hai, i need a small help.i have a working lisp routine which gives perpendicular line distance to main line,
i want the the lisp to ask me every time i start the lisp that what chainage it should start and what i enter should change the numerical text in this command "" (strcat "CH=1+" "".
means, when i start the lisp and it asks for chainage then i enter 23 then it should out as "" (strcat "CH=23+" "".
and if possible the out put decimal can be changed to 3 decimals. now its coming in 4 decimals like 23+455.2565.
thank you..
pls reply if its possible... thanks
(defun c:Chi (/ s p c a d tp)
  (if
    (and (setq s (car (entsel "\nPick a polyline :")))
	 (or (= (cdr (assoc 0 (entget s))) "LWPOLYLINE")
	     (alert "Invalid object! Please pick a polyline only.")
     (while
       (and
	 (setq
	   p (getpoint "\nSpecify point perpendicular to polyline :")
	 (setq c (vlax-curve-getclosestpointto s p))
	 (setq a (angle p c))
	 (not (grdraw p c 1 -1))
	 ;; rubber line in red colour.
	 (setq d (angle	'(0. 0. 0.)
			(vlax-curve-getfirstderiv
			  s
			  (vlax-curve-getparamatpoint s c)
	 (or
	   (or (equal (rem (+ d (* pi 0.5)) (+ pi pi)) a 1e-4)
	       (equal (rem (+ d (* pi 1.5)) (+ pi pi)) a 1e-4)
	   (alert
	     "Picked point is not a perpendicular to picked polyline. <!>"
	 (setq tp (getpoint "\nSpecify Point for Text : "))
	(entmakex
	  (list
	    '(0 . "text")
	    '(100 . "AcDbEntity")
	    '(67 . 0)
	    '(370 . 13)
	    '(100 . "AcDbText")
	    (cons 10 tp)
	    (cons 40 0.6)		; Change text height here
	    (cons 1
		  (strcat "CH=1+"
			  (rtos (vlax-curve-getdistatpoint s c) 2 4)
	    (cons 71 0)
	    (cons 72 0)
	    (cons 11 '(0 0 0))
	    '(100 . "AcDbText")
	    (cons 73 0)
(vl-load-com)
thank you..
(defun c:Chi (/ s p c a d tp sch)
  (setq sch (getstring "\nSpecify start chainage : <0>"))			;"0" is set as the default value
  (if (= sch "")(setq sch "0"))
  (if
     (while
       (and
	 (setq
			  s
	 (or
	   (alert
	(entmakex
	  (list
	    '(0 . "text")
	    '(67 . 0)
	    '(370 . 13)
	    '(100 . "AcDbText")
	    (cons 10 tp)
	    (cons 1
		  (strcat "CH=" sch "+"
			  (rtos (vlax-curve-getdistatpoint s c) 2 3)			;3 instead of 4 to specify precision
	    (cons 71 0)
	    (cons 72 0)
	    (cons 11 '(0 0 0))
	    '(100 . "AcDbText")
	    (cons 73 0)
(vl-load-com)
There's surely a better way to do it, but this works for me.
  • Thanks 1
thank you so much, it works perfectly.
also is it possible to change the chainage start if the polyline length exceeds 1000. means if the chainage is 23 and i got CH=23+999.856 it adds 1  o 23 in next meter , like 24+000.000
thanks you
