Hi Writers!
here i am again with new question.
I am looking for a lisp to Offset line by a selection set values.
i really wanted to get an intersection point after offsetting so that i can draw circle at each intersection.
but i have values till outer of circle, i know the radius of circle.
Process may be like this.
  1. Select Values
  2. Get Circle radius from user
  3. add with selected values
  4. select Line
  5. offset in positive direction by added values
  6. repeat once to offset another line.
please help me to find a lisp.
Thank you..
This is a pretty easy task and a good task for learning lisp etc. Just look at some of the code examples here and you will find all the answers.
It is better to see people having a go rather then just go to Cadtutor and doing the lazy some one  there will write the code for you.
Here is the method with the lisp commands highlited.
Select text Entsel use assoc 1 to get text convert to a number atof txt
Get radius getreal or getdist
 Comand offset pick line pick side getpoint.
Save the new line's entityname entlast
repeat offset for second line
Use inters to find intersection point
Command Erase the two offset lines using the entity name and entlast
Command circle using the intersection point and rad
To do positive side of picked line requires a bit more code where you check which end of a line you picked and can then work out left and right.
Lastly search for offset here so many lisp examples.
Edited by BIGAL
thank you!
i came up with this coding please check.
i want to re run this program by getting a key word from user. (yes/No)
please explain how to do without terminating.
i need to add intersections after that.
(defun c:TEST (/)
  	(vl-load-com)
    	(setq temperr *error*)					;store *error*
	(setq *error* trap1)					;re-assign *error*
	(setq oldecho (getvar "cmdecho"))			;store variables
	(setq oldlayer (getvar "clayer"))
	(setq oldsnap (getvar "osmode"))
	(setvar "cmdecho" 0)					;reset variables
	(setvar "osmode" 32)
	(command "undo" "m")
  (command "layer" "make" "INT" "color" "160" "" "")
  (princ "\nSelect Bottom/Side/Vertical Line: ")
  (setq o (ssget))
  (setq s (getpoint "\nPick Offset side"))
  (setq ra (getreal "\nEnter Duct Radius: "))
  (setq gr (ssget '((0 . "TEXT"))))
  (setq x1 (sslength gr))
  (cond
    	((= 1 x1)
  	(setq b1 (cdr (assoc 1 (entget (ssname gr 0))))
	c1 (+ ra (atof b1))
    	((= 2 x1)
		c1 (+ ra (atof b1))
		b2 (cdr (assoc 1 (entget (ssname gr 1))))
		c2 (+ ra (atof b2))
	((= 3 x1)
		c1 (+ ra (atof b1))
		c2 (+ ra (atof b2))
		b3 (cdr (assoc 1 (entget (ssname gr 2))))
		c3 (+ ra (atof b3))
    	((= 4 x1)
		c1 (+ ra (atof b1))
		c2 (+ ra (atof b2))
		c3 (+ ra (atof b3))
  		b4 (cdr (assoc 1 (entget (ssname gr 3))))
		c4 (+ ra (atof b4))
  (cond
  	((= 1 x1)
  	(progn (command "OFFSET" c1 o s ""))
      	((= 2  x1)
	(progn (command "OFFSET" c1 o s "") (command "OFFSET" c2 o s ""))
	((= 3  x1)
        (progn (command "OFFSET" c1 o s "") (command "OFFSET" c2 o s "") (command "OFFSET" c3 o s ""))
	((= 4  x1)
       	(progn (command "OFFSET" c1 o s "") (command "OFFSET" c2 o s "") (command "OFFSET" c3 o s "") (command "OFFSET" c4 o s ""))
    	(setvar "clayer" oldlayer)							;reset variables
	(setvar "osmode" oldsnap)
	(setvar "cmdecho" oldecho)
	(setq *error* temperr)
Edited by erbalaji
coding revised
Glad you got something together happy to help, nice use of the cond to work out how many text picked.
I added a While just press enter to exit, did not test as need your dwg, also change 1st pick  line to Entsel a it is only 1 object. Need a before & after picture, dwg would be best. Are you wanting to do others side as well
  (while (setq o (entsel "Select Bottom/Side/Vertical Line: "))
    ) ; end while
Edited by BIGAL
thank you for your input. it would be more convenient if the user chooses to use offset or not!
if yes then repeat
if no then need to go for finding intersections.
please give me a hint to combine programs.
Please post some examples. Dwg is best we are guessing what you want.
Edited by BIGAL
(defun TSE (/)
	(sub function)
(defun c:TSS (/ ans ans1)
    (vl-load-com)
  (command "OFFSET" l c "" "")
  (command (TSE))										;blind run of sub function
  (initget 1 "YES NO")
  (setq ans (getkword "\nWant to Offset [Yes/No]: "))	;first yes/no
  (cond
    ((= "YES" ans)
     (command (TSE))
    ((= "NO" ans)
     (command (COL-IT))
  (setq ans1 (getkword "\nWant to Offset [Yes/No]: "))	;second yes/no here if the user chooses yes above sub function (COL-IT) will not run hence this entire program fails.
  (cond
    ((= "YES" ans1)
     (command (TSE))
    ((= "NO" ans1)
     (command (COL-IT))
Please see the code below attached
i want to use repeat the program until the user wants to.
i did something nasty.
please check.
below here entire lisp attached.
TSS.LSP
