Pattosun Posted February 5, 2019 Posted February 5, 2019 I have 200 DWG's that I need to add the same xreference to and it needs to be Relative Path. The xref file name is "a3sheet.dwg" Scale is 1 Insertion is 0,0 This is my first time writing a Lisp. I have tried: (defun c:XRA () (command "-xref" "Attach" "a3sheet.dwg" "Scale" "1" "0.0" "0" (princ) ) but I'm getting error function cancelled. Ideally the LISP would load and run when the drawing opens, or even better a batch process of all 200 at once... Any help would be much appreciated. Thanks Patto Quote
Lee Mac Posted February 5, 2019 Posted February 5, 2019 You are missing a closing bracket for the command expression - I would suggest: (defun c:xra ( / dwg ) (if (setq dwg (findfile "a3sheet.dwg")) (command "_.-xref" "_A" dwg "_S" 1 "_R" 0 "_non" '(0 0)) ) (princ) ) As for batch processing, you could look to run the above program across multiple drawing from an AutoCAD Script file (.scr). You may wish to refer to the following resources: An Introduction to Script Writing Script Writer Run AutoLISP Program on Batch of Drawings Batch Processing Explanation 1 Quote
Pattosun Posted February 6, 2019 Author Posted February 6, 2019 10 hours ago, Pattosun said: I have 200 DWG's that I need to add the same xreference to and it needs to be Relative Path. The xref file name is "a3sheet.dwg" Scale is 1 Insertion is 0,0 This is my first time writing a Lisp. I have tried: (defun c:XRA () (command "-xref" "Attach" "a3sheet.dwg" "Scale" "1" "0.0" "0" (princ) ) but I'm getting error function cancelled. Ideally the LISP would load and run when the drawing opens, or even better a batch process of all 200 at once... Any help would be much appreciated. Thanks Patto Hi Lee, thanks for the reply. When running your suggested Lisp I an getting the message "error to few arguments" in the command line. Any ideas? Quote
BIGAL Posted February 6, 2019 Posted February 6, 2019 Command has no closing bracket 200 dwgs no probs script could be as simple as open dwg1 (c:X-RAY) close y open dwg2 (c:X-ray) close y .... ignore xray on iPad spell checker If the dwgs are in one directory about 5 minutes work to make script just know lots of cheats to make. Quote
rlx Posted February 6, 2019 Posted February 6, 2019 a quicky before breakfast ;;; Attach Xref to all drawings in Folder , RLX 6-Feb-2019 (defun c:RlxFaXref (/ _getfolder app adoc odbs odbx v xref folder dwg xr) (vl-load-com) (defun _getfolder ( m / sh f r ) (setq sh (vla-getinterfaceobject (vlax-get-acad-object) "Shell.Application") f (vlax-invoke-method sh 'browseforfolder 0 m 0)) (vlax-release-object sh)(if f (progn (setq r (vlax-get-property (vlax-get-property f 'self) 'path))(if (wcmatch r "*\\") r (strcat r "\\"))))) ; i is 0 (absolute), 1 (relative) of 2 (no) -xref path (defun RLXref_SetPathType (i) (vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" (getvar "cprofile") "\\Dialogs\\XattachDialog") "PathType" i)) (setq odbs "ObjectDBX.AxDbDocument" v (substr (getvar 'acadver) 1 2) adoc (vla-get-activedocument (setq app (vlax-get-acad-object)))) (RLXref_SetPathType 1) (cond ((vl-catch-all-error-p (setq odbx (vl-catch-all-apply 'vla-getinterfaceobject (list app (if (< (atoi v) 16) odbs (strcat odbs "." v)))))) (princ "\nObject DBX interface not created!")) ((not (setq xref (getfiled "Select Xref to attach" "" "dwg" 0))) (alert "No Xref was selected")) ((setq folder (_getfolder "Select folder with drawings to attach xref to")) (foreach dwg (vl-directory-files folder "*.dwg" 0) (setq dwg (strcat folder dwg)) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-open (list odbx dwg))) (princ (strcase (strcat "\nError opening: " dwg))) (progn (princ (strcat "\nOpening: " dwg)) ; attach xref (if (vl-catch-all-error-p (setq xr (vl-catch-all-apply 'vla-AttachExternalReference (list (vla-get-ModelSpace odbx) xref (vl-filename-base xref) (vlax-3d-point 0 0 0) 1 1 1 0 :vlax-false)))) (princ (vl-catch-all-error-message xr))) ; save drawing (vla-saveas odbx (vla-get-name odbx)) ) ) ) ) ) (princ) ) 1 1 Quote
Pattosun Posted February 6, 2019 Author Posted February 6, 2019 (edited) Thanks so much for your replies, and great content on your site Lee Mac... I've got it working using a script... I'm a first timer on this so awesome to get something working... _.open "C:\Users\Patto\Documents\Drawings\DWG204H524.dwg" _.xref _D C:\Users\Patto\Documents\Titleblock\a3sheet.dwg _S 1 _R 0 _non 0,0,0 _.Zoom _E _.qsave _.close _.open "C:\Users\Patto\Documents\Drawings\DWG204H525.dwg" _.xref _D C:\Users\Patto\Documents\Titleblock\a3sheet.dwg _S 1 _R 0 _non 0,0,0 _.Zoom _E _.qsave _.close _.open "C:\Users\Patto\Documents\Drawings\DWG204H526.dwg" _.xref _D C:\Users\Patto\Documents\Titleblock\a3sheet.dwg _S 1 _R 0 _non 0,0,0 _.Zoom _E _.qsave _.close Now I also want to Create a new text style in each drawing and move all existing text to that style... Here is what I have so far... _.open "C:\Users\Patto\Documents\Drawings\DWG204H524.dwg" _.style AS100 ISO3098b 0 1 0 N N N _.Zoom _E _.qsave _.close This creates the new AS1100 text style but I can't work out what commands to use to select all text and move them to that text style... AI_SELALL selects everything but I just want to select the MText and Text. Any ideas? Edited February 6, 2019 by Pattosun missing so info Quote
rlx Posted February 6, 2019 Posted February 6, 2019 (edited) _.open "C:\Users\Patto\Documents\Drawings\DWG204H524.dwg" (load "chstyle.lsp") (c:chstyle) _.Zoom _E _.qsave _.close (defun c:ChStyle ( / s i o) (vl-load-com) (if (and (not (tblsearch "style" "AS100"))(findfile "ISO3098b.shx")) (vl-cmdf "-style" "AS100" "ISO3098b" 0 1 0 "N" "N" "N") (if (not (findfile "ISO3098b.shx"))(princ "\nText font ISO3098b.shx not found"))) (if (and (tblsearch "style" "AS100") (setq s (ssget "x" '((0 . "TEXT,MTEXT"))))) (repeat (setq i (sslength s)) (vla-put-stylename (setq o (vlax-ename->vla-object (ssname s (setq i (1- i))))) "AS100") (vla-Update o) ) (princ "\nNo (m)text objects were updated") ) (princ) ) Edited February 6, 2019 by rlx Quote
Lee Mac Posted February 6, 2019 Posted February 6, 2019 12 hours ago, Pattosun said: Hi Lee, thanks for the reply. When running your suggested Lisp I an getting the message "error to few arguments" in the command line. Any ideas? Are you sure you copied the code correctly? Are you viewing this site through a translator which may have mangled the code? Quote
Pattosun Posted February 6, 2019 Author Posted February 6, 2019 Thanks so much rlx, that's awesome...... It does one dwg at a time, is there a way to get this working as a batch process? I've tried to use this for multiple drawing using Lee Mac's ScriptWriter: So APPLOAD load your lsp Then load ScriptWriter and use.... _.open *file* (c:ChStyle) _.qsave but this only does the first drawing in the folder, the others are opened but no changes are made? Quote
rlx Posted February 6, 2019 Posted February 6, 2019 (edited) you have to either load the lisp file every time in the script file (as in example line above my code) or you must make sure this file is auto-loaded every time you open a file , for example with s::startup in your acad.lsp or just add it as a standard routine in your acad.lsp. With a few mod's code can be added to my first code which uses odbx but scripts are more fun to look at even though they are a little bit slower. Edited February 6, 2019 by rlx 1 Quote
BIGAL Posted February 6, 2019 Posted February 6, 2019 I posted this before but you can use find replace to edit scripts adding like rlx code, I normally just start with a dwg names text file. This is created using old fashioned DOS commands dir *.dwg >dwglst.txt Using Word you can change end of line or start of line adding stuff like open, close y it’s ^p for end of line. 1 Quote
Pattosun Posted February 7, 2019 Author Posted February 7, 2019 31 minutes ago, Lee Mac said: Are you sure you copied the code correctly? Are you viewing this site through a translator which may have mangled the code? Hi Lee, I didn't see your message till this morning.... No I'm not using a translator. I think the problem was the folder naming that my client has asked for. They want the xref stored in ..\..\Title Block & Images\a3sheet.dwg Do spaces and characters such as "&" cause a problem with lisp and script? I changed the folder name to ..\..\Titleblock\a3sheet.dwg and it worked, but my client insists that they will not change their file structure. Is there a way to keep the folder as "Title Block & Images" but still batch process the dwgs? Quote
Pattosun Posted February 7, 2019 Author Posted February 7, 2019 Thanks for all your replies everyone, this was a steep learning curve for me, and I still have a long way to go. I have updated my 200 DWGs using the method below. Some of the items below could probably be combined or added to the acad start up lsp if I was more knowledgable, but this is how I got to the end result so thought I would type it out for any other Newbies out there .... How to Xref Detach All, Xref Attach, Make Xref Relative, Create Text Style, Change All Text To This Style : Load LSP files in AutoCAD APPLOAD > Chstyle.lsp (by RLX see below) Rlxfaxref.lsp (by RLX see below) ScriptWriterV1-2.lsp (by Lee Mac http://lee-mac.com/scriptwriter.html) Batch Detach All Old Xref's using Script Writer WSCRIPT > Use script line: _.open *file* _.xref _D * _.zoom _E _.qsave _.close Choose drawing directory Batch Attach New Xref using LSP RLXRAREF > Select Xref to attach Browse to DWG folder Batch Make Xref Relative using Script Writer WSCRIPT > Use script line: _.open *file* _.xref _T a3sheet _R _.zoom _E _.qsave _.close Choose drawing directory Batch Create New Text Style and Change All Text To This Style WSCRIPT > Use script line: _.open *file* (load”chstyle.lsp”) (c:chstyle) _.zoom _E _.qsave _.close Choose drawing directory RLXFAREF.LSP ;;; Attach Xref to all drawings in Folder , RLX 6-Feb-2019 (defun c:RlxFaXref (/ _getfolder app adoc odbs odbx v xref folder dwg xr) (vl-load-com) (defun _getfolder ( m / sh f r ) (setq sh (vla-getinterfaceobject (vlax-get-acad-object) "Shell.Application") f (vlax-invoke-method sh 'browseforfolder 0 m 0)) (vlax-release-object sh)(if f (progn (setq r (vlax-get-property (vlax-get-property f 'self) 'path))(if (wcmatch r "*\\") r (strcat r "\\"))))) ; i is 0 (absolute), 1 (relative) of 2 (no) -xref path (defun RLXref_SetPathType (i) (vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" (getvar "cprofile") "\\Dialogs\\XattachDialog") "PathType" i)) (setq odbs "ObjectDBX.AxDbDocument" v (substr (getvar 'acadver) 1 2) adoc (vla-get-activedocument (setq app (vlax-get-acad-object)))) (RLXref_SetPathType 1) (cond ((vl-catch-all-error-p (setq odbx (vl-catch-all-apply 'vla-getinterfaceobject (list app (if (< (atoi v) 16) odbs (strcat odbs "." v)))))) (princ "\nObject DBX interface not created!")) ((not (setq xref (getfiled "Select Xref to attach" "" "dwg" 0))) (alert "No Xref was selected")) ((setq folder (_getfolder "Select folder with drawings to attach xref to")) (foreach dwg (vl-directory-files folder "*.dwg" 0) (setq dwg (strcat folder dwg)) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-open (list odbx dwg))) (princ (strcase (strcat "\nError opening: " dwg))) (progn (princ (strcat "\nOpening: " dwg)) ; attach xref (if (vl-catch-all-error-p (setq xr (vl-catch-all-apply 'vla-AttachExternalReference (list (vla-get-ModelSpace odbx) xref (vl-filename-base xref) (vlax-3d-point 0 0 0) 1 1 1 0 :vlax-false)))) (princ (vl-catch-all-error-message xr))) ; save drawing (vla-saveas odbx (vla-get-name odbx)) ) ) ) ) ) (princ) ) CHSTYLE.LSP (defun c:ChStyle ( / s i o) (vl-load-com) (if (and (not (tblsearch "style" "AS100"))(findfile "ISO3098b.shx")) (vl-cmdf "-style" "AS100" "ISO3098b" 0 1 0 "N" "N" "N") (if (not (findfile "ISO3098b.shx"))(princ "\nText font ISO3098b.shx not found"))) (if (and (tblsearch "style" "AS100") (setq s (ssget "x" '((0 . "TEXT,MTEXT"))))) (repeat (setq i (sslength s)) (vla-put-stylename (setq o (vlax-ename->vla-object (ssname s (setq i (1- i))))) "AS100") (vla-Update o) ) (princ "\nNo (m)text objects were updated") ) (princ) ) Quote
rlx Posted February 7, 2019 Posted February 7, 2019 We'll make a geek out of you yet , you nerd haha happy coding 1 Quote
Lee Mac Posted February 7, 2019 Posted February 7, 2019 17 hours ago, Pattosun said: Do spaces and characters such as "&" cause a problem with lisp and script? I changed the folder name to ..\..\Titleblock\a3sheet.dwg and it worked, but my client insists that they will not change their file structure. Is there a way to keep the folder as "Title Block & Images" but still batch process the dwgs? Spaces and the ampersand character will not cause a problem, but note that the backslash character is an Escape Character in AutoLISP, and hence, a literal backslash is obtained by prefixing the backslash escape character with another backslash to mark it as a literal. As such, the path should be: "..\\..\\Title Block & Images\\a3sheet.dwg" 1 Quote
ante2803 Posted April 24, 2019 Posted April 24, 2019 On 2/6/2019 at 6:54 AM, rlx said: a quicky before breakfast ;;; Attach Xref to all drawings in Folder , RLX 6-Feb-2019 (defun c:RlxFaXref (/ _getfolder app adoc odbs odbx v xref folder dwg xr) (vl-load-com) (defun _getfolder ( m / sh f r ) (setq sh (vla-getinterfaceobject (vlax-get-acad-object) "Shell.Application") f (vlax-invoke-method sh 'browseforfolder 0 m 0)) (vlax-release-object sh)(if f (progn (setq r (vlax-get-property (vlax-get-property f 'self) 'path))(if (wcmatch r "*\\") r (strcat r "\\"))))) ; i is 0 (absolute), 1 (relative) of 2 (no) -xref path (defun RLXref_SetPathType (i) (vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" (getvar "cprofile") "\\Dialogs\\XattachDialog") "PathType" i)) (setq odbs "ObjectDBX.AxDbDocument" v (substr (getvar 'acadver) 1 2) adoc (vla-get-activedocument (setq app (vlax-get-acad-object)))) (RLXref_SetPathType 1) (cond ((vl-catch-all-error-p (setq odbx (vl-catch-all-apply 'vla-getinterfaceobject (list app (if (< (atoi v) 16) odbs (strcat odbs "." v)))))) (princ "\nObject DBX interface not created!")) ((not (setq xref (getfiled "Select Xref to attach" "" "dwg" 0))) (alert "No Xref was selected")) ((setq folder (_getfolder "Select folder with drawings to attach xref to")) (foreach dwg (vl-directory-files folder "*.dwg" 0) (setq dwg (strcat folder dwg)) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-open (list odbx dwg))) (princ (strcase (strcat "\nError opening: " dwg))) (progn (princ (strcat "\nOpening: " dwg)) ; attach xref (if (vl-catch-all-error-p (setq xr (vl-catch-all-apply 'vla-AttachExternalReference (list (vla-get-ModelSpace odbx) xref (vl-filename-base xref) (vlax-3d-point 0 0 0) 1 1 1 0 :vlax-false)))) (princ (vl-catch-all-error-message xr))) ; save drawing (vla-saveas odbx (vla-get-name odbx)) ) ) ) ) ) (princ) ) Could you please change code, I need xref to be attached in Paper space not Model. Thank you in advance Quote
rlx Posted April 24, 2019 Posted April 24, 2019 haven't looked at this code for a while so just guessing right now but change : (list (vla-get-ModelSpace odbx) xref (vl-filename-base xref) (vlax-3d-point 0 0 0) 1 1 1 0 :vlax-false)))) to (list (vla-get-PaperSpace odbx) xref (vl-filename-base xref) (vlax-3d-point 0 0 0) 1 1 1 0 :vlax-false)))) Quote
rlx Posted April 25, 2019 Posted April 25, 2019 ; attach xref in paperspace (defun c:RlxPsXref (/ _getfolder RLXref_SetPathType app adoc odbs odbx v xref folder dwg xr lay) (vl-load-com) (defun _getfolder ( m / sh f r ) (setq sh (vla-getinterfaceobject (vlax-get-acad-object) "Shell.Application") f (vlax-invoke-method sh 'browseforfolder 0 m 0)) (vlax-release-object sh)(if f (progn (setq r (vlax-get-property (vlax-get-property f 'self) 'path))(if (wcmatch r "*\\") r (strcat r "\\"))))) ; i is 0 (absolute), 1 (relative) of 2 (no) -xref path (defun RLXref_SetPathType (i) (vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" (getvar "cprofile") "\\Dialogs\\XattachDialog") "PathType" i)) (setq odbs "ObjectDBX.AxDbDocument" v (substr (getvar 'acadver) 1 2) adoc (vla-get-activedocument (setq app (vlax-get-acad-object)))) (RLXref_SetPathType 1) (cond ((vl-catch-all-error-p (setq odbx (vl-catch-all-apply 'vla-getinterfaceobject (list app (if (< (atoi v) 16) odbs (strcat odbs "." v)))))) (princ "\nObject DBX interface not created!")) ((not (setq xref (getfiled "Select Xref to attach" "" "dwg" 0))) (alert "No Xref was selected")) ((setq folder (_getfolder "Select folder with drawings to attach xref to")) (foreach dwg (vl-directory-files folder "*.dwg" 0) (setq dwg (strcat folder dwg)) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-open (list odbx dwg))) (princ (strcase (strcat "\nError opening: " dwg))) (progn (princ (strcat "\nOpening: " dwg)) ; attach xref (if (vl-catch-all-error-p (setq xr (vl-catch-all-apply 'vla-AttachExternalReference (list (vla-get-ModelSpace odbx) xref (vl-filename-base xref) (vlax-3d-point 0 0 0) 1 1 1 0 :vlax-false)))) (princ (vl-catch-all-error-message xr)) (progn (vlax-for lay (vla-get-layouts odbx) (if (/= "MODEL" (strcase (vla-get-name lay))) (vlax-invoke odbx 'copyobjects (list xr) (vla-get-block lay)))) (vla-delete xr) ) ) ; save drawing (vla-saveas odbx (vla-get-name odbx)) ) ) ) ) ) (princ) ) Quote
Palle Posted May 9, 2019 Posted May 9, 2019 On 2/6/2019 at 6:54 AM, rlx said: a quicky before breakfast ;;; Attach Xref to all drawings in Folder , RLX 6-Feb-2019 (defun c:RlxFaXref (/ _getfolder app adoc odbs odbx v xref folder dwg xr) (vl-load-com) (defun _getfolder ( m / sh f r ) (setq sh (vla-getinterfaceobject (vlax-get-acad-object) "Shell.Application") f (vlax-invoke-method sh 'browseforfolder 0 m 0)) (vlax-release-object sh)(if f (progn (setq r (vlax-get-property (vlax-get-property f 'self) 'path))(if (wcmatch r "*\\") r (strcat r "\\"))))) ; i is 0 (absolute), 1 (relative) of 2 (no) -xref path (defun RLXref_SetPathType (i) (vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" (getvar "cprofile") "\\Dialogs\\XattachDialog") "PathType" i)) (setq odbs "ObjectDBX.AxDbDocument" v (substr (getvar 'acadver) 1 2) adoc (vla-get-activedocument (setq app (vlax-get-acad-object)))) (RLXref_SetPathType 1) (cond ((vl-catch-all-error-p (setq odbx (vl-catch-all-apply 'vla-getinterfaceobject (list app (if (< (atoi v) 16) odbs (strcat odbs "." v)))))) (princ "\nObject DBX interface not created!")) ((not (setq xref (getfiled "Select Xref to attach" "" "dwg" 0))) (alert "No Xref was selected")) ((setq folder (_getfolder "Select folder with drawings to attach xref to")) (foreach dwg (vl-directory-files folder "*.dwg" 0) (setq dwg (strcat folder dwg)) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-open (list odbx dwg))) (princ (strcase (strcat "\nError opening: " dwg))) (progn (princ (strcat "\nOpening: " dwg)) ; attach xref (if (vl-catch-all-error-p (setq xr (vl-catch-all-apply 'vla-AttachExternalReference (list (vla-get-ModelSpace odbx) xref (vl-filename-base xref) (vlax-3d-point 0 0 0) 1 1 1 0 :vlax-false)))) (princ (vl-catch-all-error-message xr))) ; save drawing (vla-saveas odbx (vla-get-name odbx)) ) ) ) ) ) (princ) ) Hi I am new to the forum and not sure how things work. I am also completely new to coding. But I like the coding, RLX. However most of my drawings are in the layout tab, for your coding to work I need to be in the model tab. Is it possible to add a switch to the model tab before starting the rest of the code? Quote
rlx Posted May 9, 2019 Posted May 9, 2019 Not sure if modelspace tab needs to be active for this routine to work. As you can see in the code before your post, the xref it is inserted in modelspace and then copied to paperspace and the one in modelspace is deleted. But to make make the modelspace active you would need a script because this routine uses odbx and this has many restrictions and one of them is changing the active layout https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/set-layout-current-via-objectdbx/td-p/1233977 (if (vl-catch-all-error-p (setq xr (vl-catch-all-apply 'vla-AttachExternalReference (list (vla-get-ModelSpace odbx) xref (vl-filename-base xref) (vlax-3d-point 0 0 0) 1 1 1 0 :vlax-false)))) (princ (vl-catch-all-error-message xr)) (progn (vlax-for lay (vla-get-layouts odbx) (if (/= "MODEL" (strcase (vla-get-name lay))) (vlax-invoke odbx 'copyobjects (list xr) (vla-get-block lay)))) (vla-delete xr) ) ) Quote
