veteranus Posted February 21, 2019 Posted February 21, 2019 Hi, I need a lisp routine explained with this image, I would be grateful for your help. Regards. Quote
dlanorh Posted February 21, 2019 Posted February 21, 2019 Try this. I was unsure whether you wanted to select the text to get the prefix individually or as a selection set. It does the former, but is easily alterable to do the latter. (defun c:PText ( / *error* sv_lst sv_vals c_doc ss colour_lst t_str lyr l_lst) (defun *error* ( msg ) (mapcar 'setvar sv_lst sv_vals) (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nAn Error : " msg " occurred."))) (princ) );end_*error*_defun (setq sv_lst (list 'cmdecho 'osmode) sv_vals (mapcar 'getvar sv_lst) c_doc (vla-get-activedocument (vlax-get-acad-object)) p_obj (vlax-ename->vla-object (car (entsel "\nSelect Prefix text : "))) p_str (vlax-get-property p_obj 'textstring) );end_setq (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (vla-startundomark c_doc) (mapcar 'setvar sv_lst '(0 0)) (while (setq t_ent (entsel "\nSelect Text to Prefix : ")) (setq t_obj (vlax-ename->vla-object (car t_ent))) (vlax-put-property t_obj 'textstring (strcat p_str (vlax-get-property t_obj 'textstring))) );end_while (mapcar 'setvar sv_lst sv_vals) (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (princ) );end_defun 1 Quote
veteranus Posted February 21, 2019 Author Posted February 21, 2019 5 minutes ago, dlanorh said: Try this. I was unsure whether you wanted to select the text to get the prefix individually or as a selection set. It does the former, but is easily alterable to do the latter. (defun c:PText ( / *error* sv_lst sv_vals c_doc ss colour_lst t_str lyr l_lst) (defun *error* ( msg ) (mapcar 'setvar sv_lst sv_vals) (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nAn Error : " msg " occurred."))) (princ) );end_*error*_defun (setq sv_lst (list 'cmdecho 'osmode) sv_vals (mapcar 'getvar sv_lst) c_doc (vla-get-activedocument (vlax-get-acad-object)) p_obj (vlax-ename->vla-object (car (entsel "\nSelect Prefix text : "))) p_str (vlax-get-property p_obj 'textstring) );end_setq (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (vla-startundomark c_doc) (mapcar 'setvar sv_lst '(0 0)) (while (setq t_ent (entsel "\nSelect Text to Prefix : ")) (setq t_obj (vlax-ename->vla-object (car t_ent))) (vlax-put-property t_obj 'textstring (strcat p_str (vlax-get-property t_obj 'textstring))) );end_while (mapcar 'setvar sv_lst sv_vals) (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (princ) );end_defun Tx for you effort. I want to use with selection set. Can you revise the code please? Quote
Tharwat Posted February 21, 2019 Posted February 21, 2019 Hi, Just this a shot. (defun c:test (/ s x i e) (and (princ "\nPick a prefix text :") (or (setq s (ssget "_+.:S:E" '((0 . "*TEXT")))) (alert "Invalid object or nothing selected. Try again") ) (princ (strcat "\nSelect texts to add prefix [" (setq x (cdr (assoc 1 (entget (ssname s 0))))) "]. to them :" ) ) (setq i -1 s (ssget "_:L" '((0 . "*TEXT"))) ) (while (setq e (ssname s (setq i (1+ i)))) (entmod (subst (cons 1 (strcat x (cdr (assoc 1 (setq e (entget e)))))) (assoc 1 e) e ) ) ) ) (princ) ) 1 Quote
veteranus Posted February 21, 2019 Author Posted February 21, 2019 5 minutes ago, Tharwat said: Hi, Just this a shot. (defun c:test (/ s x i e) (and (princ "\nPick a prefix text :") (or (setq s (ssget "_+.:S:E" '((0 . "*TEXT")))) (alert "Invalid object or nothing selected. Try again") ) (princ (strcat "\nSelect texts to add prefix [" (setq x (cdr (assoc 1 (entget (ssname s 0))))) "]. to them :" ) ) (setq i -1 s (ssget "_:L" '((0 . "*TEXT"))) ) (while (setq e (ssname s (setq i (1+ i)))) (entmod (subst (cons 1 (strcat x (cdr (assoc 1 (setq e (entget e)))))) (assoc 1 e) e ) ) ) ) (princ) ) Hi, Can you upgrade the lisp for working with mtext s? Quote
dlanorh Posted February 21, 2019 Posted February 21, 2019 Try this version (defun c:PText ( / *error* sv_lst sv_vals c_doc ss colour_lst t_str lyr l_lst) (defun *error* ( msg ) (mapcar 'setvar sv_lst sv_vals) (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nAn Error : " msg " occurred."))) (princ) );end_*error*_defun (setq sv_lst (list 'cmdecho 'osmode) sv_vals (mapcar 'getvar sv_lst) c_doc (vla-get-activedocument (vlax-get-acad-object)) p_obj (vlax-ename->vla-object (car (entsel "\nSelect Prefix text : "))) p_str (vlax-get-property p_obj 'textstring) );end_setq (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (vla-startundomark c_doc) (mapcar 'setvar sv_lst '(0 0)) (prompt "\nSelect Text to Prefix : ") (setq ss (ssget '((0 . "TEXT")))) (cond (ss (vlax-for t_obj (vla-get-activeselectionset c_doc) (vlax-put-property t_obj 'textstring (strcat p_str (vlax-get-property t_obj 'textstring))) );end_forwhile ) );end_cond (mapcar 'setvar sv_lst sv_vals) (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (princ) );end_defun 1 Quote
Tharwat Posted February 21, 2019 Posted February 21, 2019 Are you sure that the program does not work with Mtext objects ? Quote
veteranus Posted February 21, 2019 Author Posted February 21, 2019 I just upgraded this line, (prompt "\nSelect Text to Prefix : ") (setq ss (ssget '((0 . "TEXT,MTEXT")))) Now it worket like charm. Thanks dlanorh and Tharwat. Regards for you helps. Quote
dlanorh Posted February 21, 2019 Posted February 21, 2019 1 minute ago, veteranus said: I just upgraded this line, (prompt "\nSelect Text to Prefix : ") (setq ss (ssget '((0 . "TEXT,MTEXT")))) Now it worket like charm. Thanks dlanorh and Tharwat. Regards for you helps. You could have followed @Tharwat example and (setq ss (ssget '((0 . "*TEXT")))) Quote
Tharwat Posted February 21, 2019 Posted February 21, 2019 32 minutes ago, dlanorh said: You could have followed @Tharwat example and (setq ss (ssget '((0 . "*TEXT")))) You can guide a horse to a river but you can not force him to drink. Quote
veteranus Posted February 21, 2019 Author Posted February 21, 2019 50 minutes ago, dlanorh said: You could have followed @Tharwat example and (setq ss (ssget '((0 . "*TEXT")))) I followed hım and it worked very well. Thanks again mr. Tharwat and you sir. Quote
ronjonp Posted February 21, 2019 Posted February 21, 2019 You could have also searched for this .. I'd guess there are already 20+ solutions to this question. Quote
Lee Mac Posted February 21, 2019 Posted February 21, 2019 Here's another existing & generic solution: http://www.cadtutor.net/forum/showthread.php?64606&p=441001&viewfull=1#post441001 Quote
