MGS Posted February 21, 2019 Posted February 21, 2019 Hi. I have been having problems with lineweights for ages but I had a work around, now that has stopped working. I have been using the same ctb file for years - many years - and it always worked perfectly. However suddenly all normal lines have started plotting really thin and feint - polylines are OK. I have tried changing the default lineweight to really thick, but nothing changes - is there a default somewhere that overrides the "lwdefault"? Quote
ReMark Posted February 21, 2019 Posted February 21, 2019 Did you recently change printers/plotters? I ask only because you mentioned that the problem surfaces when you plot a drawing. Quote
RobDraw Posted February 21, 2019 Posted February 21, 2019 On 2/21/2019 at 10:48 AM, MGS said: Hi. I have been having problems with lineweights for ages but I had a work around, now that has stopped working. Expand Why did you need a workaround and what was it? Quote
Cad64 Posted February 22, 2019 Posted February 22, 2019 On 2/21/2019 at 10:48 AM, MGS said: is there a default somewhere that overrides the "lwdefault"? Expand In the plot dialog there is an option to "Scale Lineweights". Have you accidentally enabled that option? Quote
MGS Posted February 22, 2019 Author Posted February 22, 2019 On 2/21/2019 at 1:32 PM, ReMark said: Did you recently change printers/plotters? I ask only because you mentioned that the problem surfaces when you plot a drawing. Expand no - I have always had the same one (HP500) - in fact I don't use it that much any more - this week was the first time for a couple of years, but I have the same issue when plotting pdfs that I create from the degs. Quote
MGS Posted February 22, 2019 Author Posted February 22, 2019 On 2/22/2019 at 12:15 PM, Cad64 said: In the plot dialog there is an option to "Scale Lineweights". Have you accidentally enabled that option? Expand I don't think that is an option as I was working and plotting in model space. Quote
MGS Posted February 22, 2019 Author Posted February 22, 2019 On 2/21/2019 at 2:08 PM, RobDraw said: Why did you need a workaround and what was it? Expand I had an older copy of AutoCAD on an old computer that I used to use to create plot files which worked perfectly, but then that suddenly developed the same issue. Quote
ReMark Posted February 22, 2019 Posted February 22, 2019 In the plot dialog box over on the right hand side where it says Plot Options. Is Plot Object Lineweights enabled? Quote
MGS Posted February 22, 2019 Author Posted February 22, 2019 On 2/22/2019 at 4:52 PM, ReMark said: In the plot dialog box over on the right hand side where it says Plot Options. Is Plot Object Lineweights enabled? Expand yes - and shaded so it can't be edited on that page Quote
SLW210 Posted February 25, 2019 Posted February 25, 2019 How does the Plot Preview appear? Can you share a .dwg and the plot file? And some images of what you have and what the plot looks like. Quote
MGS Posted March 1, 2019 Author Posted March 1, 2019 On 2/25/2019 at 11:39 AM, SLW210 said: How does the Plot Preview appear? Can you share a .dwg and the plot file? And some images of what you have and what the plot looks like. Expand Thank you for this - the plot preview is perfectly OK - just as it has always been, and just as I would expect - it is just the plot that is very feint, on an A4 printer or A0 plotter. I will sort out some files and get them over to you. Quote
