Currently the view port color over write doesn't effect the colors of nested blocks. The nested blocks show the global color of the layer.
Ideally VP color over write should behave same as changing global color of layer. Is there a way to achieve it (beside exploding the blocks to remove nesting).
For example see attached sample file. I want all elements in the blocks to have the overwritten color in the view port i.e. color 20, instead it is showing the nested blocks as yellow which is not what i want.
sample.dwgFetching info...
Edited by PrimeTimeAction
The circle (or nested block) needs to be on Layer 0 and set to ByLayer for color, it was set to ByBlock.
Thanks. It solved the problem.
