Multiple polyline area sum
Jest
I need a lisp command, to calculate area sum of already selected multiple closed polylines ...
Thanks
(vl-load-com)
;; Get Selected Areas
(defun c:gsa ( / ss1 obj i sum)
  ;; SSGET polylines already selected
  (setq ss1  (ssget "I" '( (0 . "POLYLINE,LWPOLYLINE") (70 . 1) )))  ;; 70=1 means closed
  (setq
    i 0
    sum 0.0
  (repeat (sslength ss1)
    (setq obj (vlax-ename->vla-object (ssname ss1 i)))
    (setq ar (vlax-curve-getarea obj))  ;; get area
    (setq sum (+ sum ar))
    (setq i (+ i 1))
  (princ sum)
Edited by Emmanuel Delay
Thank you!!
It works fine, but I have two more questions, and asking you, if you can help me.
Using this lisp, i found out two strange things.
1. example: My units are set to 4 decimal numbers. in one case result shows 5 decimal numbers.
2. example: I choose few really big objects and result is 9.36016e+06. But I want to see whole real number (so I can use copy-paste option), not to calculate result ...is it possible at all?
How to fix this. Do I have to change something in my program settings or any of System Variables?
kind regards!
You may want to consider my Total Length & Area programs.
To modify the precision of the output, change:
(princ (rtos a 2))
To:
(princ (rtos a 2 15))
Alternatively, retain the existing code and increase the value of your LUPREC system variable.
Edited by Lee Mac
Thanks....exactly what I need.
By the way, an option (princ (rtos a 2 1 5 )) doesnt work...but never mind, original version works fine.
Now I am just wondering, if there is an option, to display thousands separated with comma...or space..?
It should be:
(rtos a 2 15)
Per my post, not:
(rtos a 2 1 5)
The rtos function accepts a maximum of three arguments.
Edited by Lee Mac
For this you can make use of the function I posted here.
Copy the code for that function to the end of your .lsp file, and then change the output expression to:
(princ (rtoc a 15))
Edited by Lee Mac
It works, but now i got 6 decimal numbers, not 4, as before..
Did I wrote down correctly?:
;;---------------------=={ Total Area }==---------------------;;
;;  Displays the total area of selected objects at the        ;;
;;  command line. The precision of the printed result is      ;;
;;  dependent on the setting of the LUPREC system variable.   ;;
;;  Author: Lee Mac, Copyright © 2013 - www.lee-mac.com       ;;
(defun c:tarea ( / a i s )
    (if (setq s
            (ssget
               '(   (0 . "CIRCLE,ELLIPSE,*POLYLINE,SPLINE")
                    (-4 . "<NOT")
                        (-4 . "<AND")
                            (0 . "POLYLINE") (-4 . "&") (70 . 80)
                        (-4 . "AND>")
                    (-4 . "NOT>")
            (setq a 0.0)
            (repeat (setq i (sslength s))
                (setq a (+ a (vlax-curve-getarea (ssname s (setq i (1- i))))))
            (princ "\nTotal Area: ")
            (princ (rtoc a 15))
(vl-load-com) (princ)
(defun rtoc ( n p / d i l x )
    (setq d (getvar 'dimzin))
    (setvar 'dimzin 0)
    (setq l (vl-string->list (rtos (abs n) 2 p))
          x (cond ((cdr (member 46 (reverse l)))) ((reverse l)))
          i 0
    (setvar 'dimzin d)
    (vl-list->string
        (append (if (minusp n) '(45))
            (reverse
                (apply 'append
                    (mapcar
                       '(lambda ( a b )
                            (if (and (zerop (rem (setq i (1+ i)) 3)) b)
                                (list a 44)
                                (list a)
                        x (append (cdr x) '(nil))
            (member 46 l)
Note that the precision is limited to approximately 15 significant figures, hence for larger numbers, you'll lose precision in the number of decimal places - observe:
_$ (rtos 1.123456789012345 2 15)
"1.123456789012345"
_$ (rtos 10.123456789012345 2 15)
"10.12345678901234"
_$ (rtos 100.123456789012345 2 15)
"100.1234567890123"
_$ (rtos 1000.123456789012345 2 15)
"1000.123456789012"
_$ (rtos 10000.123456789012345 2 15)
"10000.12345678901"
_$ (rtos 100000.123456789012345 2 15)
"100000.123456789"
_$ (rtos 1000000.123456789012345 2 15)
"1000000.123456789"
_$ (rtos 10000000.123456789012345 2 15)
"10000000.12345679"
_$ (rtos 100000000.123456789012345 2 15)
"100000000.1234568"
_$ (rtos 1000000000.123456789012345 2 15)
"1000000000.123457"
_$ (rtos 10000000000.123456789012345 2 15)
"10000000000.12345"
_$ (rtos 100000000000.123456789012345 2 15)
"100000000000.1235"
_$ (rtos 1000000000000.123456789012345 2 15)
"1000000000000.123"
_$ (rtos 10000000000000.123456789012345 2 15)
"10000000000000.12"
_$ (rtos 100000000000000.123456789012345 2 15)
"100000000000000.1"
_$ (rtos 1000000000000000.123456789012345 2 15)
"1000000000000000"
I see...thanks
Can you just tell me, ho toadd thousand comma separation to TotaL Lenght lisp?
6 hours ago, Jest said:
I see...thanks
In the same way, changing:
(princ (rtos l))
to:
(princ (rtoc l 15))
  • 2 years later...
On 2/5/2019 at 3:51 PM, Emmanuel Delay said:
(vl-load-com)
  (setq
    i 0
    sum 0.0
    (setq i (+ i 1))
  (princ sum)
This is nearly perfect for me however I would like to have the sum of the areas of the polylines written in an MText in this format:
"%lu2%pr2%ps[,]%ct8[0.0001]"
(I draw in cm and want the sum in m2)
Cheers!
This will create an mtext object, just replace the "princ sum" text in the above with this
  (setq pt (getpoint "Select Insertion Point"))
  (entmakex (list (cons 0 "MTEXT")
                  (cons 100 "AcDbEntity")
                  (cons 100 "AcDbMText")
                  (cons 10 pt) ;Insertion Point
                  (cons 1 sum) ;Sum text from above
                  (cons 40 2.5)
and you can have a look on google how to format this as you want
Wouldn't you need to divide by 10000 to get m² or is that taken care of with that formatting?
Punched up the code a bit. After making mtext its copied to clipboard.
(defun c:gsa (/ sum SS1 ent poly area pt str)
  (vl-load-com)
  (setq sum 0)
  (if (ssget "I") ;allows user to have polylines already selected or select them while code is running.
    (setq SS1 (ssget "_P" '((0 . "*POLYLINE") (70 . 1))))
    (setq SS1 (ssget '((0 . "*POLYLINE") (70 . 1))))
  (if SS1
      (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS1)))
        (setq poly (vlax-ename->vla-object ent)
              sum (+ sum (vlax-curve-getarea poly))
      (entmake (list '(0 . "MTEXT")
                     '(100 . "AcDbEntity")
                     '(100 . "AcDbMText")
                     (cons 1 (setq str (strcat (rtos (/ sum 10000) 2 3) " m²")))  ;cm to m convert
                     (cons 40 (getvar "TextSize"))
      (vlax-invoke (vlax-get (vlax-get (setq html (vlax-create-object "htmlfile")) 'ParentWindow) 'ClipBoardData) 'setData "TEXT" str)
      ;copies output to clipboard
      (vlax-release-object html)
    (prompt "/nNo Polylines Selected")
Edited by mhupp
  • 9 months later...
    (if (setq s
            (ssget
                    (-4 . "<NOT")
                        (-4 . "<AND")
                        (-4 . "AND>")
                    (-4 . "NOT>")
            (setq a 0.0)
            (princ (rtoc a 15))
    (setvar 'dimzin 0)
          i 0
    (setvar 'dimzin d)
    (vl-list->string
            (reverse
                (apply 'append
                    (mapcar
                       '(lambda ( a b )
                                (list a 44)
                                (list a)
            (member 46 l)
It's works perfectly ❤️
