gadgetjay Posted February 20, 2019 Posted February 20, 2019 (edited) Hi, The below code does what I require manually (select items on multiple layers, then an item on target layer and moves whole layers items to target). (defun c:lm () (if (and (not (prompt "\nSelect objects on layers to merge: ")) (setq ss (ssget "_:L")) (setq sel (car (entsel "\nSelect object on target layer: "))) ) (progn (setq laya (strcase (cdr (assoc 8 (entget sel)))) curlay (strcase (getvar 'CLAYER)) laylst nil) (repeat (setq i (sslength ss)) (setq ent (entget (ssname ss (setq i (1- i)))) lay (strcase (cdr (assoc 8 ent))) ) (if (and (not (wcmatch lay (strcat laya ",DEFPOINTS," curlay))) (not (member lay laylst)) ) (setq laylst (cons lay laylst)) ) ) (if laylst (progn (command "_.-laymrg") (foreach l laylst (command "_N" l)) (command "" "_N" laya "_Y"))) ) ) (princ) );END I'm trying (and failing) to automate this by searching for a *TEXT word in the layers moves those layers (all items on layer) to a new layer. EG: searches for RED - finds RED on 4 different layers so merges the contents of these layers to a new layer 'colours'. I can get it to search and find the *Text (probably a more elegant way to do this!) and move the found items but I cannot get it to select the other items on these layers and merge them together. ;search for a word in layers (defun C:Test () (if (not (tblsearch "layer" "Colours")) (command "_.layer" "t" "Colours" "m" "Colours" "c" "7" "" "")) (setq str "RED" ) (if (setq ss (ssget "_X" (list (cons 0 "*TEXT")(cons 1 (strcat "*" str "*"))(cons 410 (getvar 'ctab))))) (repeat (setq i (sslength ss)) (setq d (entget (ssname ss (setq i (1- i))))) (entmod (setq d (subst (cons 8 "Colours") (assoc 8 d) d)))); DO THIS - MOVE TO COLOURS LAYER (setq str "BLUE" );DO THAT - CANNOT FIND RED SEARCH BLUE ) (if (setq ss (ssget "_X" (list (cons 0 "*TEXT")(cons 1 (strcat "*" str "*"))(cons 410 (getvar 'ctab))))) (repeat (setq i (sslength ss)) (setq d (entget (ssname ss (setq i (1- i))))) (entmod (setq d (subst (cons 8 "Colours") (assoc 8 d) d)))); DO THIS - MOVE TO COLOURS LAYER (setq str "GREEN");DO THAT - CANNOT FIND BLUE SEARCH GREEN ) (if (setq ss (ssget "_X" (list (cons 0 "*TEXT")(cons 1 (strcat "*" str "*"))(cons 410 (getvar 'ctab))))) (repeat (setq i (sslength ss)) (setq d (entget (ssname ss (setq i (1- i))))) (entmod (setq d (subst (cons 8 "Colours") (assoc 8 d) d)))); DO THIS - MOVE TO COLOURS LAYER (setq str "YELLOW" );DO THAT - CANNOT FIND GREEN SEARCH YELLOW ) (if (setq ss (ssget "_X" (list (cons 0 "*TEXT")(cons 1 (strcat "*" str "*"))(cons 410 (getvar 'ctab))))) (repeat (setq i (sslength ss)) (setq d (entget (ssname ss (setq i (1- i))))) (entmod (setq d (subst (cons 8 "Colours") (assoc 8 d) d)))); DO THIS - MOVE TO COLOURS LAYER ();DO THAT - CRY! ) ); End Edited February 20, 2019 by gadgetjay Quote
dlanorh Posted February 20, 2019 Posted February 20, 2019 I don't completely understand what you are trying to do! You are searching text in the drawing that contains the part string "*RED*" , or searching for text on a layer name that contains the part string "*RED*"? Quote
BIGAL Posted February 21, 2019 Posted February 21, 2019 (edited) So you have a layer "abc" which has texts "abcRED123" you want all items on that layer changed to "Colours". I would use a foreach or defun so code is once only and pass a list item for red blue green etc '("red" "green" "blue") This is untested (setq ss (ssget "_X" (list (cons 0 "*TEXT")(cons 1 (strcat "*" str "*"))(cons 410 (getvar 'ctab))))) (repeat (setq i (sslength ss)) (setq d (entget (ssname ss (setq i (1- i))))) (setq ss2 (ssget "x" (list (cons 8 (assoc 8 d))))) (entmod (subst (cons 8 "Colours") (assoc 8 d) ss2))); DO THIS - MOVE TO COLOURS LAYER (setq str "YELLOW" );DO THAT - CANNOT FIND GREEN SEARCH YELLOW Edited February 21, 2019 by BIGAL Quote
gadgetjay Posted February 21, 2019 Author Posted February 21, 2019 Hi, I was getting an error with the above code but I guess it was because of my explanation.. The layer names are all numbers 01,02,03,etc. There is no order to what these layers include so I'm trying to get a bit of order to the drawing by correctly naming the layers. There would be numerous layers with *TEXT on but I know there are only a few layers will have unique word (e.g . 'RED' ) amongst the *TEXT. 'RED' maybe on 4 layers so I need to find this word and move the complete contents of those layers to a new 'colours' layer. layer 01 - has text: yellow, RED, blue, green,... layer 02 - has text: banana, apple, pear, grape,... layer 03 - has text: gold, silver, orange, RED,... layer 04 - has text: yellow, pink, RED, blue,... layer 05 - has text: dog, cat, lion,... As RED is on layers 01,03,04 - all the contents of these layers (red, blue orange etc. ) is place on new layer 'Colours' If it didn't find RED it tries another unique word (eg BLUE). Hope that makes more sense! Quote
dlanorh Posted February 21, 2019 Posted February 21, 2019 Try this quicky: The colour name must be words. You should alter the highlighted list for any colour names you want to add or delete (defun c:LM ( / *error* sv_lst sv_vals c_doc ss colour_lst t_str lyr l_lst) (defun *error* ( msg ) (mapcar 'setvar sv_lst sv_vals) (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nAn Error : " msg " occurred."))) (princ) );end_*error*_defun (setq sv_lst (list 'cmdecho 'osmode) sv_vals (mapcar 'getvar sv_lst) c_doc (vla-get-activedocument (vlax-get-acad-object)) ss (ssget "_X" '((0 . "TEXT") (410 . "Model"))) colour_lst (list "* RED *" "* YELLOW *" "* GREEN *" "* CYAN *" "* BLUE *" "* MAGENTA *");<<== Alter list of colours here );end_setq (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (vla-startundomark c_doc) (mapcar 'setvar sv_lst '(0 0)) (cond ( (not (tblobjname "LAYER" "COLOURS")) (vla-add (vla-get-layers c_doc) "COLOURS"))) (cond (ss (vlax-for obj (vla-get-activeselectionset c_doc) (setq t_str (vlax-get-property obj 'textstring) lyr (strcase (vlax-get-property obj 'layer)) ) (foreach col colour_lst (cond ( (wcmatch (strcase t_str) col) (if (not (vl-position lyr l_lst)) (setq l_lst (cons lyr l_lst))))) );end_foreach );end_for (cond (l_lst (foreach lyr l_lst (command "_.-laymrg" "_N" lyr "" "_N" "COLOURS" "_Y")))) ) );end_cond (mapcar 'setvar sv_lst sv_vals) (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc)) (princ) );end_defun ;; 1 Quote
gadgetjay Posted February 24, 2019 Author Posted February 24, 2019 Thanks Dlanorh, it was the weekend here so away from pc... Brilliant it works thank you so much! Quote
