdd (load "LayFilterAdd.lsp"));(LayFilterAdd) ; [B][COLOR="#FF0000"]Newer versions automatically display Xref Layer Filters **Adding Xref Layer Filter names the same as them can cause serious issues**[/COLOR][/B] ; Save, close and reopen the DWT or DWG for the Filters to be put into alphabetical order. (defun LayFilterAdd (/ collection names) ; (load "LFD.lsp") ; (command "C:LFD" "All*") *Layers (setq names (list "")) (if (not (vl-catch-all-error-p (setq collection (vl-catch-all-apply (function (lambda () (vla-item (vla-getextensiondictionary (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))) "ACAD_LAYERFILTERS"))) )))) ; (vlax-for item collection (setq names (cons (strcase (vla-get-name item)) names)))) (vlax-for item collection (setq names (cons (vla-get-name item) names)))) names (or(member "CALC Points" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"V-NODE-CALC\" or NAME== \"Layer*\"" "CALC Points" "X" nil)) (or(member "HATCH No xrefs" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"~*|*\" and NAME==\"*HATCH\"" "HATCH No xrefs" "X" nil)) (or(member "Linetype" names)(command "._-layer" "filter" "new" "property" "All" "LINETYPE==\"~Continuous\"" "Linetype" "X" nil)) (or(member "Lineweight" names)(command "._-layer" "filter" "new" "property" "All" "LINEWEIGHT==\"~Default\"" "Lineweight" "X" nil)) (or(member "NCS" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"[A,C,E,L,V]-*\" or NAME== \"Layer*\"" "NCS" "X" nil)) (or(member "NCS No xrefs" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"~*|*\" and NAME==\"[A,C,E,L,V]-*\" or NAME== \"Layer*\"" "NCS No xrefs" "X" nil)) (or(member "No NCS" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"~[A,C,E,L,V]-*\"" "No NCS" "X" nil)) (or(member "No NCS or xrefs" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"~*|*\" and NAME==\"~[A,C,E,L,V]-*\"" "No NCS or xrefs" "X" nil)) (or(member "No NODE" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"~*|*\" and NAME==\"[A,C,E,L,V]-*\" and NAME==\"~*-NODE*\" or NAME== \"Layer*\"" "No NODE" "X" nil)) (or(member "NODE" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"~*|*\" and NAME==\"*-NODE*\" or NAME== \"Layer*\"" "NODE" "X" nil)) (or(member "Profile" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"C-ROAD-PROF*\" or NAME== \"Layer*\"" "Profile" "X" nil)) (or(member "Sections" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"C-ROAD-SEC*\" or NAME== \"Layer*\"" "Sections" "X" nil)) (or(member "Topo" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"C-TOPO*\" or NAME== \"Layer*\"" "Topo" "X" nil)) (princ "Layer Filter Names » ")(princ names) ; (princ "\nSave, close and reopen the DWT or DWG for the Filters to be put into alphabetical order.") (princ) ); function (LayFilterAdd) wcmatch (AutoLISP) https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-AutoLISP/files/GUID-EC257AF7-72D4-4B38-99B6-9B09952A53AD-htm.html Edited August 10, 2020 by tombu Quote
tombu Posted March 7, 2019 Posted March 7, 2019 Gotta wonder how you managed to have seperate layers for every contour elevation? I'd be looking for a lisp to merge layers CONTOUR_EL "1170 thru 1238" into "1150 LEVEL" and so on. Contour_Index and Contour_Intermediate would be all the layers I'd use. Quote
BIGAL Posted March 8, 2019 Posted March 8, 2019 We have never really had the need for anything but Major and Minor contour layers ie 2 layers. The only time I have played with multi layers was to do with water volumes in ponds. Quote
ktbjx Posted March 11, 2019 Author Posted March 11, 2019 (edited) On 3/7/2019 at 9:13 PM, tombu said: Here's how I load mine: ; (load "LayFilterAdd.lsp") ; ^C^C^P(or LayFilterAdd (load "LayFilterAdd.lsp"));(LayFilterAdd) ; Save, close and reopen the DWT or DWG for the Filters to be put into alphabetical order. (defun LayFilterAdd (/ collection names) (setq names (list "")) (if (not (vl-catch-all-error-p (setq collection (vl-catch-all-apply (function (lambda () (vla-item (vla-getextensiondictionary (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))) "ACAD_LAYERFILTERS"))) )))) (vlax-for item collection (setq names (cons (vla-get-name item) names)))) names (or(member "NODE" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"*-NODE*\" or NAME== \"Layer*\"" "NODE" "X" nil)) (or(member "Sections" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"C-ROAD-SEC*\" or NAME== \"Layer*\"" "Sections" "X" nil)) (or(member "Profile" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"C-ROAD-PROF*\" or NAME== \"Layer*\"" "Profile" "X" nil)) (or(member "Topo" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"C-TOPO*\" or NAME== \"Layer*\"" "Topo" "X" nil)) (or(member "CALC Points" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"V-NODE-CALC\" or NAME== \"Layer*\"" "CALC Points" "X" nil)) (or(member "Linetype" names)(command "._-layer" "filter" "new" "property" "All" "LINETYPE==\"~Continuous\"" "Linetype" "X" nil)) (or(member "NCS" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"[A,C,E,L,V]-*\" or NAME== \"Layer*\"" "NCS" "X" nil)) (or(member "No NCS" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"~[A,C,E,L,V]-*\"" "No NCS" "X" nil)) (princ "Layer Filter Names » ")(princ names) (princ "\nSave, close and reopen the DWT or DWG for the Filters to be put into alphabetical order.") (princ) ); function (LayFilterAdd) wcmatch (AutoLISP) https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-AutoLISP/files/GUID-EC257AF7-72D4-4B38-99B6-9B09952A53AD-htm.html Sir Thank you so much for your routine... I edit it for my Filter and it works! Its long, i know, but its easy! i used excel and mostly concatenation and COPY>TRANSPOSE... Heres what i came up with: (defun LayFilterAdd (/ collection names) (setq names (list "")) (if (not (vl-catch-all-error-p (setq collection (vl-catch-all-apply (function (lambda () (vla-item (vla-getextensiondictionary (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))) "ACAD_LAYERFILTERS"))) )))) (vlax-for item collection (setq names (cons (vla-get-name item) names)))) names (or(member "670 LEVEL" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"*CONTOUR_EL670*\" or NAME==\"*CONTOUR_EL672*\" or NAME==\"*CONTOUR_EL674*\" or NAME==\"*CONTOUR_EL676*\" or NAME==\"*CONTOUR_EL678*\" or NAME==\"*CONTOUR_EL680*\" or NAME==\"*CONTOUR_EL682*\" or NAME==\"*CONTOUR_EL684*\" or NAME==\"*CONTOUR_EL686*\" or NAME==\"*CONTOUR_EL688*\" or NAME==\"*CONTOUR_EL690*\" or NAME==\"*CONTOUR_EL692*\" or NAME==\"*CONTOUR_EL694*\" or NAME==\"*CONTOUR_EL696*\" or NAME==\"*CONTOUR_EL698*\" or NAME==\"*CONTOUR_EL700*\" or NAME==\"*CONTOUR_EL702*\" or NAME==\"*CONTOUR_EL704*\" or NAME==\"*CONTOUR_EL706*\"" "670 LEVEL" "X" nil)) (or(member "700 LEVEL" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"*CONTOUR_EL710*\" or NAME==\"*CONTOUR_EL712*\" or NAME==\"*CONTOUR_EL714*\" or NAME==\"*CONTOUR_EL716*\" or NAME==\"*CONTOUR_EL718*\" or NAME==\"*CONTOUR_EL720*\" or NAME==\"*CONTOUR_EL722*\" or NAME==\"*CONTOUR_EL724*\" or NAME==\"*CONTOUR_EL726*\" or NAME==\"*CONTOUR_EL728*\" or NAME==\"*CONTOUR_EL730*\" or NAME==\"*CONTOUR_EL732*\" or NAME==\"*CONTOUR_EL734*\" or NAME==\"*CONTOUR_EL736*\" or NAME==\"*CONTOUR_EL738*\" or NAME==\"*CONTOUR_EL740*\" or NAME==\"*CONTOUR_EL742*\" or NAME==\"*CONTOUR_EL744*\" or NAME==\"*CONTOUR_EL746*\" or NAME==\"*CONTOUR_EL748*\" or NAME==\"*CONTOUR_EL750*\" or NAME==\"*CONTOUR_EL752*\" or NAME==\"*CONTOUR_EL754*\" or NAME==\"*CONTOUR_EL756*\" or NAME==\"*CONTOUR_EL758*\" or NAME==\"*CONTOUR_EL760*\" or NAME==\"*CONTOUR_EL762*\" or NAME==\"*CONTOUR_EL764*\" or NAME==\"*CONTOUR_EL766*\" or NAME==\"*CONTOUR_EL768*\"" "700 LEVEL" "X" nil)) (or(member "750 LEVEL" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"*CONTOUR_EL770*\" or NAME==\"*CONTOUR_EL772*\" or NAME==\"*CONTOUR_EL774*\" or NAME==\"*CONTOUR_EL776*\" or NAME==\"*CONTOUR_EL778*\" or NAME==\"*CONTOUR_EL780*\" or NAME==\"*CONTOUR_EL782*\" or NAME==\"*CONTOUR_EL784*\" or NAME==\"*CONTOUR_EL786*\" or NAME==\"*CONTOUR_EL788*\" or NAME==\"*CONTOUR_EL790*\" or NAME==\"*CONTOUR_EL792*\" or NAME==\"*CONTOUR_EL794*\" or NAME==\"*CONTOUR_EL796*\" or NAME==\"*CONTOUR_EL798*\" or NAME==\"*CONTOUR_EL800*\" or NAME==\"*CONTOUR_EL802*\" or NAME==\"*CONTOUR_EL804*\" or NAME==\"*CONTOUR_EL806*\" or NAME==\"*CONTOUR_EL808*\"" "750 LEVEL" "X" nil)) (or(member "800 LEVEL" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"*CONTOUR_EL810*\" or NAME==\"*CONTOUR_EL812*\" or NAME==\"*CONTOUR_EL814*\" or NAME==\"*CONTOUR_EL816*\" or NAME==\"*CONTOUR_EL818*\" or NAME==\"*CONTOUR_EL820*\" or NAME==\"*CONTOUR_EL822*\" or NAME==\"*CONTOUR_EL824*\" or NAME==\"*CONTOUR_EL826*\" or NAME==\"*CONTOUR_EL828*\" or NAME==\"*CONTOUR_EL830*\" or NAME==\"*CONTOUR_EL832*\" or NAME==\"*CONTOUR_EL834*\" or NAME==\"*CONTOUR_EL836*\" or NAME==\"*CONTOUR_EL838*\" or NAME==\"*CONTOUR_EL840*\" or NAME==\"*CONTOUR_EL842*\" or NAME==\"*CONTOUR_EL844*\" or NAME==\"*CONTOUR_EL846*\" or NAME==\"*CONTOUR_EL848*\" or NAME==\"*CONTOUR_EL850*\" or NAME==\"*CONTOUR_EL852*\" or NAME==\"*CONTOUR_EL854*\" or NAME==\"*CONTOUR_EL856*\" or NAME==\"*CONTOUR_EL858*\" or NAME==\"*CONTOUR_EL860*\" or NAME==\"*CONTOUR_EL862*\" or NAME==\"*CONTOUR_EL864*\" or NAME==\"*CONTOUR_EL866*\" or NAME==\"*CONTOUR_EL868*\"" "800 LEVEL" "X" nil)) (or(member "850 LEVEL" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"*CONTOUR_EL870*\" or NAME==\"*CONTOUR_EL872*\" or NAME==\"*CONTOUR_EL874*\" or NAME==\"*CONTOUR_EL876*\" or NAME==\"*CONTOUR_EL878*\" or NAME==\"*CONTOUR_EL880*\" or NAME==\"*CONTOUR_EL882*\" or NAME==\"*CONTOUR_EL884*\" or NAME==\"*CONTOUR_EL886*\" or NAME==\"*CONTOUR_EL888*\" or NAME==\"*CONTOUR_EL890*\" or NAME==\"*CONTOUR_EL892*\" or NAME==\"*CONTOUR_EL894*\" or NAME==\"*CONTOUR_EL896*\" or NAME==\"*CONTOUR_EL898*\" or NAME==\"*CONTOUR_EL900*\" or NAME==\"*CONTOUR_EL902*\" or NAME==\"*CONTOUR_EL904*\" or NAME==\"*CONTOUR_EL906*\" or NAME==\"*CONTOUR_EL908*\"" "850 LEVEL" "X" nil)) (or(member "900 LEVEL" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"*CONTOUR_EL910*\" or NAME==\"*CONTOUR_EL912*\" or NAME==\"*CONTOUR_EL914*\" or NAME==\"*CONTOUR_EL916*\" or NAME==\"*CONTOUR_EL918*\" or NAME==\"*CONTOUR_EL920*\" or NAME==\"*CONTOUR_EL922*\" or NAME==\"*CONTOUR_EL924*\" or NAME==\"*CONTOUR_EL926*\" or NAME==\"*CONTOUR_EL928*\" or NAME==\"*CONTOUR_EL930*\" or NAME==\"*CONTOUR_EL932*\" or NAME==\"*CONTOUR_EL934*\" or NAME==\"*CONTOUR_EL936*\" or NAME==\"*CONTOUR_EL938*\" or NAME==\"*CONTOUR_EL940*\" or NAME==\"*CONTOUR_EL942*\" or NAME==\"*CONTOUR_EL944*\" or NAME==\"*CONTOUR_EL946*\" or NAME==\"*CONTOUR_EL948*\" or NAME==\"*CONTOUR_EL950*\" or NAME==\"*CONTOUR_EL952*\" or NAME==\"*CONTOUR_EL954*\" or NAME==\"*CONTOUR_EL956*\" or NAME==\"*CONTOUR_EL958*\" or NAME==\"*CONTOUR_EL960*\"" "900 LEVEL" "X" nil)) (or(member "950 LEVEL" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"*CONTOUR_EL962*\" or NAME==\"*CONTOUR_EL964*\" or NAME==\"*CONTOUR_EL966*\" or NAME==\"*CONTOUR_EL968*\" or NAME==\"*CONTOUR_EL970*\" or NAME==\"*CONTOUR_EL972*\" or NAME==\"*CONTOUR_EL974*\" or NAME==\"*CONTOUR_EL976*\" or NAME==\"*CONTOUR_EL978*\" or NAME==\"*CONTOUR_EL980*\" or NAME==\"*CONTOUR_EL982*\" or NAME==\"*CONTOUR_EL984*\" or NAME==\"*CONTOUR_EL986*\" or NAME==\"*CONTOUR_EL988*\" or NAME==\"*CONTOUR_EL990*\" or NAME==\"*CONTOUR_EL992*\" or NAME==\"*CONTOUR_EL994*\" or NAME==\"*CONTOUR_EL996*\" or NAME==\"*CONTOUR_EL998*\" or NAME==\"*CONTOUR_EL1000*\" or NAME==\"*CONTOUR_EL1002*\" or NAME==\"*CONTOUR_EL1004*\" or NAME==\"*CONTOUR_EL1006*\" or NAME==\"*CONTOUR_EL1008*\" or NAME==\"*CONTOUR_EL1010*\" or NAME==\"*CONTOUR_EL1012*\" or NAME==\"*CONTOUR_EL1014*\" or NAME==\"*CONTOUR_EL1016*\" or NAME==\"*CONTOUR_EL1018*\"" "950 LEVEL" "X" nil)) (or(member "1000 LEVEL" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"*CONTOUR_EL1020*\" or NAME==\"*CONTOUR_EL1022*\" or NAME==\"*CONTOUR_EL1024*\" or NAME==\"*CONTOUR_EL1026*\" or NAME==\"*CONTOUR_EL1028*\" or NAME==\"*CONTOUR_EL1030*\" or NAME==\"*CONTOUR_EL1032*\" or NAME==\"*CONTOUR_EL1034*\" or NAME==\"*CONTOUR_EL1036*\" or NAME==\"*CONTOUR_EL1038*\" or NAME==\"*CONTOUR_EL1040*\" or NAME==\"*CONTOUR_EL1042*\" or NAME==\"*CONTOUR_EL1044*\" or NAME==\"*CONTOUR_EL1046*\" or NAME==\"*CONTOUR_EL1048*\" or NAME==\"*CONTOUR_EL1050*\" or NAME==\"*CONTOUR_EL1052*\" or NAME==\"*CONTOUR_EL1054*\" or NAME==\"*CONTOUR_EL1056*\" or NAME==\"*CONTOUR_EL1058*\" or NAME==\"*CONTOUR_EL1060*\" or NAME==\"*CONTOUR_EL1062*\" or NAME==\"*CONTOUR_EL1064*\" or NAME==\"*CONTOUR_EL1066*\"" "1000 LEVEL" "X" nil)) (or(member "1070 LEVEL" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"*CONTOUR_EL1070*\" or NAME==\"*CONTOUR_EL1072*\" or NAME==\"*CONTOUR_EL1074*\" or NAME==\"*CONTOUR_EL1076*\" or NAME==\"*CONTOUR_EL1078*\" or NAME==\"*CONTOUR_EL1080*\" or NAME==\"*CONTOUR_EL1082*\" or NAME==\"*CONTOUR_EL1084*\" or NAME==\"*CONTOUR_EL1086*\" or NAME==\"*CONTOUR_EL1088*\" or NAME==\"*CONTOUR_EL1090*\" or NAME==\"*CONTOUR_EL1092*\" or NAME==\"*CONTOUR_EL1094*\" or NAME==\"*CONTOUR_EL1096*\" or NAME==\"*CONTOUR_EL1098*\" or NAME==\"*CONTOUR_EL1100*\" or NAME==\"*CONTOUR_EL1102*\" or NAME==\"*CONTOUR_EL1104*\" or NAME==\"*CONTOUR_EL1106*\" or NAME==\"*CONTOUR_EL1108*\"" "1070 LEVEL" "X" nil)) (or(member "1100 LEVEL" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"*CONTOUR_EL1110*\" or NAME==\"*CONTOUR_EL1112*\" or NAME==\"*CONTOUR_EL1114*\" or NAME==\"*CONTOUR_EL1116*\" or NAME==\"*CONTOUR_EL1118*\" or NAME==\"*CONTOUR_EL1120*\" or NAME==\"*CONTOUR_EL1122*\" or NAME==\"*CONTOUR_EL1124*\" or NAME==\"*CONTOUR_EL1126*\" or NAME==\"*CONTOUR_EL1128*\" or NAME==\"*CONTOUR_EL1130*\" or NAME==\"*CONTOUR_EL1132*\" or NAME==\"*CONTOUR_EL1134*\" or NAME==\"*CONTOUR_EL1136*\" or NAME==\"*CONTOUR_EL1138*\" or NAME==\"*CONTOUR_EL1140*\" or NAME==\"*CONTOUR_EL1142*\" or NAME==\"*CONTOUR_EL1144*\" or NAME==\"*CONTOUR_EL1146*\" or NAME==\"*CONTOUR_EL1148*\" or NAME==\"*CONTOUR_EL1150*\" or NAME==\"*CONTOUR_EL1152*\" or NAME==\"*CONTOUR_EL1154*\" or NAME==\"*CONTOUR_EL1156*\" or NAME==\"*CONTOUR_EL1158*\" or NAME==\"*CONTOUR_EL1160*\" or NAME==\"*CONTOUR_EL1162*\" or NAME==\"*CONTOUR_EL1164*\" or NAME==\"*CONTOUR_EL1166*\" or NAME==\"*CONTOUR_EL1168*\"" "1100 LEVEL" "X" nil)) (or(member "1150 LEVEL" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"*CONTOUR_EL1170*\" or NAME==\"*CONTOUR_EL1172*\" or NAME==\"*CONTOUR_EL1174*\" or NAME==\"*CONTOUR_EL1176*\" or NAME==\"*CONTOUR_EL1178*\" or NAME==\"*CONTOUR_EL1180*\" or NAME==\"*CONTOUR_EL1182*\" or NAME==\"*CONTOUR_EL1184*\" or NAME==\"*CONTOUR_EL1186*\" or NAME==\"*CONTOUR_EL1188*\" or NAME==\"*CONTOUR_EL1190*\" or NAME==\"*CONTOUR_EL1192*\" or NAME==\"*CONTOUR_EL1194*\" or NAME==\"*CONTOUR_EL1196*\" or NAME==\"*CONTOUR_EL1198*\" or NAME==\"*CONTOUR_EL1200*\" or NAME==\"*CONTOUR_EL1202*\" or NAME==\"*CONTOUR_EL1204*\" or NAME==\"*CONTOUR_EL1206*\" or NAME==\"*CONTOUR_EL1208*\" or NAME==\"*CONTOUR_EL1210*\" or NAME==\"*CONTOUR_EL1212*\" or NAME==\"*CONTOUR_EL1214*\" or NAME==\"*CONTOUR_EL1216*\" or NAME==\"*CONTOUR_EL1218*\" or NAME==\"*CONTOUR_EL1220*\" or NAME==\"*CONTOUR_EL1222*\" or NAME==\"*CONTOUR_EL1224*\" or NAME==\"*CONTOUR_EL1226*\" or NAME==\"*CONTOUR_EL1228*\" or NAME==\"*CONTOUR_EL1230*\"" "1150 LEVEL" "X" nil)) (princ "Layer Filter Names » ")(princ names) (princ "\nSave, close and reopen the DWT or DWG for the Filters to be put into alphabetical order.") (princ) ); function (LayFilterAdd) Edited March 11, 2019 by ktbjx 1 Quote
