MS13 Posted February 1, 2019 Posted February 1, 2019 Hello again. I am using routine Quote (defun c:ahl (/ p1 p2 p3 p4 a10 a1 a2 s1 s2 lin pickpt linname lindata ang1) (setq cosmode (getvar "OSMODE")) (setvar "OSMODE" 0) (setq lin (entsel "\nPick a line: ") pickpt (cadr lin) linname (car lin) lindata (entget linname) p1 (cdr (assoc 10 lindata)) p2 (cdr (assoc 11 lindata)) ) (if (< (distance p1 pickpt) (distance pickpt p2)) (setq p3 p1 p1 p2 p2 p3 ) ) (setq ang (angle p1 p2) ang1 (* (/ ang pi) 180) a10 (* (/ 10.0 180) pi) a1 (+ (- ang a10) pi) a2 (+ (+ ang a10) pi) ) (if (= (getvar "USERR1") 0.0) (setvar "USERR1" 3.0) ) (setq s1 (getvar "USERR1")) (setq mess (strcat "\nArrow Size = <" (rtos s1) "> ")) (setq s2 (getreal mess)) (if (= s2 nil) (setq s2 s1) (setvar "USERR1" S2) ) (setq p3 (polar p2 a1 s2) p4 (polar p2 a2 s2) ) (command "SOLID" p2 p3 p4 p3 "") (setvar "OSMODE" cosmode) ) Expand Is there a chance to modify it and: 1) Insert arrow where I want on the line (snap) 2) Or at least add option to change which end of the line should have arrow. Sometimes it picks up wrong end (not the one I want) and I need to rotate for 180 deg and elevate arrow Thanks Quote
ronjonp Posted February 1, 2019 Posted February 1, 2019 Any reason you don't just use a leader? 1 Quote
MS13 Posted February 1, 2019 Author Posted February 1, 2019 Because I need to arrow some lines in the drawing Quote
BIGAL Posted February 2, 2019 Posted February 2, 2019 The correct end can be checked by comparing pick point to end points distance and swap start end point if required, on iPad will post code later Quote
ronjonp Posted February 2, 2019 Posted February 2, 2019 On 2/2/2019 at 10:09 PM, BIGAL said: The correct end can be checked by comparing pick point to end points distance and swap start end point if required, on iPad will post code later Expand The code already does that. Quote
BIGAL Posted February 2, 2019 Posted February 2, 2019 Hi ronjonp did not look to close in that case sounds like operator error. Quote
ronjonp Posted February 4, 2019 Posted February 4, 2019 On 2/2/2019 at 10:22 PM, BIGAL said: Hi ronjonp did not look to close in that case sounds like operator error. Expand Yeah .. I'm not sure what's going on. Maybe the OP can post a drawing where it does not work. Quote
ronjonp Posted February 4, 2019 Posted February 4, 2019 (edited) Maybe this will help: (defun c:foo (/ a e p0 p1 p2) (cond ((null (tblobjname "block" "_ar")) (entmake '((0 . "BLOCK") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbBlockReference") (2 . "_ar") (10 0 0 0) (70 . 0) ) ) (entmake '((0 . "LWPOLYLINE") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbPolyline") (90 . 2) (70 . 128) (10 0 0 0) (41 . 0.347296) (10 -0.984807 0.0) (40 . 0.347296) (41 . 0.347296) ) ) (entmake '((0 . "ENDBLK") (100 . "AcDbBlockEnd") (8 . "0"))) ) ) (cond ((and (setq e (entsel "\Pick a line: ")) (= "LINE" (cdr (assoc 0 (entget (car e))))) (progn (initget 6) (or (setq sc (getdist "\nEnter scale: <3.0> ")) (setq sc 3.))) ) (setq p0 (vlax-curve-getclosestpointtoprojection (car e) (trans (cadr e) 1 (car e)) '(0. 0. 1.)) ) (setq e (entget (car e))) (setq p1 (cdr (assoc 10 e))) (setq p2 (cdr (assoc 11 e))) (setq a (angle p1 p2)) (setq p1 (cond ((< (distance p1 p0) (distance p2 p0)) (list p1 (+ pi a))) ((list p2 a)) ) ) (entmakex (list '(0 . "insert") (cons 10 (car p1)) '(2 . "_ar") (assoc 8 e) (cons 50 (cadr p1)) (cons 41 sc) (cons 42 sc) (cons 43 sc) ) ) ) ) (princ) ) Edited February 8, 2019 by ronjonp Quote
MS13 Posted February 7, 2019 Author Posted February 7, 2019 Sorry guys for keep you waiting for any reply. ronjonp your routine works same as ahl - does not doing good in same way I have attached drawing with lines where foo and ahl works and do not work 1.dwg Quote
Roy_043 Posted February 8, 2019 Posted February 8, 2019 The lines are not co-planar with the WCS XY-plane and all have a non-zero delta Z. Quote
ronjonp Posted February 8, 2019 Posted February 8, 2019 On 2/7/2019 at 7:36 PM, MS13 said: Sorry guys for keep you waiting for any reply. ronjonp your routine works same as ahl - does not doing good in same way I have attached drawing with lines where foo and ahl works and do not work 1.dwgFetching info... Expand Updated the code. Give it a try Quote
